Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 08-21-2009, 04:59 PM   #1
Drive Em
Senior Member
Default Tube Notching 101:
There may come a time when you need to notch a piece of tubing or pipe. Most will use this knowlege towards the installation of a roll bar or cage in their car. Here are three methods that I use to do some notching:
The first is the chop saw method, and it requires no notcher at all. It does require a little practice, and it is the method that is most like art. What you do is set the chop saw vise at a 45 degree angle, and cut the corner of the tube off, flip it 180 degrees, and cut the other corner off. You end up with two notches that require a little massaging with a file or disc sander to be a perfect notch.
With the chop saw vise set at 45 degrees, the piece of tube is set in the vise and clamped in place:
The corner of the tube is cut off and you now have one half of a notch:
The tube is now flipped 180 degrees. If you are making a straight 90 degree notch, you will position the tube exactly like the first cut, if it is an angle cut, you will set the tube in a little further in the vise so you are cutting off more of the tube. This is where the art part of it comes in as it takes a while before you know how much to cut off for angle cuts:
Here is the tube before deburring:
And here is the tube after deburring with a disc sander:
Just in case you think you cannot make accurate notches with this method, here is the notch and a piece of tube that it will weld to showing no gap at all. This is the method I use the most including chrome moly TIG welded cages:
The next method is by using a common hole saw tube notcher that several vendors sell. This one is made by Dale Wilch, and has been used thousands of times. I do not use a drill press as I have found that most of them do not have a slow enough low speed, and you end up tying up the drill press. I mount the notcher on the corner of a sturdy table and I power it with a variable speed 1/2" drill:
Here is the notcher and the drill used to power it:
The tube is held in place with a horse shoe shaped piece of strap, and will accomodate tobe sizes from 3/4"-2". It will also notch square tubing:
For straight 90 degree cuts, the tube is set to zero with the adjustable tube holder:
Any angle from 0-50 degrees can be cut by adjusting the tube holder:
The drill is turned on and the holesaw and the arbor that holds it are fed into the tube slowly until the notch is made. You want to notch the tube with the same size hole saw that the tube will weld to, in this case a 2" hole saw was used. A little cutting fluid will prolong hole saw life:
You end up with a nice notch that will need a little tune up:
This notcher works extremely well and the variable speed drill lets you control the feed and speed. The only modification I made to mine was to replace the bronze bushings where the arbor rides with needle bearings as the bronze bushings will only last a few dozen notches:
The last method is a version of the hole saw notcher except that I chucked up the arbor and hole saw in chuck of my lathe, and the tube holder is mounted to the carriage of the lathe. This allows me to use the power of the lathe motor, and more angles than the 0-50 degree range of the notcher.
Here is the lathe setup:
The feed on the lathe is used to feed the tube into the spinning hole saw:
Angled notches are done by moving the tool post holder, this one is set at 22 degrees:
[IMG]http://i45.photobucket.com/albums/f88/tommyzees/tubenotching007.jpg
offline   Reply With Quote
Old 08-21-2009, 05:05 PM   #2
Dreddybear
Old School HAMBer
Dreddybear's Avatar
Default Re: Tube Notching 101:
Dude! Great thread!
Old 08-21-2009, 05:28 PM   #3
DCLXVI
FNG
Thanks man!
Great lesson.
Old 08-21-2009, 05:35 PM   #4
exwestracer
exwestracer's Avatar
The first method can also save you a little of that expensive 4130 tube and a lot of time. If you use the same method with a hand grinder and cutoff wheel, you can cut 90deg notches at the same time you cut the tube off. Just mark where you want the bottom of the notch to be and cut the angles from there to the center of the tube. The next notch only requires cutting back along the "ears" that were left from the previous cut. The only scrap is 2 small slivers of tube for each cut.
__________________
BE-yond YOU-nique Interiors, for top quality traditional upholstery styling. In the HAMB-o-Dex.
