Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Vendor
Hey guys,
It's Shane from Baileigh Industrial here in Wisconsin. As you know, we deal with the Hot Rod and Restoration crowd on a daily basis and would love to get a little more involved on the board and help out in our area of expertise. We have a whole team of metal fabrication experts here and we specialize in tube bending and odd applications. So, I will start this tube bending thread. If you have any questions about roll cages, bending tube or pipe, application issues, what wall thickness will work or not, wall thickness vs. center line Radius or what material will bend. Pretty much anything related to tube bending......ask away.
__________________
Shane Henderson Baileigh Industrial shenderson@bii1.com www.bii1.com 920-684-4990 New Notcher Video http://www.bii1.com/videos/tubing-notcher-tn-250.php New Shrinker / Stretchers http://www.bii1.com/metal-forming/shrinker-stretcher.php $995 New 36" Throat Powered Bead Roller http://www.bii1.com/videos-pages/bead-roller-br18E.php Click Here For Quality Metal Fabrication Equipment Last edited by BAILEIGH INC; 01-12-2009 at 09:07 AM. |
#2 |
I know how to bend, but as everyone here will say, they would like to find an affordable mandrel bender...maybe even a bench mount one. Then can be made to be affordable....
__________________
The 'GO' pedal is the one on the right. |
#3 | |
Alliance Vendor
Quote:
Unfortunately if you are looking to do exhaust, mandrel benders that will handle exhaust are quite spendy.
__________________
Shane Henderson Baileigh Industrial shenderson@bii1.com www.bii1.com 920-684-4990 New Notcher Video http://www.bii1.com/videos/tubing-notcher-tn-250.php New Shrinker / Stretchers http://www.bii1.com/metal-forming/shrinker-stretcher.php $995 New 36" Throat Powered Bead Roller http://www.bii1.com/videos-pages/bead-roller-br18E.php Click Here For Quality Metal Fabrication Equipment |
#4 |
i second that
#5 |
Old School HAMBer
I would imagine that the actual bendier for the exhaust is reasonable...it's the "draw through" part that makes it get exciting.
Do You guys have anything that will adapt My Hossfeld number 2 from manual to air over hydraulic, or something similar? The worlds toughest rowing machine is about to get used again, and since I use 1-3/4 .180 wall, ....I could use some help.
#6 |
Senior Member
i think just about any rotary draw bender could have a mandral attached, it just requires a place to mount the mandrel and of course a mandrel, i built my own hydraulic mandrel bender to bend 1-1/2"dia, 1/16" wall staniless, made my own mandrel, i would think it would take alot of effort the operate a manual mandrel bender.
#7 | |
Alliance Member
Quote:
__________________
Quality Engineered Components Early Hemi Parts, Pieces, Tech EarlyHEMI and Flat 6&8 Trans adapters Complete Machine Shop Services |
#8 | |
Alliance Vendor
Quote:
__________________
#9 |
Newbie
Hossfield hydraulic attatchment:http://www.hossfeldbender.com/toolin...attachment.php
attatchment for air (hoist) type ram roe JD2 and Protools bender: http://copperheadfab.com/index.php?a...%20Accessories ebay dies to bend 3/4 or 1/2 tube in a cheap HF bender: http://shop.ebay.com/merchant/moto9ll new cheapie HF tube roller $159:
#10 | |
Alliance Vendor
Quote:
__________________
#11 |
Newbie
was just throwing it out there for those looking to do large radius bends.
#12 |
Alliance Member
thanks for posting
lets hear it for a guy who shares useful knowledge of his trade on the board. |
#13 |
Location: Duluth, MN (Hey, Al....where's that global warming ?)
I have used my Hossfeld #2 hydraulic bender for over 30 years and it's pretty much bulletproof. Of course, like any machine, it has its limits. One of these being its inability to make smooth bends on thin wall tubing.
I've often thought about packing some sand into a piece of 1 1/2" Dia. X 16 Ga. tubing to see if that might help. Has anybody tried this ?
__________________
JohnnyFast (aka SJFast) Fenders ? We don't need no stinking fenders !! |
#14 |
Alliance Vendor
The secret to bending tube successfully (no ripples, wrinkle or kinks) is to make sure the tube wall is thick enough to support being bent at a given radius. This is why roll cages and tube chassis can be bent with a simple open rotary draw bender.
If the tube is not thick enough (like most exhaust) it will require a mandrel inside of the tube to support it as it is being bent. Without a mandrel, it will be like trying to bend a pop can. It will just crush. I have heard of guys using sand to bend exhaust to large radius, but I have never seen any pictures of any tight radius bends (like headers) that look any good.
__________________
#15 |
Super Moderator
Tightest/most realistic radius for 1 3/4" .125 wall tubing and the method used to get it?
#16 | |
Senior Member
i would say that in the same amount of time it would take to use sand to make bends in two pieces of 1-1/2" dia. 1/16" wall tubeing you could build and install a mandrel on your Hossfeld bender.
Quote:
#17 |
Grenade Inspector
I have a hydrualic bender for heavy stuff,
and an old Laco manual bench mounted machine for thin walled, it's just like a scaled up version of the thing plumbers use to bend very soft thin walled copper, only you bolt to a bench and it's made from heavy iron and got a big handle. makes lovely smooth bends in 16swg but the radius of the bends is quite large,and it's quite physical, larger diameters require the handle to be extended to about eight feet to be able to pull the bend smoothly, but the results are good. Firm down the road has a fancy machine which can be programed to make whole exhaust systems, but when it comes to high performance stuff they still pack the pipes with sand and bend the pipes using a manual machine very like the one I use. I like that Harbour Frieght Tube Roller, what a great little machine for making hoops, what diameters and wall thicknesses does it work best with ? |
#18 | |
Alliance Member
Quote:
![]() ![]() I've found their cylinders to be questionable quality, I've had better luck at Agri Supply or Northern....
__________________
I have gotten grief for pointing out that the white, speckled stuff on chicken shit is still chicken shit. I will continue to do so... Chili Phil |
#19 |
Alliance Vendor
5.5" or 6.5" are pretty common bend radius' for 1 3/4' x .125 wall. Any simple open rotary draw bender can bend it. You will just need the correct die set.
__________________
#20 |
Senior Member
When using .120 wall DOM for a cage where the minimum wall required is .120 what are the chances that the wall will be under spec on the outside edge of your bends?
Are you better off going with at .134 wall tube? |
| Thread Tools | |
| Display Modes | |
