Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
I picked up a T10 at a swap meet today and I wasn't able to get the details since it came out of a t-bucket. I would like to know what it came from, if its a mixture of parts, and what the gear ratio is, also if someone can confirm that if i change the bell housing it will fit a pontiac.
I know it was behind a 60's ford The input shaft is 10 spline output is 25 Cant read the date plates yet but I can read the following Case Passenger side: T10H-1 W.G. DIV W-1 Case Cover on Driver side: (its a 9 bolt cover) T10-148B W.G. DIV Tail Shaft: T10 H-7A W.G. DIV W1 So I am pretty sure the case is 60's ford, I even read that it came on a rare 427 I believe the tail shaft can be 58-59 Vette 59 chev Pass and it has a CompetitionPlus Hurst shifter Last edited by Kail; 04-27-2009 at 07:51 AM. |
#2 |
Old School HAMBer
It looks like the one I have in my coupe. It's from a Falcon Sprint. The shifter location is unique to that application.
#3 |
Senior Member
If that is a shift lever behind the shifter mech in the tail shaft it's a T-10.
#4 |
Old School HAMBer
Early 1964 and before Ford products had a different bolt pattern.That one looks to me like it has the bolt pattern that fits the early and late bellhousings.It also has the short tailshaft so I think just dug is right.I think its a Falcon or Comet or Fairlane.A Galaxie had a long tailshaft.
__________________
I'm just an analog guy trying to make it in a digital world. |
#5 | ||
Quote:
Quote:
#6 |
Old School HAMBer
The two bolt patterns on the trans are both Ford patterns.One is the old style and the other is the newer one.I don't know for sure,but I thought the Pontiac used the Chevy pattern.If its true,then there are adapters you could use to mount the Ford to GM bell.
__________________
#7 |
FNG
If it has a 25 spline output shaft it is a vary early Mustang. They changed them to 28 spline later.
| Thread Tools | |
| Display Modes | |
