Reply
Thread Tools Display Modes
Old 08-02-2009, 09:19 PM   #1
Kevin Lee
Super Moderator
Kevin Lee's Avatar
Default Anyone know how much pressure those "bomber oxygen" tanks can safely hold?
I have a couple in good shape but the labeling is long gone. Thinking I'm going to use them with a compressor so I can have enough air in my shop to run the occational air tool and of course inflate tires.
Assuming someone here has one with the labels in tact with a psi rating.
__________________
Learning the hard way since '72
offline   Reply With Quote
Old 08-02-2009, 09:24 PM   #2
35ratbstr
35ratbstr's Avatar
Default Re: Anyone know how much pressure those "bomber oxygen" tanks can safely hold?
Kevin,
I dont think it is worth the chance. Think about the damage it could do when you can probably find one for under $500.
__________________
Rules..... Guide lines for Gray areas
Old 08-02-2009, 09:30 PM   #3
Engine Pro 5X
Old School HAMBer
Engine Pro 5X's Avatar
I have a cat that works for me and he has all of that crazy knowledge stored in his melon !! He has told me before but I never remembered, but I do know his comment was to not worry about my air compressor ever blowing one up >>>>.
__________________
GET IN THE TRUCK JETHRO!!! WE'RE GOING TO CALIFORNIA!!! SWIMMING POOLS!!! MOVIE STARS!!!***CAN I SHOW YOU MY BEST KIELBASA ???
Old 08-02-2009, 09:31 PM   #4
plym49
Old School HAMBer
plym49's Avatar
Not to worry. Your shop air is maybe 150 psi tops. Those tanks held like ten times that.
Old 08-02-2009, 09:41 PM   #5
tbraginton
Grenade Inspector
tbraginton's Avatar
What size tank are you talkin I've got a little guy but it wouldn't hold much air to be useful. You never know what the inside looks like even if the outside looks good... PSI will do some major damage if it gets loose
Old 08-02-2009, 09:54 PM   #6
SUHRsc
Alliance Member
SUHRsc's Avatar
mine are all the normal size that you see in cars and all say the same thing on them
__________________
www.zachsuhr.com
WANTED
Early DIVCO - any condition
Old 08-02-2009, 09:57 PM   #7
plym49
Old School HAMBer
plym49's Avatar
Those are just fine for the pressure of shop air. However, their volume is too small to do much with, except maybe for cleaning spark plugs or an air brush.
Old 08-02-2009, 10:23 PM   #8
CoolHand
Alliance Vendor
CoolHand's Avatar
What you need to do is find a clapped out air compressor and steal the tank off of it.
I've got a compressor with a 150 gal tank on it, and that runs directly into another 250 gal tank off a long deceased industrial machine that I happened across many years ago.
I can run an air grinder for about 15 mins before my compressor kicks on.
Now, when it does kick on though, it runs for a while.
__________________
Ryan Shanks
Logic Industries LLC
"Our freedom is not for sale, and we reserve the right to defend it from theft." - Doc Zero
Stainless Lincoln Style Door Buttons - Now in Stock!
Old 08-02-2009, 10:30 PM   #9
Weeks46
Alliance Member
Weeks46's Avatar
Did somone suggest an old tank? Go to post 129.-Weeks
http://www.jalopyjournal.com/forum/s...light=blown+up
__________________
BANGER ?(S) ANSWERED = http://www.jalopyjournal.com/forum/s...d.php?t=161498
Old 08-02-2009, 10:45 PM   #10
patrick2965
Senior Member
patrick2965's Avatar
Hey Kevin,
One thing I saw some dirt trackers doing was to use a nitrogen bottle, like you run of the mill Ox/Acet bottle, with a regulator. Don't pull the trigger on your impact to make noise, only work.
440RR, oh SHIT!!!!!!!!!!!!!!!!!!!! Glad I wasn't there!!!!!!!!!!!!!!!!
__________________
Custom and performance driveshafts built here. Axiline equipment, quality concious builders.
For most folks, common sense really IS rocket science.
Old 08-02-2009, 11:08 PM   #11
CoolHand
Alliance Vendor
CoolHand's Avatar
Yeah, that's why you pay attention, and have them inspected, just like every other pressure vessel you work with.
I was born at night, but not last night.
Why must everyone here assume that everyone else is stupid and/or inept?
__________________
Ryan Shanks
Old 08-03-2009, 09:16 AM   #12
Kevin Lee
Super Moderator
Kevin Lee's Avatar
Thanks, Zach.
__________________
Old 08-03-2009, 09:22 AM   #13
Ole don
Alliance Member
Ole don's Avatar
Location: Southern Illinois half way between Benton and DuQuoin
What do those military tanks weigh? They look to be aluminum, are they?
Old 08-03-2009, 09:48 AM   #14
Kevin Lee
Super Moderator
Kevin Lee's Avatar
Stainless.
__________________
Old 08-03-2009, 10:26 AM   #15
ems customer service
Senior Member
ems customer service's Avatar
here-s how you do a home test.
