Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 |
Alliance Member
I call bullshit on the " bump steer "
#22 | |
Old School HAMBer
Quote:
Was this a multileaf spring salesman?
__________________
Crease Barons "In the end its all about the friends you make while your here." Collin Casey |
#23 |
I used a 72 Nova rear end, it literally bolted right in and gave me around 5 inches of drop. I could add blocks and drop it more but would need a notch.
__________________
I am a roar, a blur and a finger. |
#24 | |
Senior Member
Quote:
The point isn't that monoleafs will cause bump steer, while "regular" stacked leafs won't.......... The issue is that monos LOWER ride height, and that a lowered ride height can affect clearance and steering geometry. Lowering a straight axle front end significantly without making an effort to restore proper geometry to the steering linkage steering is likely to produce some bump steer. I assume that if you are "calling bullshit" then you understand what bump steer is and what causes it(?) |
#25 | |
Senior Member
Quote:
58Fridge100, The story you have just seen is true, the names have been changed to protect the innocent. I like your signature line and that's a fact. |
#26 |
Grenade Inspector
ok so im just wondering if i do a mono and drop axle in front that should give me about a 6-7 inch drop (using 3inch drop axle and 3-4 inch mono's)
__________________
blood sweat and tears =truck youll love for ever and say "it is apart of me and im a part of it" |
#27 |
Grenade Inspector
if the spring change didnt change the angle of the drag link it would not bump steer no matter the type of spring. if it is a straight shot from the pitman arm ( arm coming from box ) to the arm at the spindle ( level or close, not angled up or down ) then you wont get bump steer unless you have alot of suspension travel and real soft springs that let the drag link achieve that angle we dont want when you hit a big bump or drop into a big pothole. if you do have the radical angle on the drag link ( higher at spindle on lowered car...lower at spindle on raised 4x4 ) when the axle moves up or down yet the axle cant move forward or backward ( just straight up/down )the distance between the spindle and the draglink gets shorter or longer by maybe an inch or more. try it with a pencil or something. hold one end in your fingers and hold the other end down at a 45 degree angle with your other hand. as you move the end on the down side up and down ( alot ) you will see the distance between the 2 ends gets longer and shorter between your two hands as the free end swings in an arc up and down. the more the pencil is close to level the less this distance changes if you move the free end up and down. if the draglink has the radical angle or as you hit a large bump and that distance between the pitman arm abd spindle increases or decreases if you are holding the steering wheel tight it will push or pull on the spindle making the car steer rt or left very quickly (bumpsteer) if you had a light grip on the steering wheel it rips the steering wheel from your hands because when the draglink moved it moved the pitman arm end instead of the spindle arm end ripping the wheel from your hands ( ripped hands, OUCH! ) instead of steering the car rt or left . in other words try to keep drag link level whether lowering or raising the car or truck. make any sense? WHEW! now i have a headache.
vaya con Dios Last edited by parksquijada; 01-09-2009 at 07:53 AM. Reason: sp |
#28 |
Senior Member
#29 |
Senior Member
my truck has a mono leaf in front but i want to put a drop axle on it. also i have a 55-57 car rearend is the 72 nova the same width? . thanks billy
#30 | |
Senior Member
Quote:
Great looking truck. I have been debating whether to go with a copper color on mine. |
#31 |
Grenade Inspector
58fridge100 i have that article and thats why i was wandering but thanks for all the info. also if i do a 4inch drop in back will it make the ride level since the back is higher or if i do the drop the back and do just the drop axle? what do you guys think
thanks for everything guys -kujo
__________________
#32 |
every situation every angle is different even on the same vehicles.
It is purely a problem of geometry, your own personal geometry on your vehicle not a question of materials or name brands or even the style of suspension your running. it is an engineering, setup and adjustment issue. anything that causes the up and down of the suspension to push and pull on the steering causes bumpsteer. bad gas, mismatched brand names, and religious affiliation will not cause it. No amount of superstition hear-say or "what he did on his car" will fix it on your car. you have to learn about suspension and steering geometry if your going to change anything.from stock and be happy with it(unless your lucky) It cant turn the steering wheel in the bump because your hand is holding it still so it turns the tires instead. |
#33 |
Senior Member
As Tommy's drawing shows you need to keep the drag link parallel with the ground to keep the up and down arcs at a minimum and equal.
__________________
My Blown Flathead '49 Merc Website @: http://www.blown49.com |
#34 |
Old School HAMBer
There was a thread some time ago about a dropped straight axle setup (think it involved "flipping" the axle over the springs) where the builder moved the steering box up about six or so inches to tame the bump steer. Might be in the tech archives?
#35 |
Senior Member
also the greater the distance of up and down travel in your suspension is what
increases the amount of bump steer you will have if your geometry is incorrect, if you had no movement then the angle of your drag link wont matter, no sway bar can allow bump steer to occur, poor shocks can as well, so my point is if you can't get the geometry to work out so as much bump steer is eliminated as possible then keep the ride stiff and bump steer won't show up. |
#36 |
Newbie
I have a 4 inch dropped axle with mono's and cross steering in my '46.. Absolutely no bump steer. Drag link is very close to parallel with tie rod. Also have reversed eye mono's on rear.
| Thread Tools | |
| Display Modes | |
