Reply
Thread Tools Display Modes
Old 08-05-2009, 01:14 PM   #1
hotroddave
FNG
hotroddave's Avatar
Default 40 front axle suicide on a 23T
Trying to figure out the front end? i have a set of split 40 bones and the axle, spring, to the tires. what i am trying to figure is how to set it up on my 23 T. the spring is in front of the axle. and i need it atop the axle any bolt ups? or should i build new hangers
offline   Reply With Quote
Old 08-05-2009, 01:15 PM   #2
onlychevrolets
Senior Member
onlychevrolets's Avatar
Default Re: 40 front axle suicide on a 23T
if you want a spring over the 40 is an inch and half to wide.
__________________
Plus tax , title , and your old recap-able tire
Old 08-05-2009, 02:00 PM   #3
hotroddave
FNG
hotroddave's Avatar
what would you suggest I use? i have these parts and can mount as is, it will work however it will be ugly.
Old 08-05-2009, 02:25 PM   #4
Rootie Kazoootie
Old School HAMBer
Rootie Kazoootie's Avatar
Posies sells a spring for the 40 axle for the spring over #1009
Old 08-05-2009, 02:32 PM   #5
trad27
trad27's Avatar
Why not leave the spring in front? Its not necessarily ugly its just not something your used to seeing. It lowers the car an extra 2", traditional, and alot easier to set up if thats the parts you got. Im running it on my T with no problems and love it, pm me if you want pics or questions on my set-up. just my 2 cents.
Old 08-05-2009, 03:00 PM   #6
G V Gordon
Old School HAMBer
G V Gordon's Avatar
I used a '46 axle under my A with Speedway long perches and had a mainleaf made for $50. Cut off the stock perches and cleaned them up with a grinder. Worked fine.
__________________
Vagabonds / Oklahoma
www.vagabonds.cc
http://www.pinheadlounge.com/gvgordon
Are fake bull scrotums on Chrysler produced pickup trucks considered "Dodge Balls"
online   Reply With Quote
Old 08-05-2009, 03:03 PM   #7
NortonG
NortonG's Avatar
Quote:
That is exactly how it's done.
Norton
__________________
Home built, Simple, Traditional Hotrods and Customs.
Old 08-05-2009, 03:18 PM   #8
Atwater Mike
Old School HAMBer
Another way is to use hangers welded to the insides of the wishbones, 2.5" behind the axle. Hang the flattened '40 spring between, using the '40 shackles. Prune the front overhangs from the wishbones and smooth them, Voila! "Rat Rod Suicide"!
See lots of them like this at Billetproof...It's an old idea seen years ago at the Dry Lakes. (quick lengthening of wheelbase)
__________________
Mike in Atwater
Old 08-05-2009, 03:51 PM   #9
Shaggy
Old School HAMBer
Remember, that when you split the bones on a '40 axle it kills your turning radius, it is good to kick in your bones in so the tire doesnt hit them because unlike a 32 axle there isnt a lot of beam 'tween your bone and spindle
Old 08-05-2009, 06:54 PM   #10
F&J
Old School HAMBer
Quote:
X2 what he said. Tuck the back ends under the car as much as you can. Cars that don't steer enough are a pain
Old 08-07-2009, 01:27 PM   #11
hotroddave
FNG
hotroddave's Avatar
Wow thanks for the info, as far as the bones i bought the whole mess already split. the guy had it under a sprite, I have no idea why. but they are split about 8 to 10 inches up the bones that way they are about 26" wide.
Old 08-07-2009, 04:37 PM   #12
hotroddave
FNG
hotroddave's Avatar
here are the parts and the project,
Click image for larger version
ID:	727228   Click image for larger version
ID:	727229   Click image for larger version
Old 08-07-2009, 04:40 PM   #13
trad27
trad27's Avatar
yeah you wont have trouble with turning radius with the bones like that. looks good
Old 09-11-2009, 04:19 PM   #14
hotroddave
FNG
hotroddave's Avatar
Now how should I mount the front spring? perch over or under the spring?
__________________
Groucho marks once said "i wasn't kissing her, I was wispering in her mouth"
Old 09-11-2009, 04:45 PM   #15
hotrodfil
Senior Member
hotrodfil's Avatar
Here y'go - 24T, spring in front, '39 axles and wishbones. Split slightly - hope that helps?
__________________
"Tradition is a guide and not a jailer." W. Somerset Maugham
My '27 Mercury..Monkeybiker no more..
Old 09-11-2009, 05:19 PM   #16
rusty28a
Alliance Member
rusty28a's Avatar
Those pics have got my blood boiling! Go for it Hotroddave!
Old 09-11-2009, 05:34 PM   #17
NortonG
NortonG's Avatar
Quote:
I like them under. I think they're safer that way.
Other people may think otherwise.
Check out the pics in my build thread.
http://www.jalopyjournal.com/forum/s...d.php?t=266975
This is just how mine has been done.
LOTS of other ways of doing this.
Norton
__________________
Old 09-11-2009, 06:07 PM   #18
Alliance Member
Mr48chev's Avatar
I had to do that on my 23.
Take a look at a front spring out from under an F-1 Ford pickup. I think that is what I ended up using on my T. I may be off as I ended up swapping in a drilled axle that I got from a club member back then but I think the distance on the pins was the same as the other axle.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 09-14-2009, 01:06 AM   #19
hotrodfil
Senior Member
hotrodfil's Avatar
Plenty of turning circle left with my slightly split '39 bones...
__________________
Old 09-25-2009, 06:56 PM   #20
hotroddave
FNG
hotroddave's Avatar
tanks for the insight i will get some pics up to show progress once completed.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
