Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 10-10-2009, 10:13 PM   #161
Fighter-of-Wars
Grenade Inspector
Fighter-of-Wars's Avatar
Default Re: 1947 Ford 1.5 Ton 'Heavy' Turbo Diesel
Lookin good
__________________
Join my Group! 1942-1947 Ford Truck Owners
"Remove two spark plugs, then you'll have 400hp"
offline   Reply With Quote
Old 10-12-2009, 02:03 AM   #162
Flathead26T
Grenade Inspector
Flathead26T's Avatar
great project. 4bt's are awsome. for my next project, what ever it may be, i plan on putting a diesel in it which will probably be when i am out of school. I am looking forward to the rest of this build. Good Luck!
Old 10-15-2009, 09:17 PM   #163
47Ford - 1.5Ton
Grenade Inspector
47Ford - 1.5Ton's Avatar
Here is what I'm thinking for my one off custom 4 Link Design
I'm trying to do a full bolt on configuration... why you ask... I'm an engineer... when the project is done I garuntee I'm giong to need something to toy with..... and Probably this....
__________________
1947 Ford 1.5 Ton
Cummins 6/Fuller 10sp
http://www.jalopyjournal.com/forum/s...d.php?t=355535
Old 10-15-2009, 10:39 PM   #164
Artfrombama
Senior Member
Artfrombama's Avatar
I think I'd rather have one bar over the axle, one below.
May have wheel hop under braking
__________________
1956 F100
Old 10-15-2009, 11:33 PM   #165
Dan Hay
Senior Member
Dan Hay's Avatar
Incredilble!! I'm crackin' up because most guys here bag there cars to lay frame, you bag your ride so it will fit in the garage! Hahahaha!
Old 10-16-2009, 01:21 AM   #166
47Ford - 1.5Ton
Grenade Inspector
Quote:
Hey! I take that as well.... sh*t........ the truth
Naw in all honesty..... its something to do that doesnt really effect the outward appearance... but man will it be nice to have in regards to ride quality when running completely empty.... and the moment I need to haul a few pallets of shingles for a friends new roof.... simply up the air pressure and viola.... its back to its full 2-ton hauling purpose.
__________________
1947 Ford 1.5 Ton
Old 10-16-2009, 06:39 AM   #167
bobwop
Alliance Member
bobwop's Avatar
give some thought to your shock angle. Great build, I am subscribed!
Old 10-16-2009, 08:32 AM   #168
Scott K
Please stand those shock up more vertical. They will be doing nothing at the angle that you show them currently.
Old 10-22-2009, 01:11 PM   #169
ruquik
Newbie
ruquik's Avatar
Why not just use the tried and true truck-arm type suspension??
Why can't i get my weld feature to work like yours. I'm using SW2009 w/ sp 1.4???
-Brad
__________________
Looking for a hard to find part, shoot me pm.
Old 10-22-2009, 02:58 PM   #170
Shifty Shifterton
Old School HAMBer
Shifty Shifterton's Avatar
Quote:
I would agree. Maybe incorporate the lower shock mount in the U bolt plate.
Damn that truck is cool
__________________
The same........but different
Old 10-22-2009, 05:08 PM   #171
47Ford - 1.5Ton
Grenade Inspector
-Brad
cntrl-left click all the faces you want threads on..... control-rightclick on a face..... appearance / threads / adjust angle-repeat size accordingly.
Cosmetic Thread Callouts rarely ever work or appear correctly on exterior based threads.... only holes do consistently.
EDIT: Running Solidworks Pro 2009 x64 sp. 4.00
__________________
1947 Ford 1.5 Ton
Old 10-22-2009, 09:14 PM   #172
ruquik
Newbie
ruquik's Avatar
Wait... Are you filleting the edges and then just putting the cosmetic thread on the fillet??
