Reply
Thread Tools Display Modes
Old 05-08-2009, 05:39 PM   #1
35PontiacCoupe
Grenade Inspector
35PontiacCoupe's Avatar
Default Drilling Ford 9 Axles to change pattern
I've read some of the threads about drilling 9" axle flanges to change the bolt patterns, and I know there are some people out there that think it shouldn't be done, etc. I've got a pretty good idea of a fixture to make sure everything is indexed correctly but I don't know how close I can make the new holes to the old ones.
I'm going from 5x5.5 to 5x4.5 and the biggest problem is the access hole is right in the way- of course. There were some people who had drilled to 5x4.75 and made it work, but my templates put the holes pretty close to each other.
Basically, I'm wondering how much space needs to be left in between the lug holes to keep it stable. If there isn't enough room, how would a plug work? Would it have to be welded in from the backside?
offline   Reply With Quote
Old 05-08-2009, 05:47 PM   #2
2-TONED
Senior Member
2-TONED's Avatar
Default Re: Drilling Ford 9 Axles to change pattern
i sent some axles over to the local mud bogger machinest here & he welded plugs in & then redrilled a pattern.
i see new currie axles with 2 patterns & the holes are pretty close.
i too would like to hear what others think.
__________________
Raisinhel speed shop.
(raisin hell)
Old 05-08-2009, 06:00 PM   #3
35PontiacCoupe
Grenade Inspector
WHen he welded them in, did he take a slice out of the flange to make sure it wasn't warped?
Old 05-08-2009, 08:28 PM   #4
Old Guy
Grenade Inspector
Old Guy's Avatar
Just did a set from 5.5 to 4.5. Plugged the holes, welded both sides, and resurfaced the flange.The only thing that sucks is that the welds get really hard, which makes it a little tough to drill.
Old 05-08-2009, 08:36 PM   #5
bigolds
bigolds's Avatar
Did them on my 37...welded...resurfaced...milled new holes...used screw in studs....used to beat the livin' shit out of it...no problems!!!!
__________________
Christ, you guys are givin' me a fuckin' headache!!!
Old 05-08-2009, 08:39 PM   #6
1935Ron
Senior Member
1935Ron's Avatar
Been there done that a few times before, I personally had a few issues with balance, after i pluged it.... did not want to spend the bucks to send them to the balancer .... got pretty close (guessing 99%)with a old high speed balancer on the car.
Old 05-08-2009, 08:41 PM   #7
Rocky
Classified Editor
Rocky's Avatar
When I ordered my axle shafts for my 9 inch rearend from Dutchman, they drilled them with 3 different bolt patterns [ 4.5", 4.75" & 5"]and the extra holes didn't void the warrantee. Must be safe.
__________________
My wife says I never listen to her....at least that's what I think she said.
Old 05-08-2009, 08:41 PM   #8
35Chevy.com
35Chevy.com's Avatar
I would just send them to Moser Eng.
Gary
Redrilling Bolt Patterns
To suit your requirements, we can redrill new bolt patterns on most OEM or M/E axles, most one-piece rotors, hubs, and brake drums. (We do not drill Chevy Luv rotors.) See our price sheet for your application, and feel free to contact us if you have any questions!
Axles - redrilling only
$60 pair
Axles - plug & redrill holes
$80 pair
__________________
I think the monkeys at the zoo should have to wear sunglasses so they can't
hypnotize you.....Jack Handy
Old 05-08-2009, 09:24 PM   #9
35PontiacCoupe
Grenade Inspector
Is the balance issue sideways or top to bottom balance?
I know moser doesn't cost a ton but shipping both ways is a pig too..
Rocky- did those axles have access holes in them? How much material is there between the holes?
Old 05-08-2009, 09:31 PM   #10
40streetrod
40streetrod's Avatar
That's what I did well over 10 years ago, many miles with no problems
Old 05-08-2009, 09:35 PM   #11
Dolmetsch
Old School HAMBer
Dolmetsch's Avatar
I just redrilled the new pattern in between . Why weld??????? went from 5.5 to 4.75. Took a morning of measuring and work. Measuring and layout is the key.
