Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 02-22-2009, 06:21 PM   #1
CRH
CRH's Avatar
Default Ford Alternator w/ External Regulator...?
Hey guys, I hope my question isn't stupid! I made the entire harness for my little '27 Roadster, and everything seems to be working fine except the charging circuit.
The car is running a little 302, and it used an external voltage regulator. I wired the regulator terminals correctly, but didn't use the "I" terminal, since I always assumed that is only for a charge indicator light on the dashboard. I just have the other three terminals properly hooked up (A to BAT, S to Stator, F to Field). Do I need to have the resistance of an indicator light connected to the terminal "I" on my regulator in order for proper charging, assuming all other parts and pieces are working and connected right?
When I test the new alternator, it only raises the charging to about 12.6 volts, and that requires at least 1200 RPM's. Any help appreciated.
__________________
www.theoldcar.blogspot.com
offline   Reply With Quote
Old 02-22-2009, 06:36 PM   #2
coupster
coupster's Avatar
Default Re: Ford Alternator w/ External Regulator...?
The "I" has to be hooked up to excite the field. Did you try to full field the Alt to see if it is working?
Old 02-22-2009, 06:54 PM   #3
coupster
coupster's Avatar
To give you a little more info about that circut, Ford used a 15 ohm resistor in parallel with the indicator light. It was there in case the bulb burned out. You need to use ignition switch voltage for this as the battery would run down if you left voltage at "I" when the engine is not running. Hope I didn't muddy up the explination to bad.
Old 02-22-2009, 07:01 PM   #4
58custom
Grenade Inspector
58custom's Avatar
Quote:
Coupster is exactly right. Run 12v from the ignition or running accessory supply through a 15 ohm resistor to that terminal whether or not you use a charge indicator light. Use a 1 watt resistor or greater. This works the same when you use a Ford 3G internally regulated alt. I found that out when adding a 3G to my '58 Ford.
__________________
1958 Ford Custom 300
1968 Cougar (sold)
1969 MG Midget
1994 Suzuki VS800
Old 02-22-2009, 07:20 PM   #5
24riverview
Grenade Inspector
24riverview's Avatar
I've always hooked them up the same as you did (CRH) except-the S terminal on the regulator goes to a key controlled ignition source (no stator wire is needed at the alternator).
http://www.oldcarmanualproject.com/t...re5765-237.jpg
http://www.oldcarmanualproject.com/t...re5765-236.jpg
Old 02-22-2009, 07:37 PM   #6
butch27
Senior Member
I put a diode in and ran the wire to ACC on the switch.
Old 02-22-2009, 10:27 PM   #7
CRH
CRH's Avatar
Holy Moly, thanks for this helpful, straightforward info, people! I'm very grateful, and the reason-why type explanations I like best are what you people have provided. Thanks!! I'll wire the '27 correct tomorrow...
__________________
Old 02-24-2009, 05:27 PM   #8
CRH
CRH's Avatar
Hey guys, one more question: Is it bad to simply have the "I" terminal run straight from a switchable power source, like the ACC part of my ignition switch? I tried this for fun and it did as stated previously; it excited the field. I'm just wondering if and why a resistance must be part of that circuit...? Is it too much amperage, hence the use of 15 ohm resistor by Ford?
__________________
Old 02-25-2009, 09:11 AM   #9
58custom
Grenade Inspector
58custom's Avatar
Quote:
Well, first, I must correct my previous post. I took a look at my factory data and the resistor is 560 ohms, not 15. Sorry for the bad cheese. The resistor is there to simulate the DC resistance of the charge indicator lamp should that lamp burn out. I have heard of people wiring it up straight without either lamp or resistor but I think I would use a resistor anyways. Another poster mentioned a diode. You have a 50/50 chance of getting that one right. Just get a 470 to 560 ohm 1 watt resistor or a pair of 1K 1/2 watt resistors and put them in parallel, solder on the wires, use two pieces of shrink wrap (shrink one at a time) and there you have your inline resistomathingie for much charging goodness.
__________________
1968 Cougar (sold)
1969 MG Midget
1994 Suzuki VS800
Old 02-25-2009, 09:52 AM   #10
CRH
CRH's Avatar
Quote:
That makes sense, no worries. I'm just too "in-the-dark" about why there should be the resistance. I'm scared that maybe it lessens the load on the "I" terminal for a good reason, like protection or something...? I have driven the '27 for the past two days with just a straight wire from the ignition ACC side to the "I" on my voltage regulator, and the alternator charges great. But, does this mean it is overcharging or that my un-resisted wire will eventually burn out the voltage regulator?
__________________
Old 02-25-2009, 10:20 AM   #11
butch27
Senior Member
Put a diode in. You just don't want the voltage to back up to the reg.
Old 09-25-2012, 09:00 PM   #12
hrspwrranch
FNG
hrspwrranch's Avatar
Do you put the diode on the I terminal?
Old 09-26-2012, 09:58 PM   #13
Kenneth S
Senior Member
Kenneth S's Avatar
This is how I wire a Ford alternator w/ external regulator, except I delete the amp guage (fire hazard), and use a volt guage. Been wiring then this way for over 30 years with no problems.
__________________
Ford 2.3L Lima engine guide.
http://www.jalopyjournal.com/forum/s...36#post3389436
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
