What body filler are you guys using?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 29, 2009.
  1. Roothawg
    Roothawg
    I am looking to change brands. I have always used 3M and I know that there have been some technological advances in fillers in the production shop lines.
    So what are you swearing by now?
  2. Special Ed
    Special Ed
    Rage. Good stuff
  3. djust
    djust
    from Oklahoma
    Don't have alot of experience with it yet but rage extreme seems to be real easy to apply and sand.
  4. Rage, I used it on the T just getting back into paint and body work after a long hiatus. Really liked how it worked. Have a few smaller projects under my belt since then. Double bonus that my parts store now carries it so I can get it on Sunday even!
  5. cody repp
    cody repp
  6. ruralrod
    ruralrod
    great topic.. good to know.
  7. Roothawg
    Roothawg
    Rage is actually the one I was curious about.
  8. chaos10meter
    chaos10meter
    from PA.
  9. autobodyed
    autobodyed
    from shelton ct
    make sure whatever brand you use, is stain free so it doesn't bleed thru your primer and paint. i always used rage until i was turned on to usc fuzion brand, it' s just as good for 1/2 the price. my guys love it, hardly any pin holes and does'nt stain. i've haven't had a problem with it at all in the last 6 months of using it. my 0.02
  10. MattyB
    MattyB
  11. roddinron
    roddinron
    Which rage are you guys using, extreme or gold?
  12. super plus
    super plus
    It's not the body filler that blends It's the hardner in it that makes it blend :mad:
  13. super plus
    super plus
    Oops:rolleyes:
  14. Squablow
    Squablow
    I put Rage against the machine. All my cars are filled with Rage. I like the regular stuff, not the Xtreem or whatever they call it. The fancy-pants shit seems to pinhole more, even though that's what it's designed not to do.
  15. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
  16. 40StudeDude
    40StudeDude
    It's the amount of hardener you put in that makes it "stain" or bleed...it's NOT the bondo...mix it correctly and you won't have any problems with bleeding or staining...DO NOT mix way too much hardener to hurry it...
    I use Rage Gold...
    R-
  17. I like Rage Xtreme. It sands really good. It's more expensive than regular Rage. That's if I have my choice. Rage is good too.
    Reverend Jake
  18. srdart67
    srdart67
    from Sharon, Wi
    LEAD!!!:D but most of the time rage gold. good stuff. very good stuff.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    I dont use body filler, I use polyester panel straightening compound
  20. theHIGHLANDER
    theHIGHLANDER
    I think the USC Kromate Light is hard to beat. Way less $$, almost never pinholes, never bleeds, sands easy, overall superior to Rage. It seems that this Rage line is indeed the latest "rage" in fillers but I don't see it. I have a 3gal tub here and it makes me miss my Kromate Light. It could be that I use very little filler in the work we do here, and my impression of Rage is that it's better for thicker builds.
  21. chopt55bc
    chopt55bc
    trust me on this,TRY THE FUSION!!! its the best stuff i have ever worked with.
  22. Roothawg
    Roothawg
    Good info. Never heard of the USC. Wonder who carries it around here. I'll hafta call my supplier.
  23. dawg
    dawg
    rage is the best, and shark bite is a cost effective alternative...
  24. another vote for rage
  25. 55oldsrocket
    55oldsrocket
    from Santa Ana
    i just started using Evercoat
    good stuff , very easy to sand.
    anyone tried it?
  26. Bluedscrewed&tattooed
    from AUSTIN,TX
    Rage, and all metal, all metal make you work for it though.
  27. 71buickfreak
    71buickfreak
    from Oklahoma
    rage is nice, but it costs too much. I use dp170 from PPG. works great, costs less.
  28. inliner54
    inliner54
    USC basecoat clearcoat
  29. 31aBoy
    31aBoy
    Rage Gold here... I used Rage Extreme for a couple of years, but i have since went back to Rage Gold. It has a nice big "window" of time to work it before it fully hardens. Take some 36 grit on a long board and sand most of the excess off.. Works slick, especially on large jobs.
    Then I use a "poly putty" over top. Work it with 80, spray with guide coat, and finish it out with 180.
