Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Member
To start off,yes I did search and couldn't find an answer to the problem I'm having. I read all of the posts and found the proper wiring diagrams for a 3 wire 10si.
I installed a new alternator (3 wire internal regulator) in my '62 comet. I wired the main lug on the alternator directly to the battery cable side of the ford starter solenoid. I jumped post 2 from the 2 post connector to the main lug on the alternator. I've tried connecting the 3rd wire (post 1 on the alternator) to 1.) load side of the ignition switch 2.) The ignition post of the starter solenoid and 3.) the main lug on the alternator. All of these produced no change. This is what's happening.... I'm only getting 12.5 volts as shown on my new voltmeter and confirmed with my multimeter. Once in awhile, it will register around 14 volts, but if I shut it off and restart it shows 12.5 again. If I disconnect everything from the alternator, I read about 18 volts at the main lug on the alternator. Because of this, it seems that I have a voltage sensing problem. Any of this make sense? What am I missing? Or is the regulator bad in my new alternator? Thanks in advance Mike |
#2 |
Old School HAMBer
1) Wire from #2 terminal should go to the battery + or to the battery + side of the starter solenoid. This will sense the voltage at the battery, not at the alternator output.
2) Wire from #1 should go to a diode (striped or cathode end) or idiot lamp then the other side of lamp or diode to ignition terminal of ignition switch. By doing this it will prevent run-on when ignition switch is shut off. The other two terminals you mentioned are NOT what to do. 3) You may want to check your main lug wire to starter solenoid. This sounds like an intermittent connection. Remember to make this at least #12 gauge stranded wire. Hope this helps
__________________
Dual range hydros rule! ![]() Wise man say to 53 Olds with Dynaflow owner: SHIFT TO LO & GO!
#3 |
Senior Member
The 3rd wire should be hooked up to a gauge or light to make the alt work. The 2 pin connector with red/white wires, the red to the pos post on alt and the white wire is the 3rd wire , sounds the the rest is wired ok.
d2 types faster than I do, def need the diode.
__________________
Vintage Drag Meet Meltdown Drags-Byron Il July 20-21 2013 |
#4 |
Alliance Member
So if I understand right, the third wire (post 1) should feed the voltmeter and everything should be ok? I will add a diode if it runs on, but I want to get it operating and charging properly first. Also, that's the first time that I've heard that the wire from post 2 should go to the battery and not hook to the main alternator lug. I'll try that.
any other input? thanks Last edited by mikew; 08-25-2009 at 09:01 AM. Reason: grammar |
#5 |
Senior Member
May I throw in a question?
If you have the alt main lug wire going to the bat cable starter terminal on a Chevy application, would lug #2 to the main lug also be correct?
__________________
Custom and performance driveshafts built here. Axiline equipment, quality concious builders. For most folks, common sense really IS rocket science. |
#6 | |
Old School HAMBer
Quote:
__________________
#7 |
Alliance Member
What is the right model or rating of diode to get at radioshack?
#8 |
Grenade Inspector
Sounds like a bad regulator to me
#9 |
Alliance Member
Thanks for the delcoRemy link, I'll check that out.
I read somewhere else last night that I can connect both wires (1 and 2) to the main lug and connect that to the battery, and it will act like a 1 wire alternator. Is this BS? I tried it last night and nothing happened. |
#10 | |
Old School HAMBer
Quote:
__________________
#11 |
Alliance Member
__________________
HAMB dealer for Rebel wiring products. 10%discount to all HAMB members http://www.jalopyjournal.com/forum/s...d.php?t=614260 |
#12 |
The Red sense voltage is how the regulator senses voltage.
In a 1 wire it goes to the batt terminal. In a 3 wire it can compensate for voltage drop in the charging wire.
#13 |
Alliance Member
whats an alternator?
| Thread Tools | |
| Display Modes | |
