Reply
Thread Tools Display Modes
Old 04-24-2009, 09:50 AM   #1
Duke
Default Building A Hand Held Planishing Hammer
I just picked up a set a of CP lower dies made by Hoosier on e-bay and plan on building a hand held planishing hammer. My thought is a tube frame, air hammer and a flat rivet head for a top die. I have some questions for those who have built these before:
1. I want to make the frame light, but if it is too light it won't be good- any recomendations on frame material- I was thinking 3/4 heavy wall tube??
2. Air hammers- what BPM should I look for?
3. Upper die- is a rivet head good enough or should I spring for the hoosier upper die? (I think it is around $80).
4. Throat size- how deep should I make it? I plan on using this to work on my 34 coupe with extensive roll over roof damage.
5. Lower die holder- what material should I make it out of so my dies don't get stuck in it?
If you have not seen the hoosier dies, check them out, they look nice!
offline   Reply With Quote
Old 04-24-2009, 10:13 AM   #2
budd
Old School HAMBer
budd's Avatar
Default Re: Building A Hand Held Planishing Hammer
heres one, might give you some ideas, http://allshops.org/cgi-bin/communit...=9980294362382
Old 04-24-2009, 10:21 AM   #3
Tman
Old School HAMBer
Tman's Avatar
The antique one I got to play with had a frame of about 2 1/4' tubing, it actually had three with different throat depths. You just swapped them out when needed. I think the one that was in the machine the most had an 18" depth.
__________________
www.compulsionrodandcustom.com New website up! Product listings updating weekly!
Old 04-24-2009, 10:22 AM   #4
John_Kelly
John_Kelly's Avatar
Hi Duke,
I made mine from 1/2" square tubing bent to fit. A 4X rivet gun and steel tubing for the die holder and riveter sleeve. It is flexible which is handy for lumpy work. You squeeze it together to stretch or smooth where you need more pressure. An inline regulator is a must. You might want to make several frames. The longest one should use heavier material and the shorter one like mine would be light weight. Picture attached. You can see it in action in my youtube videos below: CMB #2 if I remember right.
John www.ghiaspecialties.com
Click image for larger version
Name:	Library - 019.jpg
ID:	646480   Click image for larger version
Name:	Library - 109.jpg
__________________
Metal Shaping and Dent Repair videos:
http://www.youtube.com/profile?user=...nn&view=videos
Old 04-24-2009, 10:38 AM   #5
scootermcrad
Alliance Member
scootermcrad's Avatar
I always thought it would be really cool to have one of these! Good idea!
Always thought a handheld english wheel would be helpful as well!
__________________
Like early Hemis? Click the banner below...
My blog:
scootermcrad.blogspot.com
Old 04-24-2009, 11:14 AM   #6
Duke
Thanks for the info so far guys. I like the idea of several frames. What is the main difference between using a 4X rivet gun and a quality long barrel air hammer? I can buy an air hammer local, but I will need to find a rivet gun online.
Thanks
Old 04-24-2009, 11:38 AM   #7
John_Kelly
John_Kelly's Avatar
Hi Duke,
The riveter has a teasable trigger making it a slightly more variable at the trigger.
Jim Bailie said something to the effect of not needing a riveter, that an air hammer works just fine. If you search his albums on metalshapers.org you will probably find something about it.
I do like the teasable trigger on my riveter, but most of the variation in hit strength, and rapidity is done with the regulator.
__________________
Old 04-24-2009, 12:55 PM   #8
beaulieu
Grenade Inspector
beaulieu's Avatar
the larger riveters also use a larger shaft ,
the small zip guns use a .401 shaft ,
so if you already have dies make sure you match them
Beaulieu
__________________
WTD:356 Porsche project ,anything considered ,rusty ,crashed, incomplete OK+Fiat 500-600+Citroen van
Old 04-24-2009, 01:13 PM   #9
Slide
Old School HAMBer
Slide's Avatar
FWIW, I just picked up a used 4x CP rivet gun, and I've had some success shaping sheet metal by just using the rivet gun in my hand and a dolly for the anvil. I even rounded off the head of an 8# sledge hammer, clamped it in my bench vise, and used that like a post dolly.
For the rivet set (The "bit" you put in the rivet gun), I'm using a flush set, which has a round (about 7/8" dia.) flat surface not unlike the business end of a good body hammer. (Very much like the one in John's photos above.)
I like the rivet gun's teasable trigger. I'm just learning how to use the thing, so it's nice to be able to go a little slower.
One other nice thing I've discovered is that you can hammer off-dolly using this method.
I still have thoughts of making a frame, though.
__________________
Just because you can doesn't mean you should.
www.mikeshoaf.com
Old 04-24-2009, 01:34 PM   #10
fordcragar
Alliance Member
fordcragar's Avatar
Another place that you might check is www.metalmeet.com
One of the MetalMeet guys made a scissor like handheld hammer about six years ago, out of aluminum and it seemed to work well.
online   Reply With Quote
Old 04-24-2009, 06:45 PM   #11
HOTTRODZZ
Grenade Inspector
HOTTRODZZ's Avatar
Nice Job John...!
__________________
Rich Pauza
PAUZASFD Inc
Fabrications - Restorations - Recreations &
HOT RODS with RACE CAR DNA
Old 04-24-2009, 07:25 PM   #12
havi
Senior Member
havi's Avatar
Figure out a way to control air with a foot-pedal for bpm speed, and yer golden! http://www.autobody101.com/articles/...shing%20Hammer here's another.
__________________
I'm just an old truck guy trapped in a hot rodder's world
Old 04-24-2009, 07:29 PM   #13
Unkl Ian
Old School HAMBer
Unkl Ian's Avatar
Location: Just past the corner of Hell and The Twilight Zone.
Yardstore.com should have flat Upper Dies.
Much more reasonable $$$ than Hoosier.
I would go with larger cross section, thin wall tubing,
to get stiffness without un-necessary weight.
__________________
Updated:
FlyingEyeballs.net
Old 04-24-2009, 08:46 PM   #14
fordcragar
Alliance Member
fordcragar's Avatar
I will agree with Ian.
As for the upper die, do a search for rivet sets, I bought one off of Ebay for $20 a few years ago.
Old 04-25-2009, 10:09 AM   #15
Duke
What diameter and wall tube should I use?
Old 04-25-2009, 03:59 PM   #16
Fish Tank
Fish Tank's Avatar
Quote:
Originally Posted by John_Kelly View Post
Hi Duke,
HEY! I subscribe on youtube to your videos...lol I had no idea it was you.
Ha! (small world)
~Jef
__________________
LONE STAR ROUND UP 'PLACES' INFO:
http://www.jalopyjournal.com/forum/s...d.php?t=306194
Old 04-29-2009, 03:50 PM   #17
Duke
Any more ideas?
Thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