1: flll it with water
2 then pressureized it to as high as you can go , if a crack does burst then the danger of hgh pressure air is minimized,
3. but the bomber tanks are really to old i would tak it to a welding supply store to check how much they would charge to hydro test it.
Old 08-03-2009, 10:29 AM   #16
Senior Member
as for a portable power tool, i use a cordless milwaukee impact (275 ft/lbs) does every thing but inflate tires.
Old 08-03-2009, 10:40 AM   #17
budd
Old School HAMBer
budd's Avatar
a couple of days ago i saw a new 60 gallon tank for sale for $280, it was a heavy duty looking tank, must of been ment for a 10 hp setup, doesnt help you but that tank would last a lifetime, a little hunting and i bet you could find something much the same in your area.
Old 08-03-2009, 11:19 AM   #18
InDaShop
Old School HAMBer
InDaShop's Avatar
no doubt a bomber tank will take 400psi easy.
Get it tested but I bet it will hold the same today as it did in 1942.
of my tank collection I have two that were used as bouys in a lake for 20-25 years. They looked new after getting the mineral crude off the outside.
Old 08-03-2009, 12:39 PM   #19
Winterbear
Newbie
Winterbear's Avatar
Are they all stainless? The one I found in a old dump seems to be rusted pretty badly.
Chris
__________________
1932 chrysler coupe parts are hard to find.
The squirrels in my head have knives!
Old 08-03-2009, 01:16 PM   #20
hammeredabone
Kev, Just a thought, if the label is missing will your home owners insurance cover a non labeled pressure vessel? At work our insurance carrier wants to see our ASME
rated pressure vessel data plates. If you do go this route make sure you use a relief valve on the tank lower than the rating of the tank.
BTW, the coupe is looking extremely BADASS!!
Gordon
Old 08-03-2009, 03:09 PM   #21
KeithDyer
Grenade Inspector
KeithDyer's Avatar
Being off a bomber it should be aluminum, not stainless I would think.
And saying it will handle 400 psig, that might be higher here on the ground than at altitude.
Would still fill with water and do a hydrostatic test, we test new pressure vessels at 1.5 or 1.3 times working pressure in most cases.
A controlable argon or nitrogen line will give you the pressure to test it with, but you need to be careful and pay attention to the set up.
Water is only about 4% compressable so a failure will not equal an explosion.
Figure it will fail, secure the tank and pressure line so it won't hurt anybody (air/gas space to the top), then be happy when it stays.
K
Old 08-03-2009, 03:11 PM   #22
jdubbya
Alliance Member
jdubbya's Avatar
Quote:
It is stainless for sure
__________________
Just keepin' it real for my homies!
Old 08-03-2009, 03:17 PM   #23
InDaShop
Old School HAMBer
InDaShop's Avatar
Growing up one of these was my Grandfathers airbubble. God I hated having to go get it and drag it around the yard. Freaking heavy SOB's!!! Not even remotely a chance at being aluminum.
Old 08-03-2009, 03:50 PM   #24
CoolHand
Alliance Vendor
CoolHand's Avatar
. . . . . And saying it will handle 400 psig, that might be higher here on the ground than at altitude. . . . . .
It will be . . . . by up to 14.7 PSI at sea level.
Not digging on you at all, just pointing out that atmospheric pressure is not high. Even if you made it out into space (absolute pressure = 0 PSI), you'd only have to support a pressure difference of ~15 PSI.
Being in a vacuum is very hard on people (being somewhat squishy and quite stretchy), but easy on pressure vessels.
To the OP - Whatever vessel you intend to use, just have it hydro tested to the standard factor of safety for whatever medium you intend to contain, and be at ease.
That's all there is to it.
Testing = Knowing
__________________
Ryan Shanks
Old 08-03-2009, 03:56 PM   #25
Kevin Lee
Super Moderator
Kevin Lee's Avatar
I actually have two of them and again, they are stainless.
And if anything pressure is going to be higher at altitude than on the ground, right? But lucky for me I will never load my air compressor into a bomber to go flying.
__________________
Old 08-03-2009, 06:49 PM   #26
sodbuster
Old School HAMBer
sodbuster's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=90234
hotrod magazine has a 20% off coupon, typing with one hand....haha....baby in the other
__________________
A Devil with A Hammer & Hell with A Torch
Old 08-03-2009, 07:21 PM   #27
patrick66
Old School HAMBer
patrick66's Avatar
Location: Oklahoma, where the wind comes sweeping down the plain!
Those old aircrew O2 tanks will safely hold up to a MAX of 400 PSI. The modern aircrew tanks also hold a max of 400 PSI, though the design is slightly different. They are DESIGNED for that pressure, at altitudes from sea level to as high as 41K feet. Air expands as you gain altitude.
The term "bomber tank" is misleading. They are simply "aircrew O2 tanks", as all US military aircraft have had them, or currently carry them.
I'm retired USAF aircrew, so I've had years of experience flying around with these bottles.
Have that tank tested, as recommended above, before you apply it to your project.
__________________
Screw with your neighbors...name your Wi-Fi network "NSA Surveillance Van #6"...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