Old 08-21-2009, 10:40 PM   #5
dannyuscg
FNG
dannyuscg's Avatar
This is a good link to a calculator if you can't afford a notcher. Just print it out and trace on the tube and cut.
http://metalgeek.com/static/cope.pcgi
Danny
Old 08-22-2009, 01:00 AM   #6
fiftyv8
Senior Member
fiftyv8's Avatar
Great thread, Id like to see more threads like this from guys who have a good knowledge to share.
__________________
THE MORE YOU LEARN, THE MORE YOUR REALISE YOU DONT KNOW!
Old 08-22-2009, 01:35 AM   #7
striper
Alliance Member
striper's Avatar
I like the lathe version especially. Haven't seen that one before. I really need to get more creative with my lathe.
__________________
How to build an avatar like mine
http://www.jalopyjournal.com/forum/s...d.php?t=282490
Old 08-22-2009, 02:26 AM   #8
Hilo hotrodder
Alliance Member
Hilo hotrodder's Avatar
What he said .I never thought of using the lathe I can finally cut at the right speed .
Old 08-22-2009, 02:38 AM   #9
Docco
Grenade Inspector
Docco's Avatar
Awesome tech thanks.
Old 08-22-2009, 02:52 AM   #10
35mastr
Alliance Member
35mastr's Avatar
Now thats some good tech. Another lesson learned.
__________________
George
Old 08-22-2009, 03:45 AM   #11
Gasolinedeniz
Gasolinedeniz's Avatar
great post thanksd a lot ,this link http://metalgeek.com/static/cope.pcgi is also a big help
__________________
Rebel Wire, American Made Harnesess
www.rebelwire.com
Old 08-22-2009, 04:13 AM   #12
Warpspeed
Grenade Inspector
Great thread !!!
I had not though of using a lathe for this either. Great idea, and thanks...
Old 08-23-2009, 11:28 AM   #13
Drive Em
Senior Member
Bump for the Sunday morning crew.
Old 08-23-2009, 01:17 PM   #14
Mark H
Senior Member
Mark H's Avatar
I've used the chop saw method in the past with varying degrees of success(i.e. I usually make an arse of it!).
Recently bought a lathe so I'll try that method next time.As others have said,I wouldn't of thought of that.
Great tech,thanks.
__________________
'29 Roadster Pickup Build Thread
http://www.jalopyjournal.com/forum/s...d.php?t=405109
Old 08-23-2009, 01:38 PM   #15
FiddyFour
Old School HAMBer
FiddyFour's Avatar
tech-o-matic!!!
__________________
Quote:
Originally Posted by D.W. View Post
You wanna build a car but you can't even build a fucking sentence?
Old 08-23-2009, 02:50 PM   #16
HOTTRODZZ
Grenade Inspector
HOTTRODZZ's Avatar
Very Cool - nice job.
Just one question,
On the Lathe set up - you have the mandrel & hole saw sticking out of the chuck pretty far -
Does it move around on you..?
If you could set the hole saw closer into the chuck wouldnt it be alot more ridgid set up..??
__________________
Rich Pauza
PAUZASFD Inc
Fabrications - Restorations - Recreations &
HOT RODS with RACE CAR DNA
Old 08-23-2009, 03:24 PM   #17
Ted H
Alliance Member
DRIVE EM,
Thank you very, very much. I will eventualy be building a cage for my jalopy racer Model A sedan and this will save me a ton of time!
Ted
Old 08-23-2009, 03:37 PM   #18
HomemadeHardtop57
Senior Member
HomemadeHardtop57's Avatar
that's using your noggin!
Old 08-23-2009, 04:36 PM   #19
Drive Em
Senior Member
Quote:
Just one question,
It doesn't move at all. I mount the hole saw this way because when you start doing angles, it gives you more clearance.
Old 08-23-2009, 05:36 PM   #20
Hot Rod Packard..
Hot Rod Packard..'s Avatar
Very neat set up. With the lathe set up to make the cuts, you could make a new arbor out of 1 or 1-1/2 round stock. This set up would not move, depending on the carriage feeds you could feed this as well and take alot of work out of notching.
Super info man.! A+
__________________
BRIAN.
Member of the HOTROD magazine cover car club. Feb 2010
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
