Reply
Thread Tools Display Modes
Old 07-14-2009, 11:05 AM   #1
grobb284
Newbie
Default Questions on difference of water temperature within the Chevy small block.
How large is the temperature gradient across a small block chevy with cast iron heads? The reason I ask, we are using an aluminum air gap intake, that has four access points to the circulating water, one in each corner.
The sender for the gage was at the passenger side front nearest the thermostat. The temperature switch for the electric fan was at the drivers rear corner of the intake. The 190 degree fan switch came on at 215 according to the gage.
We then reversed the locations, putting the gage sender at the rear of the intake on the drivers side, the fan switch at the front of the intake on the passengers side (common with the thermostat). This time the reading was 185 when the fan switch came on.
I was surprised that an aluminum intake would have that much difference in temperature with the water circulating. I am confident the fan switch is repeating with consistency the temperature trip point, it's just that the water is much hotter at the thermostat.
Anyone have some detailed information on the temperature differential at different locations of the water circulating the engine?
offline   Reply With Quote
Old 07-14-2009, 01:03 PM   #2
ride00007
FNG
Default Re: Questions on difference of water temperature within the Chevy small block.
This is a good question. I've often wondered where the best location for my sending units actually are. My temp sender is in the head... I'm not sure that's the best place.
Wherever the sender is... it's just a quick picture of what's going on. Not sure which area is the most critical to observe and which is the hottest. I'm guessing there are a lot of variables that affect that.
Old 07-14-2009, 01:28 PM   #3
el Scotto
Old School HAMBer
el Scotto's Avatar
I wondered this before, as well! There's a kit in the Speedway Track Catalog for directing water to a spot between the two rear cylinders, a buddy of mine says there is a hot spot there.
We always wondered the difference between water temps at the manifold and at the factory temp sending unit in the head, too. Seems like it'd be much hotter near the combustion chamber.
__________________
waywardgarage
Hey, careful, man, there's a beverage here!
Old 07-14-2009, 01:37 PM   #4
KJSR
Senior Member
KJSR's Avatar
I would like to know as well. I have a fan switch on the right side that will activate the fan at low temps (150-160) displayed on my gauge. The switch is in between the rear cylinders and the gauge sender is on the left side between the front cylinders. The real issue with mine is over cooling in the cooler seasons. I think I will swap them and see if it gets better...
__________________
1936 Chevrolet 1/2 ton
1937 Plymouth P4
1964 Chevrolet 1/2 ton
Old 07-14-2009, 02:01 PM   #5
sdluck
Senior Member
Howard Stewarts (sp)web site has some good info , small blk chevy water pumps are not all created equal, the don't flow water the same to both sides,also cylinder 5 and 7 are next to each other in firing and tend to build more heat on that side.
Old 07-14-2009, 02:04 PM   #6
four-thirteen
Senior Member
Most of the heat removed from an engine comes from the cylinder heads. I would fully expect there to be a 30F degree or more difference in the water entering the heads and the water leaving the heads.
The only good way to measure coolant temperature is after its done its job removing heat from the engine and while its on its way to the radiator.
Old 07-14-2009, 02:17 PM   #7
Old School HAMBer
squirrel's Avatar
30 degrees sounds reasonable.
The aluminum intake can't affect coolant temperature front to back....how could it?
__________________
Jim Forbes
my shtuff
Old 07-14-2009, 02:20 PM   #8
oj
Alliance Member
oj's Avatar
I have felt that water dosn't actually flow thru the engine, heat gets transferred from hottest to coldest (very quickly) by convection. If you stick your finger into the formost water passage port in the head and another finger in the water inlet in the block you can almost touch fingers, and that is where water flows. What i do on the race motors is feed water into the back of the intake manifold and return from the front of the block-the water has to flow thru the head.
If your sending unit turns your coolant fan on & off you might want to put it on the radiator inlet, right in the stream coming into the radiator. That way it can run with the motor shut off and turn itself off when it reaches a temp. If the sender is in the block it won't be able to run on 'automatic' mode because it isn't cooling the engine, it'll just run and run.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
