Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 06-01-2009, 02:37 AM   #1
1oldtimer
Alliance Member
1oldtimer's Avatar
Post TECH WEEK---'47 ford dual pot master install
For TECH WEEK.....
I didn't really put up a full post on my install, so I'll try it now (might be known already, but hope it helps someone). 1947 ford super deluxe, stock pedal assy, stock drivetrain, lincoln brakes dual pot master install. I needed to get the master out from under the floor bracing into a flat spot in the floor. I used a 1968 chrysler car master with the bolt hold down lid because it's short, has res valves in it and is a 1" bore (wagner #F71258). It needed to be 8" from the stock location. Using 3/16" plate and 1/8" thick tube make 2 feet (1 matching the foot of the '47 pedal assy and the other matching the new master). I found a universal master pushrod , both the stock ends threaded into it. Loosely mount the master and new mount, mark the floor, take out the set-up and cut a new access hole in the floor. Install the new pushrod on the pedal, slide the new mount over the pushrod, bolt new mount to pedal assy, bolt new master to mount (I used grade 8 bolts) and adjust pushrod free play. Lastly make a removable cover for the inspection hole. Bend some new lines (chrysler-front pot to rear brakes and rear pot to front brakes), bleed system and your done. I tried to makes this an easy read......hope it comes across ok.
Click image for larger version
Name:	brake master mount-1.jpg
ID:	674200   Click image for larger version
Name:	brake master mount-2.jpg
ID:	674201   Click image for larger version
Name:	brake master mount-3.jpg
Name:	brake push rod-1.JPG
ID:	674203   Click image for larger version
Name:	brake master-7.jpg
ID:	674204   Click image for larger version
Name:	brake master-6.jpg
Name:	brake master-1.jpg
ID:	674206   Click image for larger version
Name:	brake master-2.jpg
ID:	674207   Click image for larger version
Name:	brake master cover-1.jpg
__________________
My mind is aglow with whirling, transient nodes of thought careening through a cosmic vapor of invention.
offline   Reply With Quote
Old 06-01-2009, 10:52 PM   #2
1oldtimer
Alliance Member
1oldtimer's Avatar
Default Re: TECH WEEK---'47 ford dual pot master install
will work for 40-48....
__________________
Old 06-01-2009, 11:15 PM   #3
pasadenahotrod
Old School HAMBer
Great job. Well illustrated, and well thought out.
Old 06-07-2009, 04:11 PM   #4
banditomerc
banditomerc's Avatar
can you add a power booster to it? if so..what year?
__________________
DRIP RAILS ARE FOR SISSYS
Old 06-08-2009, 09:56 PM   #5
1oldtimer
Alliance Member
1oldtimer's Avatar
Quote:
if you made a different foot and shorten the adapter you could, i would use the smallest booster you could find. C.E makes an adapter for a power brake to stock pedal.
http://www.chassisengineeringinc.com/page70.html
AS-2058
__________________
Old 01-17-2010, 02:06 PM   #6
tromollo
Grenade Inspector
tromollo's Avatar
Thanks for the post .I used the same design on my 47 .works great
I used a 1970 mustang master cylinder with front \rear\ drum brakes
I cut a bigger hole in the floor .put a little door there .
http://i827.photobucket.com/albums/z...icture1309.jpg
sill used the factory end on the rod
http://i827.photobucket.com/albums/z...icture1310.jpg
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