If you run the 4-link I think the end on the axle should be spread apart more for more "H"(height). Unless you reasoning was to have the angles of the two bars set so that the IC (instant center) is on/near the CG. Then you might just want to drop the lower bar and extend the bars forward more.
just my $.02.... (psst. truck arm is cheap and easy, lol)
Personally with an engineering back ground I say go all out and do a 3-link with a watts-link.....just because.
-Brad
__________________
Old 10-25-2009, 07:13 PM   #173
crxgames
FNG
Wow! Awesome build and truck! Subscribing...
Old 10-29-2009, 01:24 AM   #174
mart3406
Old School HAMBer
mart3406's Avatar
I like it! A couple of suggestions though. I'd probably mount the lower bar *below* the axle. With the axle centered between the two bars, instead of both bars on top, they'll have more leverage to be better able to control axle rotation under acceleration and breaking. without binding or bending. Also the shock needs to be much closer to vertical to be effective. At the angle shown in the drawing I think it'll' be almost useless. And idea for a shock mount - If you attached the lower bar with an extra long bolt - about an inch or inch and half or so longer than necessary - and then, leaving enough thread for the nut to locate the bar, turn the remaining inch or so of the bolt down on a lathe to the inside diameter of the shock eye and tread it for a nut. Basically you would be creating a "stepped' bolt that would locate the lower bar and also double as the lower shock mount. For the upper shock mount, you could weld a square or rectangul of 1/4 inch or so thick steel plate as a reinforcement on the frame where the shock will attach - and then drill it and the frame for a bolt to attach the shock. I'd put the plate on the frame just slightly forward of the axle, so as to allow the shock to attach from below the axle on the lower bar pivot point, to the frame and operate parallel to the frame and at about a 30 - 35 degree forward angle.
Mart
Old 10-30-2009, 05:14 PM   #175
47Ford - 1.5Ton
Grenade Inspector
CHRISTMAS IS EARLY!!!!!
UPS guy made my Friday.... made the beer tast better, and gave me something to do all weekend long......
All in an 80 lb box......
Rear Disc Brake Conversion! Yahtzee!
__________________
1947 Ford 1.5 Ton
Old 10-30-2009, 08:45 PM   #176
47Ford - 1.5Ton
Grenade Inspector
OLD:
NEW:
__________________
1947 Ford 1.5 Ton
Old 10-30-2009, 10:01 PM   #177
Gretta's Owner
FNG
I too have been mulling this idea over in my head for a while. great build. I love the detail.
__________________
I was reading in the paper today about this dwarf that got pickpocketed How could they stoop so low?
Old 10-31-2009, 12:05 AM   #178
woody 29 dodge
If you want to pretty up the front end a little try finding a mercury grill they have chromed horizontal grill bars , and they would look really good on your project. As for your truck that is an impressive piece of work. Rob
Old 10-31-2009, 06:27 AM   #179
mart3406
Old School HAMBer
mart3406's Avatar
Thumbs up Re: 1947 Ford 1.5 Ton 'Heavy' Turbo Diesel
CHRISTMAS
IS EARLY!!!!! UPS guy made my Friday.... made
to do all weekend long...... All in an 80 lb
box......Rear Disc Brake Conversion! Yahtzee!
Beautiful rear brake set-up! Well thought
out, beautiful and practical! The fact that
with a diesel, because it doesn't have a
throttled intake like a gas engine and thus
doesn't supply any appreciable compression
braking, I think you'll really appreciate the
added braking power and particularly the
fade resistance of the rear disks. Way to
go!
Mart
Old 10-31-2009, 07:08 AM   #180
Stevie G
Alliance Member
Stevie G's Avatar
Quote:
Originally Posted by mart3406 View Post
The fact that
You let off the fuel and it becomes an air compressor...with a VERY high compression ratio. The throttle really has nothing to do with it. Add an inexpensive exhaust brake and you really have something.
__________________
Member ADHDC. Sure, I have a lot of cars but...Hey, that would look real cool with a...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
