Reply
Thread Tools Display Modes
Old 03-09-2009, 04:25 PM   #1
'52 F-3
Grenade Inspector
'52 F-3's Avatar
Default hidden (under dash) AM/FM antenna? any recommendations? good or bad....
so i mounted a CD player (and 2 speakers) under/behind my dash. I didn't want anything visible and there was no other good options........(it came with a remote control, so i don't need to touch it except to change CDs)
anyway i now need and antenna and have never used one of those hidden (street rod) antennas. do they work? which brands good or bad?
or other mounting locations? maybe under the car.........(oh, it's for a roadster with no hood or fenders)
__________________
www.52 Ford F-3.com
offline   Reply With Quote
Old 03-09-2009, 05:39 PM   #2
tooslow54
tooslow54's Avatar
Default Re: hidden (under dash) AM/FM antenna? any recommendations? good or bad....
I just stuck a cheapy 8$ under my dash. There were holes in the bracing so I just routed it thru them and zip tied it in place. So far I get pretty good reception...
Old 03-09-2009, 05:39 PM   #3
Boyd Who
Senior Member
Boyd Who's Avatar
I had one mounted under the dash of my '48 Chevy p/u and it didn't work worth a damn. Apparently they work better in a 'glass car.
__________________
Al Gingles...livin' the quiet life in rural Manitoba.
'27 Essex pickup (was a driver, now a project)
http://www.northwestcoin.ca/hotrod.html
Old 03-09-2009, 05:56 PM   #4
MilesM
Alliance Member
MilesM's Avatar
I have tried two different hidden ones and niether could bring in AM if that matters to you. FM was only fair.
Old 03-09-2009, 06:03 PM   #5
Black Primer
Black Primer's Avatar
Ditto... I did the same on my 40, only FM and not that great. I was thinking about trying to mount one under the running board, might work better?
__________________
Just because you have a few Craftsman tools, doesn't mean you're a craftsman.
Old 03-09-2009, 06:56 PM   #6
40StudeDude
Old School HAMBer
40StudeDude's Avatar
Go get a plain antenna from the parts store, mount it front to back on the outside or bottom of the frame rail, run the coaxial (or whatever they're called) cable up into the car and hook it into your stereo...I've done several that way and they all work fine...
R-
Old 03-09-2009, 07:50 PM   #7
LOW LID DUDE
Senior Member
LOW LID DUDE's Avatar
I bought one of those antennas from a street rod supplier that sticks to the inside of glass .JUNK it sucks.Wasted $.
Old 03-09-2009, 07:56 PM   #8
the shadow
Senior Member
the shadow's Avatar
mounted one along the frame rail on my 41 willy's worked great!
Old 03-09-2009, 08:18 PM   #9
Zookeeper
Senior Member
Zookeeper's Avatar
I had a plain old junkyard antenna under the seat of my A, it worked just fine.
__________________
If it breaks, fix it. If it doesn't break, make it lighter...
Old 03-09-2009, 08:37 PM   #10
CruZer
Senior Member
CruZer's Avatar
Yup me,too. I just bolted it to some bracing.It's just a cheapy.
Glenn
Old 03-09-2009, 08:45 PM   #11
meatball
Old School HAMBer
meatball's Avatar
old installer tip is mount it in the back of the seat as high as you can get it.make sure its tight and grounded should be good for fm/am
__________________
Be nice to strangers.......They may sit on your jury! Street Freaks RULE!
online   Reply With Quote
Old 03-09-2009, 09:29 PM   #12
mitch 36
mitch 36's Avatar
I tried one , it was called CAT hidden antennae.IT SUCKED ASS. It even didnt work well when i stuck it directly in the windshield. I ended up drilling a hole in my newly painted body and installed a power unit. I even tried it in my boat with marginal success. JUST JUNK !!! Mitch.
Old 03-09-2009, 09:59 PM   #13
fuzzy bunny
Alliance Member
fuzzy bunny's Avatar
I bought a powered antenna from auto lock for my van, stuck it under the dash wired it to the aux power on the CD player and it works killer. I think it was like 30 bucks.
__________________
Hey!!! That doesn't float!
Old 03-10-2009, 12:59 AM   #14
bob3757
Alliance Member
bob3757's Avatar
I have two cars with the antenna mounted under the car, both work great. I used standard cowl or fender mount antennas. Be sure to use rubber grommets, or some other insulator on the antenna shaft, to prevent grounding of the antenna to the frame or body. Bob
Old 03-10-2009, 01:07 AM   #15
meatball
Old School HAMBer
meatball's Avatar
look for HARADA PM58 works great for this use
__________________
Old 03-10-2009, 04:22 AM   #16
'52 F-3
Grenade Inspector
'52 F-3's Avatar
thanks very much for the replies.........
i'm going to pickup a standard antenna and temp. mount in a few locations under the car (think i'll try behind the seat also). then permantly fix to the best location.
fyi,
he's a picture of the brackets i made to hide the stereo and speakers up under the dash out of view....
__________________
www.52 Ford F-3.com
Old 03-10-2009, 06:41 AM   #17
zman
Alliance Member
zman's Avatar
I used one of these antennas.
http://www.crutchfield.com/p_12044UA...wAll=N&tp=2369
works great...
__________________
I have gotten grief for pointing out that the white, speckled stuff on chicken shit is still chicken shit. I will continue to do so... Chili Phil
Old 03-10-2009, 07:15 AM   #18
Topolino Kid
Senior Member
Topolino Kid's Avatar
works great...
this type is stock equipment in my four winns boat...works great!!!!!
__________________
Lil Beast.............
http://www.jalopyjournal.com/forum/s...d.php?t=441513
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
