Reply
Thread Tools Display Modes
Old 03-25-2009, 10:18 PM   #1
wetatt4u
Senior Member
wetatt4u's Avatar
Default Thumper Comp Cam * GOOD OR BAD *
I want to buy one of the New comp cam thumper Series cams.....
Summit sells them! ! !
But Im worried about tech help if Comp goes out of business,I think
Summit would stand behind them somewhat , but I don't know for sure ,
I will call them in the morning and get the low down about Comp products,
1)I would like to know what all you guys feel about the thumper series cams?
2)Do you think there is a better cam for the proformance and sound ?
Thanks for the help....
If a stupid question let me know about that also.
FLAME ON ,Ive got my fire suit on! ! ! ! ! ! ! !
__________________
God Bless America.
offline   Reply With Quote
Old 03-25-2009, 10:58 PM   #2
Shifty Shifterton
Old School HAMBer
Shifty Shifterton's Avatar
Default Re: Thumper Comp Cam * GOOD OR BAD *
Nobody stands behind anything with cams. As long as the right part number's in the box, you're on your own.
Frankly the whole concept behind the thumper seems cheesy. If you pick any moderate cam and exhaust, it's gonna rumble and thump and sound good. I'm sure they're fine, the marketing just chafes a little
good luck
__________________
The same........but different
Old 03-25-2009, 11:01 PM   #3
Glen
Senior Member
Glen's Avatar
Quote:
good luck
Well said.....shoot for power and then get the sound as a benefit. Also, make sure you degree the cam, dont just put it in straight up.
Old 03-25-2009, 11:03 PM   #4
ModelAMafia
Grenade Inspector
ModelAMafia's Avatar
I believe they get their sound by having a large overlap. I would check into specific specs and if it is really the best cam for your setup. You might run into vacuum problems if your running power brakes with so much overlap.
Old 03-25-2009, 11:10 PM   #5
fab32
Alliance Member
fab32's Avatar
Your best bet, as always, is to call the Comp Cam help line and discuss your EXACT application with someone trained to point you in the right direction. Just don't BS them and try to make out your John Force Just the facts ma'am. They don't want a dissatisfied customer and have years of experience mating cams to applications. Even if you have to pay for the call ($10 maybe) it will be the best money you'll spend knowing you've got the right piece for such a critical component.
I've used Comp Cams for years and have never had one recommended by them to be wrong.
Frank
__________________
"What we got here is failure to communicate"
Old 03-25-2009, 11:16 PM   #6
wetatt4u
Senior Member
wetatt4u's Avatar
Thanks everyone ,well said by all so far.
Im thinking about 492/510 height ,high as I want to go ,should have real good power and
should sound good ..headers with 2 and 1/2 in pipes and flowmasters ,electric cutouts
I don't have power brakes ,so thats not a problem.........
__________________
God Bless America.
Old 03-25-2009, 11:26 PM   #7
dirtbag54
dirtbag54's Avatar
i have heard of the thumper cams but dont know the exact specs...the name comes from the fact that it has enough duration and lift to give you a rough choppy idle which any cam starting at about 480 lift and 280 duration and up will give you....the thing to look for is the requirements for running a specific cam. like headers,stahl converter larger than stock. different gears and weight of vehicle all play a part in making it all work together....
Old 03-26-2009, 12:00 AM   #8
wetatt4u
Senior Member
wetatt4u's Avatar
I like the Comp Cam help line idea,
I wonder if their line is still up and running or if its been shut down along with the company?
__________________
God Bless America.
Old 03-26-2009, 12:10 AM   #9
r759ca
FNG
thought crane was the one that went out of business not comp unless i missed that part
Old 03-26-2009, 03:44 AM   #10
scottybaccus
Old School HAMBer
scottybaccus's Avatar
I just put one in my engine. I had ordered the big mutha, but it was back ordered for weeks and was pushed back twice. (late model OE roller cam) I finally told Summit to send me the middle weight. It got here in 2 days. I only gave up about .010 lift on each side.
I'll let you know how it works out. It may be a while before I turn it over. It was a pain to degree in. I figured there was something machined wrong; crank key way, timing set, cam or maybe stack of tolerances in all three. It was retarded 3-4 degrees when timing set was straight up and each key way was + and - 5-6 degrees. I finally installed a cam bushing to nail the specs on the card. Local speedshop owner tells me that in all his years he has never seen a roller cam install correctly out of the box. I dunno.
I chose it specifically to get the narrow lobe separation (107*). It is about as much overlap as you can get anymore. All the cams available today, short of max race, have wide separation to create vacumme for power brakes and idle well with efi. I built mine for a real 11:1+ compression and want every bit of cylinder pressure I can get. The marketing campaign is kinda cheesy, but I am sure they get tons of calls asking for that "knarly, race car, lope".
Anyways, once degreed in, it matched the spec card very closely. It may be a couple thousandths short on lift, but it's within the tolerances I expected.