Don
__________________
going more fast on less gold
Old 05-08-2009, 09:37 PM   #12
BobbyD
BobbyD's Avatar
Any machine shop that has a indexing head can machine them in a few minutes for any bolt pattern you want, thou it will require machining and welding in a plug for the "access" hole. You can send them to me and I'll do it for you right, PM me if you need my help.
__________________
A "hand out" is what you get from the goverment,
A "hand up" is what you get from a friend.....
Old 05-08-2009, 09:49 PM   #13
fab32
Alliance Member
fab32's Avatar
I send everything to Moser. I have them shorten and respline when necessary, change bolt pattern and install new studs and wheel bearings. I have then send their retainer plates as they are slip on not the captured stock type. When they change bolt pattern they weld up the old pattern
remachine the flange true to the axle centerline and redrill the new pattern and press in new studs. They can put new bearings on for less than 1/2 what it costs to replace them here.
Nice thing about them is they have a 24 hour turnaround. When I send them a pair of axles UPS I have them back in less then a week ready to install. Best service of any aftermarket company I've dealt with.
Frank
__________________
"What we got here is failure to communicate"
Old 05-08-2009, 09:49 PM   #14
Deuce Roadster
Deuce Roadster's Avatar
Ford made a LOT MORE different axles with the 5 on 4.5 pattern than with the 5 on 5.5 pattern.
The 57 to 67 F-100 axle shaft measures 30 inches ( both the right side and the left side ) ... I helped a friend with his project and we used 64/65 Full size Ford axle ... It is 29.5 inches long ... and it has been trouble free for many, many miles. We even used the drums, backing plates and all.
He runs a 460 Ford with a 125 shot of NOS ...
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Old 05-08-2009, 10:06 PM   #15
35PontiacCoupe
Grenade Inspector
Quote:
Don
This is what I want to do. How close were the holes to the access hole/existing holes? I'd rather drill without welding if I can.
Moser is still an option but I'd rather do this myself if possible because I'm cheap and like doing things myself..
Old 05-08-2009, 10:30 PM   #16
2-TONED
Senior Member
2-TONED's Avatar
Quote:
yep he surfaced them. -- he is a very good machinest but he cant get off the mud bog 4x4 shit.
he charged me 70.00 for the pair new studs included.
i wanted mine surfaced. he does alot of 4x4s with the big tires they wouldnt know if the axles were warped or not.
__________________
(raisin hell)
Old 05-09-2009, 10:43 AM   #17
budd
Old School HAMBer
budd's Avatar
i'm think of drilling my axle from 4.5 to 4.75, i would start by placeing them in my lathe and take a little cut/sctarch to give me the correct DIA. then print out the pattern on my office printer and center punch the locations, or i may mill my wheels to except uni-lug washers as they are aluminum.
Old 05-09-2009, 10:52 AM   #18
35PontiacCoupe
Grenade Inspector
How much space between the old holes/access hole and the new lugs is acceptable though? I'm looking at the template that I made with both patterns and it looks like about 1/8" of material in between. I don't know if that's enough- that's really what I'm looking for...
Old 05-09-2009, 11:15 AM   #19
seabeecmc
seabeecmc's Avatar
"How much space between the old holes/access hole and the new lugs is acceptable though? I'm looking at the template that I made with both patterns and it looks like about 1/8" of material in between. I don't know if that's enough- that's really what I'm looking for... "
Ain't it Hell trying to get a straight answer on the H.A.M.B.? Regards, Ron
__________________
Whistling is like masturbation. You may find it entertaining but, NO ONE wants to listen to you do it.
Old 05-09-2009, 11:50 AM   #20
35PontiacCoupe
Grenade Inspector
Yes. Yes it is! I appreciate all the other ideas though!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
