Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 10-02-2009, 11:54 AM   #61
GOONZ
Grenade Inspector
GOONZ's Avatar
Default Re: Scooped By Moriarity
Here are the pics of my intake. Someone has added a few extra holes. I couldn't find any markings except for on the bottom of the intake and it looks like a 1001. No idea what it means.
C
Click image for larger version
ID:	773193   Click image for larger version
ID:	773194   Click image for larger version
offline   Reply With Quote
Old 10-02-2009, 05:27 PM   #62
MEDDLER1
Senior Member
MEDDLER1's Avatar
Quote:
Originally Posted by goonz View Post
here are the pics of my intake. Someone has added a few extra holes. I couldn't find any markings except for on the bottom of the intake and it looks like a 1001. No idea what it means.
C
you always find the good stuff man!
__________________
WOMEN ARE LIKE USED CARS,YOU JUST HAVE TO FIND ONE WITH A SET OF PROBLEMS YOU CAN DEAL WITH.
VILLAINS CC
online   Reply With Quote
Old 10-02-2009, 11:28 PM   #63
GOONZ
Grenade Inspector
GOONZ's Avatar
Quote:
I get lucky once in awhile, but i need to get it in a driving car rather than one in mock up stage. I think that intake will look good on my LB block, I just have to find some good heads to go with it.
Old 10-25-2011, 02:51 AM   #64
777
Grenade Inspector
777's Avatar
I just happened across this thread while doing research for a new thread I'll be posting The Essential Pre-War Flathead Ford V8 Intake Manifold Guide.
So I'm deep into the Hexagon at the moment and I noticed the original 1935 Hexagons designed by Sullivan for use on the Ted Horn car has a taller fuel pump mounting flange and the boss at the base of the forward carb is a different shape then this one but this one is very similar to the post wars.
Name:	Ted Horns 1935 Miller Ford with Hexagon Sullivan manifold.jpg
ID:	1466993   Click image for larger version
ID:	1466994   Click image for larger version
Name:	Hexagon Tool & Die_2.jpg
Old 10-25-2011, 03:01 AM   #65
777
Grenade Inspector
777's Avatar
Lastly I'd like to put another wives tale to rest. The carbs are not turned around on the Hexagons to compensate for the Millers front wheel drive arrangement. Turning the carbs backwards has no effect on a side pivot float carburetor!
Sullivan did address the float hinge location on the 1934 Bohnalite Special by placing the carbs in line; hence moving the floats pivots fore and aft which in turn negates the centrifugal forces that may have affected float operation.
He did not carry that design over to any of the subsequent designs though and it is believed to have actually created a fuel slosh problem for the forward jets creating a lean condition on those venturis.
I attached a pic of the manifold used on the 34 Bohnalite
Name:	Unknown 2X2 side mounted carbst.jpg
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