As far as a better cam for performance, that is all relative to your situation. Their tech line can help a lot, but you need all the details. If this will be your first conversation on that topic, expect general reccomendations on the safe side. They won't get "gnarly" with an amatuer. They expect pro builders to know their shit. You can play with all the options by downloading their camquest software. It's a trip to see how different changes affect power and torque. Just be real with the data you feed it and the expectations you have. I can create a combo in the software that makes 517 HP, but that isn't realistic for my parts. Being careful with my input, the software put me in about 425 HP, right where I was aiming with my build copied from a couple of magazine builds that I've researched very well. I think you can trust it, but it really is a case of "garbage in = garbage out".
__________________
Shooting down dumb asses one S-10 frame swap at a time...
Tejas Malcontents, Hutto
online   Reply With Quote
Old 03-26-2009, 05:42 AM   #11
Littleman
Alliance Member
Littleman's Avatar
I just pulled out the Big Mutha Thumpr hydraulic roller setup out of my 355.......it ran 10.89 w/ six-two's..........I went bigger and went with a solid cam will try that as soon as the track opens........Littleman
__________________
http://www.littlemansspeedandfabrication.com/
...............'' Are we adults.......or just tall children? ''......
Old 03-26-2009, 06:04 AM   #12
parksquijada
Grenade Inspector
parksquijada's Avatar
They must be dancin' in the Whitehouse if another American company went under.
Old 03-26-2009, 06:12 AM   #13
Finn Jensen
Alliance Member
Finn Jensen's Avatar
Quote:
Correct
Old 03-26-2009, 07:03 AM   #14
Fat Hack
Old School HAMBer
Fat Hack's Avatar
Put a really good stereo in your car and play the drumming intro to Van Halen's "Hot For Teacher" really really loud if the 'sound' is all you're after when selecting a cam.
Really, it's the Best of Both Worlds...you can control the volume and be a Little Dreamer without even leaving your driveway! The engine doesn't even have to RUN, so long as your battery is up to snuff and can power your amps!
Ha Ha...marketing a camshaft based on it's 'sound' is just about the dumbest thing I've ever heard of, but fitting, given the source. Personally, I'd buy a cam from Crane (plenty of stock still available out there), Lunati, Isky or even Crower...they have a line of "Beast" cams on the market now with some really sensible specs, with several to pick from for each popular V8 application.
Unfortunately, they were probably engineered for their PERFORMANCE, though...so who knows what they 'sound' like?!
__________________
The 90s are the new 70s...I dig the 90s!
Old 03-26-2009, 08:24 AM   #15
whatever
Grenade Inspector
whatever's Avatar
big motha thumpr sounds fricken awesome and performs great in my 11-1 350
Old 03-26-2009, 08:54 AM   #16
wetatt4u
Senior Member
wetatt4u's Avatar
scottybaccus
Thanks for the help!
Littleman
Thanks for the reply,thats what I needed ,
parksquijada
My mistake IT is Crane NOT Comp that is out of business.............
Fat Hack
Thanks
MR I JUST GOT MY 55--- LOOK AT ME........
Smart Ass,
and to think I was happy with your story about you getting your 55 home!
Its NOT just the sound
ITS the sound and proformance ...............
whatever
Thanks Man thats what Im looking for ........
I'm going to be a little less then yours at about 10 1/2-1 350cuin
__________________
God Bless America.
Old 03-26-2009, 09:10 AM   #17
Shifty Shifterton
Old School HAMBer
Actually it should be about the performance, then the sound just happens to fall in line.
It's backward logic. With street cams you go for idle manners, because that's the weak point of big cams in street cars. It's what holds you from going bigger and badder. So essentially with thumpers they're advertising the idle quality doesn't match top end performance.
There's some good advice here, but you don't have a clue how to pick cams if you're considering some of these user replies to be data points or think you've provided enough for us to recommend something intelligent. There's just not enough information. Wanna know what a real data point involves? displacement, compression, head type, torque converter, transmission, rear gear, cruise rpm, redline, weight, street/strip percent use, and a camshaft part number.
So call every cam company. Be real. Put all the recommended specs down on paper. Look for consistency in recommendations and don't be afraid to ask if something sticks out as different than what the competition recommended. That's how you pick a cam. If it just happens to be a thumper, great. Otherwise you're letting the ad guys pick your cam. They don't know shit about your setup. And if you're getting outrun, who really got thumped???
good luck
__________________
Old 03-26-2009, 09:17 AM   #18
onequickchevy
FNG
onequickchevy's Avatar
I have run Comp Cams for years and have had great luck with them. I currently am running a 292/501 cam and it sounds great and makes easy 400+ hp in my 350 (unique engine! ). They also have a downloadable desktop dyno that aids in cam selection and tells you expected horsepower per your combination. Just my .02, but I have always liked then and their service before and after the sale.
Chris
Old 03-26-2009, 09:39 AM   #19
ERKEL
Newbie
ERKEL's Avatar
I have run comp cams for several years, never had a problem. I am a dealer for them now and if you cant find one let me know and I will see what I can do for you. Best thing to do is to call COMP at 1-800-999-0853 and see what they suggest.
Old 03-26-2009, 09:53 AM   #20
wetatt4u
Senior Member
wetatt4u's Avatar
Shifty Shifterton
Makes all the sense in the world to me ,Thanks I do know most of what you advised!
I DON'T want the AD guys to pick my cam...
ERKEL
Thanks for the number ,I'll be calling them today ,
If I need more advise ,I'm pm you.......
__________________
God Bless America.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
