Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 08-27-2009, 07:01 PM   #21
Larry T
Old School HAMBer
Larry T's Avatar
Default Re: How To Narrow A 9 Inch Ford Rear End Housing:
Fords are pretty standard at 2 1/2". The measurements for other axles are in the Mark Williams catalog.
Larry T
__________________
Goldchainers CC
offline   Reply With Quote
Old 08-27-2009, 07:29 PM   #22
Drive Em
Senior Member
Quote:
Larry T
Most small bearing 8" and 9" Ford axles have a 2 1/2" brake offset, but most big bearing 9" Ford axles have a 2 3/8" brake offset.
Old 08-27-2009, 08:11 PM   #23
Larry T
Old School HAMBer
Larry T's Avatar
I don't know, but on all of the aftermarket axles I've ordered for Fords I've had them set up for 2.5 standout and never had any trouble with them. The only place I can see a problem is the drum not fitting the shoe right and unless tolerances stack up 1/8"/side isn't gonna be real critical. 1/4" total on rear end width shouldn't cause much problem either.
Larry T
Click image for larger version
Name:	axle standout.jpg
__________________
Goldchainers CC
Old 08-27-2009, 10:24 PM   #24
scottybaccus
Alliance Member
scottybaccus's Avatar
It depends on the brakes you run. My mid '70s truck drums for early big ford ends are 2 3/8" brake space.
__________________
Shooting down dumb asses one S-10 frame swap at a time...
Tejas Malcontents, Hutto
Old 08-27-2009, 10:42 PM   #25
Drive Em
Senior Member
Larry T
I was talking about factory Ford axles, with aftermarket axles, you can get anything you want. You're right, an 1/8" is no big deal if the barke offset is too big, but if the brake offset is too small, the drums might hit the backing plate and not seat all the way in.
Old 08-27-2009, 10:44 PM   #26
spark
spark's Avatar
Quote:
Originally Posted by Drive Em; The left side axle measures 25 5/8" from the outside of the flange to the end of the splines:
The right side axle measures 29 5/8" from the outside of the flange to the end of the splines:
29 5/8 – 25 5/8 = 4
Could you shorten the right side of the housing by 4 inchs and put in 2 left axles?
__________________
-if I paint stripes on a donkey is he a zebra or am I a jackass?
www.hotrodforum.freeforums.org
Old 08-27-2009, 10:48 PM   #27
Drive Em
Senior Member
Quote:
Originally Posted by spark View Post
29 5/8 – 25 5/8 = 4
You could, but your drive shaft would run at an angle. If you have the room, it will work as I have done them that way in the past.
Old 08-27-2009, 10:50 PM   #28
dirtbag13
Old School HAMBer
dirtbag13's Avatar
very nice tech !
__________________
One hand on the wheel and one on the bottle one foot in the grave the other the throttle !
Old 09-01-2009, 06:33 PM   #29
Kan Kustom
Good thread.
Old 10-24-2009, 09:31 PM   #30
Rusty
Old School HAMBer
Rusty's Avatar
good stuff
__________________
Dirtys Speed Shop
214 537-7423
Texas Nostalgia Nationals
Yello Belly Dragstrip - Grand Prairie, TX
www.texasnostalgianationals.com
Old 10-24-2009, 09:44 PM   #31
robt500
robt500's Avatar
thanks man
Old 10-24-2009, 09:45 PM   #32
brandonwillis
Grenade Inspector
brandonwillis's Avatar
good read
online   Reply With Quote
Old 10-24-2009, 09:48 PM   #33
robt500
robt500's Avatar
Quote:
Originally Posted by Drive Em View Post
I omitted the straightening of the housing process that goes along with the narrowing process because I am going to do a separate "Straighteneing A 9" Housing" article in a day or so. 9 out of 10 housings I work on are bent on at least one tube.
http://www.jalopyjournal.com/forum/s...d.php?t=393748
just to make the "straightening" thread easy to find
Old 10-25-2009, 12:10 AM   #34
fordcragar
Alliance Member
fordcragar's Avatar
Very cool, thanks!
Old 10-25-2009, 02:04 AM   #35
brucer
Grenade Inspector
brucer's Avatar
also to add on resplining axles, you cant turn down 31 spline axles turning them into 28spline .
you also have to pay attention to what axles you get. alot of the 70's axles have several different diameters on them and you cant just grab an axle and cut it off and start turning on it expecting it to work... you cut the hardness out of the axle making it useless... ive resplined a couple sets of axles and i splined/cut them to fit tight, they still ended up twisting after a couple years of service..
i would recommend just spending the money on good axles if your going to the effort and expense to cut down a rearend you can afford some nice axles..
Old 10-25-2009, 02:21 AM   #36
65stepside
Alliance Member
65stepside's Avatar
once again postin so i can find it later
Old 10-25-2009, 10:17 AM   #37
hotrod32@usfamily.net
Grenade Inspector
Thank you most informative ,I knew it wasn,t rocket science and as she goes measure, measure, measure thanks good post later
Old 10-25-2009, 10:23 AM   #38
fitzee
Old School HAMBer
fitzee's Avatar
Nice post.I take it the hosing was large bearing before? I have shorten a number of housings but never like this. cool.
Old 10-25-2009, 01:02 PM   #39
Paul
Editor
Paul's Avatar
thanks for bringing this one back up!
Old 10-25-2009, 01:41 PM   #40
31Vicky with a hemi
Alliance Member
31Vicky with a hemi's Avatar
thanks
__________________
Thank you, I will be installing a breathalyzer on my keyboard
the hamb relay network
http://www.jalopyjournal.com/forum/g...hp?groupid=214
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
