Reply
Thread Tools Display Modes
Old 04-04-2009, 08:16 PM   #1
GuyW
Grenade Inspector
GuyW's Avatar
Default ID Chevy distributor?
I have a Chevy SBC Delco Remy tach drive distributor that I want to identify. It is a cast iron body, and non-vacumn advance...
Metal band says: “1111134 DELCO REMY 5 J 7”
Anybody have a link for me?
Thanx
offline   Reply With Quote
Old 04-04-2009, 08:28 PM   #2
36-3window
Old School HAMBer
36-3window's Avatar
Default Re: ID Chevy distributor?
is that an actual tag that is riveted to the housing , or a metal band that is wrapped around it?
Old 04-04-2009, 08:45 PM   #3
GuyW
Grenade Inspector
GuyW's Avatar
Old 04-05-2009, 12:41 PM   #4
36-3window
Old School HAMBer
36-3window's Avatar
for some reason i can not find that number on anything i have , maybe by bringing this back up someone else can.
delco remy used a date code that started with the last digit of the year first , then a letter month code ...by that 5 J 7 would mean October 1965 i believe.
Old 04-05-2009, 01:49 PM   #5
dbradley
Senior Member
dbradley's Avatar
How 'bout Sept 7th, 1965 (They don't use the "I" in the date code) That would be the assembly date for the distributor. The 'tag' p/n could be a service replacement number. The one you listed doesn't show up in any Corvette docs I have (and they do show '65 - '66 production)
Old 04-06-2009, 04:29 PM   #6
chickenridgerods
Senior Member
chickenridgerods's Avatar
Those numbers would fit right in with a part for the '66 model year.
__________________
Mike
Wanted:
- ARDUN parts: Hilborn & misc
- '32-34 Ford RPU parts, radiator cap, rear fenders
Old 04-06-2009, 04:40 PM   #7
HEATHEN
Old School HAMBer
Quote:
While I have seen several sources claim that "I" was not used in date codes, I've also seen both intake manifolds and cylinder heads that had codes starting with "I".
Old 04-06-2009, 04:44 PM   #8
tommy
Old School HAMBer
tommy's Avatar
Quote:
Metal band says: 1111134 DELCO REMY 5 J 7
Thanx
This is just a guess but with no vacuum advance, could it be a marine distributor?
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
online   Reply With Quote
Old 04-06-2009, 05:04 PM   #9
hotroddon
Old School HAMBer
hotroddon's Avatar
That is a 1966 Vette 327, 300 Horse according to my Delco book (built sept 7, 1965)
__________________
As I hurtled through space, one thought kept crossing my mind
every part of this rocket was supplied by the lowest bidder. ~ John Glenn
Old 04-06-2009, 05:09 PM   #10
RustyBolts
Senior Member
RustyBolts's Avatar
Those tach drive distributors are pretty rare, so it's worth a lot to the right people. That seems weird that it's a non vacuum advance one though.
Old 04-06-2009, 08:25 PM   #11
GuyW
Grenade Inspector
GuyW's Avatar
Quote:
Thank you all. This is about what I thought it might be.
As to the no vacumn advance, it was probably removed as a modification.
The distributor came (running) in my 1936 Chevy PU with 327, 2 WCFB carbs, 30-30 cam, Muncie 4-spd, '57 Pontiac rear end, that I bought in 1969. I did have some info that the distributor had been recurved in a machine.
I am thinking about moving the distributor.....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
