fuel gauge Ohms
Discussion in 'The Hokey Ass Message Board' started by Jimv, Jun 12, 2009.
  1. Jimv
    Jimv
    I have a fuel gauge that reads from 0-90 ohms(to replacement my old one) The sender that is in my car is a 33-240 ohm one.Is there anyway to run this gauge? Can i got to radio shack & get a resistor or something?
    Thanks
    JimV
  2. can i assume when you say 0-90 ohms you are talking about 1965 and up GM? if so , the 0 is ohms empty and 90 is ohms full
    the 240-33 is Stewart Wanner and 240 is ohms empty and 33 is ohms full. as you can see they work completely opposite of each other...i see no way any resister can fix that . if there is way , please someone tell us . i think the only way to make you fuel gauge work properly is with the correct sender
  3. Shifty Shifterton
    Shifty Shifterton
    Dunno but I think if you run it as-is, it'd work like a fuel warning light. Bout 1/8th tank the needle would start plummeting off full :D
  4. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Its not gonna work, sorry.
  5. RAY With
    RAY With
    Fuel Gauges have always been a pain in the ass for most of us. Just did an auto meter full set of 5 inch gauges and had total hell with the gas sender.Took another 50 + bucks and an additional 10 days to get the Ring "adapter" so the screws would line up. They never tell you about all the additional crap you need to use some of there gauges.
  6. they can be , but i feel it is worth the effort to get an accurate fuel gauge. i'm proud of the fact that the cars i build have accurate fuel gauges and speedometers..i don't want a call from the side of the road from the owner. all you need is the correct ohms range sender properly setup for the depth of the tank, wired correctly and a good ground
    when you say "ring adapter" i assume you mean you have a stock early ford tank with 6 sender mounting holes....yes , you need an adapter to go to the normal 5 bolt. is $50 what they cost now? i think the last one i bought was $15
    new aftermarket replacement tanks from places like Tanks and Vintque usually have provisions for a 5 bolt sender. i've used a couple steel tanks from Bob Drake and they had about 3 bolt patterns
  7. marks914
    marks914
    Alliance Vendor
    Yes, the fuel gauge is always the second question a customer asks, after how to calibrate the speedo. We are working on some programmable fuel gauges so you can run virtually any sender, but its a while out. Faria used to have a programmable sonic fuel level sender that was pretty slick, but they never caught on.
    In short, you will need a new gauge (easier) or a new sender (might be cheaper)
    Mark
  8. BangerMatt
    BangerMatt
    I have a fuel gauge under my seat.
    It's a stick. . . 1 inch on the stick is about 2-3 gallons of gas.
  9. Ian Berky
    Ian Berky
    Interesting all this stuff but what a pain in the A!*#@!!!
    I have 51 chevy stock fuel gauge and a new mustang tank which already has a sending unit. Now, where do i get a different sending unit or do i use a resistor? I've been doing research for the last hour and NOTHING!! Im kinda of in a rush to figure that stuff out because my car is getting rewired right now by a friend and we both dont know what to do.:confused:
    Thanx
    Ian
  10. vertible59
    vertible59
    Been there, done that. The real beauty is, that it works every time and never gives any problems.:D
  11. pinupwithgun
    pinupwithgun
    Where can i get the sender adapter for the ford early tank?
  12. duffman
    duffman
    Ian stewart warner makes fuel guages in all 3 common ohm ratings. Just got one for the mustang tank in my 55. Napa had it in their warehouse for $33.
  13. Ian Berky
    Ian Berky
    Im all over it!! The hamb rules!!
    Ian
  14. chevnut
    chevnut
    from Corona, Ca
    For the less expensive approach, I gutted the old GM Stewart Warner sender and placed it on my new mustang cougar sender. It takes a little tweaking and testing but float works like it was meant for it. I have better pics somewhere. If I find I will post again.
    Peace,
    Chevnut
  15. duffman
    duffman
    my truck is a GMC, so I have the advantage of being able to put a 2 1/16 guage in the factory spot.
  16. 19Fordy
    19Fordy
    These guys sell them. You have to call them as it's not shown in thir parts list. But they do sell them. Cheaper to make your own.
    http://www.yogisinc.com/
  17. Shifty Shifterton
    Shifty Shifterton
    I find the half-empty/half-full analogy really fits well this time!
    If $50 and 10 days is all a problem hangs me up for, I am a lucky man. :D It don't get no cheaper or quicker when it comes to cool cars.
