Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
This subject has been discussed before. But, there never seams to be a step by step process included. I have a 6V-71 core that was given to me. It is in decent condition. Building a manifold is not an issue. How do I set-it up to run on a SBC? The goal is to do and spend as little as necessary to install on a low buck rod. Can something as simple as multiple timing belts be used to drive the blower? Do the end covers get sealed (with a breather) and filled part way with oil?
#2 |
Old School HAMBer
Build your manifold first. Various length drive snouts will get you close on you belts then you can shim the pulleys to get everyting lined up.
You need high speed bearings and new seals.. the stock blower runs on engine oil via an oil line. The front cover runs in 80W90 gear oil... the rear bearings are packed with grease. You also need a rear beraing plate and modify the front cover by making a "triangle" plate so you can fill the cover with lube. Aftermarket covers will usually have a pressure relief valve installed.. it's not a toy to impress your friends with... the cover's seals need some pressure to keep sealing properly. Visit the sites of BDS, Dyers Blower Service and others for more info.
__________________
www.rumblefest.net www.facebook.com\rumblefestshow www.facebook.com\amherstspeedway |
#3 |
Here is a question I've been ask a hundred times at the track, How much oil goes in the front cover? 20 ounces. JC
#4 | |
Old School HAMBer
Quote:
__________________
Against stupidity, the gods themselves contend in vain. - Schiller Life's a bitch. If it was easy, it would be a slut. |
#5 | |
Old School HAMBer
Quote:
Now you've got all that fab time saved up for making your drive system. ![]() One unavoidable obstacle is the physics of drive belts transferring power and the amount of torque it's gonna take to turn a 6/71. You'll probably find that when 3 or 4 timing belts are summed up it makes $$ sense to use a real blower belt and looks less hillbilly. When you start talking about using a real blower belt, suddenly looking for a used piecemeal pulley set, or buying 2 pulleys and making one, become viable options. Sometimes the cheapest way to go fast is spend money. Yes you read that right. When talking used SBC speed parts, it's real hard to make something for less than you can buy it. good luck
__________________
The same........but different Last edited by Shifty Shifterton; 01-20-2009 at 08:23 AM. |
#6 |
Alliance Member
He said it was a 6v71. Nobody makes manifolds for that blower so he's on his own.
#7 |
Old School HAMBer
Location: Texas City, Texas Between Houston & Galveston
#8 |
Old School HAMBer
6/71 gmc blower:
![]() 6V-71
#9 |
Old School HAMBer
Oops, I went by the title. Yeah a V manifold is an issue on a budget.
FWIW you can put aftermarket drive non-V snouts onto a V with minor trimming and use readily available 4/6/8-71 drive stuff. good luck
__________________
The same........but different |
#10 |
Alliance Member
There is a difference between a 6-71 and a 6v-71. The 6-71's were used on the inline engines, and were mounted on the side of the motor. The 6v-71's are from the V-type engines, and mounted between the cylinder banks, and have a completely different mounting scheme.
#11 |
Old School HAMBer
a customer of mine had a dyers v6-71 setup.....used a 1/2" or so thick plate that was bolted to a regular manifold....looked fairly easy to replicate....must have worked , as his little s10 with a stock cam and decent heads and short block went 10.70's with the deal.......
__________________
Even when they say theyll help...theyll always find a way to tell ya no.www.pinheadlounge.com/bdi |
#12 |
Senior Member
The "6v" has a weird case (for lack of a better word). Its NOT what you would see normally. Dyer's makes a manifold for one but probably not too many used ones laying around. Others make 'replacement' cases (use the other parts internally) that will fit the 'normal' 6-71 manifolds.
#13 |
Alliance Member
I had a Dyer's prepped V6-71 blower on my old 32 coupe too. The intake that was used to build the blower manifold was an Offy low rise dual quad intake.
They machined off the whole carb area and welded a flange to the existing intake that accepted the blowers bolt pattern. Considering the area the dual quad's take up on the intake, i still think that idea would be the best way to approach this. Only because the area below what's needed to be removed is already close to the length of the blower flange. Just my thought's only because of what i had myself. As far as belts, i agree with Shifty on this. I'd look around for non V style components and make them work. Of if you feel real crafty, make your own V-belt drive assembly for it.. Deffinately spend some time visiting, and talking to the people at the blower sites. They know what they are talking about and will be able to lead you in the right direction. Tony.
__________________
WHO CARES! "You are cordially invited to shit in your hat" -Chili Phil- Last edited by Tony; 01-20-2009 at 09:28 AM. |
#14 |
Old School HAMBer
Oh snap, I missed the "V". I remember being down in the engine room of my dad's boat, had 6-71 diesels in it; and seeing the blowers, and thinking how cool it would be to put one on the family car...
#15 | |
Senior Member
Quote:
__________________
Ford 2.3L Lima engine guide. http://www.jalopyjournal.com/forum/s...36#post3389436 |
#16 |
Grenade Inspector
6-71 mounts with straight up studs and bolt holes, 6V-71 has an angle set-up with splayed bolts / lugs to hold it down.
I think the rotors and gears might be the same but the case is the problem. K |
#17 |
Senior Member
Sell the 6v-71, and get a 6-71 it's easier to deal with, plus part are more readily available for the 6-71.
__________________
#18 |
Old School HAMBer
Kerry, Dyers make a intake for the V671. It's a low profile inake and a very neat setup. I'll look for a picture of it. I know a Hamber that has problems with Blowing rearends
using one of them V671's.I have a Duel Quad intake for a SBC that I'm going to sell off for 120 bucks. What you would have to do is install a Pop Off valve onto the intake or blower plate to install the V671. Oh yea have a v671 forsale too
__________________
Wanted 1932 Ford Roadster Parts doors cowl anything Please parts
#19 |
Senior Member
Dyer USED to make a sbc 6v-71 intake in the 70's.
__________________
#20 |
Alliance Member
EXACTLY. I called them last year and talked with a tech because i had the rebuilt V series on my bench... He said they CAN still make one, but it would be a little over 800$ to do it..NOT worth the money. The one i had on my coupe was one of thier's. Short of fabricating your own items to make the V6-71 work, it will be COSTLY... I sold mine and bought a nice, used 6-71 instead, and i know i'm further ahead. Tony
__________________
WHO CARES! "You are cordially invited to shit in your hat" -Chili Phil- |
| Thread Tools | |
| Display Modes | |
