Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#241 |
Newbie
p.s. what fatandloose was referring to is your anti squat, like you had it previously you would lose traction and like he said your braking would chatter. the program will also tell you your roll center height, roll center axis, vector calculations, material calc. and other stuff too. pretty cool
#242 |
Grenade Inspector
wow, now I'm 'fatandloose'? lol!
WelderSeries nailed it... exactly what I was thinking.
__________________
"I live for myself and I answer to nobody." ~ Steve McQueen |
#243 | |
Grenade Inspector
Quote:
Behold the actual use of my professional career in my hobby....... Thoughts? OLD ![]() ![]() NOW WILL BE>>>> ![]() ![]() ![]() Something I should have done in the first place...... What are everyone thoughts about the 3/8" Thick gusseted bracket to be bolted on......... Still need a cross member????
__________________
1947 Ford 1.5 Ton Cummins 6/Fuller 10sp http://www.jalopyjournal.com/forum/s...d.php?t=355535 |
#244 |
Old School HAMBer
Not having any FEA software I'll just throw this out...I would extend the plate on the frame such that the line of the angled braces/gussets would intersect at the top of the frame rail. I think this might have a better 'look'. Bolts are fine as long as they meet your shear loads and I would add a 'matched drilled' backing plate inside the rail.
Yeah I know, it's overkill.... Gary
__________________
www.qualityengineeredcomponents.com Early Hemi Parts, Pieces, Tech Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series http://www.discoverthenetworks.org/Articles/Hansen.pdf |
#245 |
Newbie
#246 |
Newbie
the goal of the 4link is to parallel with the ground at normal ride height. but if you think about it you have a 4bt and that engine isnt gonna be slinging 450hp to the rear so its not absolutely critical but what you have now will cause your suspension to act drastically better than you had it before. I say it looks good but further the better. Keep it up
#247 |
Cool....not bad for a Cheezehead!!!!
__________________
"Good Times & Good Friends Make Life Better!" my website is...www.artworks-unlimited.com |
#248 |
Alliance Member
Do you have the add-in for stress analysis?
At a minimum, I'm thinking boxing plate, but a crossmember with triangulation is what I see when I look at it. But then, I tend to think in terms of shock loads from depth charges, so take it for what it's worth.
__________________
Member ADHDC. Sure, I have a lot of cars but...Hey, that would look real cool with a... |
#249 |
Grenade Inspector
I see no need for a crossmember, being a 2 ton frame, I'm sure it's plenty stout enough. Are your frame splices from the shorten-up anywhere near the four-bar mounts?
Your design looks good, maybe a similarly-gusseted backing plate if you're going to do a bolt in. I wish I had some way to put on paper what I see in my head... I use a TON of cardboard and drawings to get my visions across. I see a combination of the vertical plate in your renderings, bent on a brake to resemble the earlier pics posted with the \____/ shaped rectangular tubing... very strong, clean, and nice... in my head anyway. My biggest problem is that my visions far surpass my fabricating abilities!
__________________
#250 |
Grenade Inspector
any updates?
__________________
#251 |
Grenade Inspector
Very nice. I've been thinkin about doing a 4-link airbag setup for the diamond. Just a matter of time and resources, it's not high on the priority list at the moment.
How do you like the ride quality on yours? Which kit did you end up going with for the hardware? |
#252 | |
Grenade Inspector
Quote:
Note comment on the ride quality yet as it hasn't seen the road..... All my hardware is either home fabricated or I use Suicide Door Company or Welder Series....... Bar none I've had nothing but positive experiences with both..... Mounts are getting machined as we speak... it'll be a few days yet but maybe next week I'll have further progress.... ~M
__________________
#253 |
Grenade Inspector
I so wish I hadn't opened this thread....
#254 |
Senior Member
its kinda refreshing to see it restored to what its intended to be. not that i mind a hot rod build but it seems like so many are destined to be chopped and altered to where you cant tell what it spent its life as.
good job on the build so far. kudos to you!
__________________
Fashion is fleeting; Style fades; Tradition is FOREVER. |
#255 |
Grenade Inspector
#256 |
Grenade Inspector
#257 |
Grenade Inspector
There was some minor drama on this thread last night which lead to 3 of my posts & seemingly all the posts by the guy who responded to my 9pm post being deleted. For some reason one of my posts was left intact when it should have also been deleted... so I just deleted it myself.
Nothing to see here... move along...
#258 |
"These are not the droids we're looking for.....move along."
__________________
#259 |
Grenade Inspector
Just got my bendix AD-9......... oooo weee ($30.00 only too to boot)
![]() PS..... for those wondering its a commercial truck air/water seperator that automatically discharges the water/debris out on purge/charge cycle by using my D2 governor and a 12V heater element..... aka the big truck PSHHHHHH that you hear at a stop light.... (if its not bleed off from the air brakes)
__________________
#260 |
So you're planning on running AIR brakes in this old girl???
__________________
| Thread Tools | |
| Display Modes | |
