Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
Recently bought a Lincoln Flathead V12 often called the Zephyr V12 although mine is not out of a Zephyr.. It's a early 1946 305ci model.
These engines have the very cool looking but hopelessly impractical dual 6 distributor with the integrated ignition coils. Parts for these distributors seem to be hard to find, I've found some vendors for some pieces, but other parts seem to be made out of unobtanium. Has anyone ever converted another distributor to work on these engines? I was looking at the older Jag v12's, they use the Lucas 36DE12 distributor, single coil, single cap with a detachable shaft and several options for electronic ignition. I'm considering trying to convert one of those for use on the Zephyr engine. Any ideas or information would be greatly appreciated to get me along the right path to make this engine run again. Thanks,
__________________
Rob. Changed my HAMB username to schilpr, my company HR Classic Cars, is no longer in business. |
#2 |
Try two EDIS 6 ignitions with a Megajolt ECU. I think you will find on the megajolt lite site http://www.autosportlabs.net/index.p..._Users_Welcome that there are one or Jag V12's running them. It may not be traditional(neither is unreliability ) but they can be hidden and the naysayers won't know what they are looking at anyway.
#3 |
Old School HAMBer
i heard you can cut 2 v6 hei's and weld the tops to your lincoln bottoms. a guy in my town converts any dizzy to hei.but only does it for the local guys.
#4 | |
Grenade Inspector
Quote:
__________________
#5 | |
Quote:
. The coil packs are in the open at the moment but I have seen them hidden in model T ford trembler boxes on concours winning T's. You can even trigger the EDIS from the ring gear but every 36th tooth has to be removed,Or a cam drive for the trigger wheel in a housing if you feel you don't want anyone to see a trigger wheel,but hey it's hot rodding not vintage car restoration And a big ugly GM HEI coil on top of a dissy looks worse than anything on a Ford or Lincoln ,don't you agree? ![]()
#6 | |
Old School HAMBer
Contact GMC Bubba here on the H.A.M.B. He appears to have the capability of making ANY old distributor better than new. Search his many posts-he's done a bunch.
Quote:
| Thread Tools | |
| Display Modes | |
