Go Back   THE H.A.M.B. > Archives > Tech Archive
Reply
Thread Tools Display Modes
Old 10-06-2004, 06:11 PM   #1
Dan
Senior Member
Dan's Avatar
Default BRAKES, ansen pedal question...
I have asked before to no avail but I'll give it another shot, maybe someone new can help - does anyone have a set of ansen (clutch and brake) pedals that they would be willing to make me a set of measured drawings of, I want to try and build a set-
online   Reply With Quote
Old 10-06-2004, 08:26 PM   #2
A-Bomb
Grenade Inspector
A-Bomb's Avatar
Default Re: ansen pedal question...
Yes , that is what we are using. This set up takes the 60-62 chevy truck master cylinder that has both brake and clutch outlets. If this is what you want, I will draw you up a print and send it to you. it doesnt look very hard to make. Dale
offline   Reply With Quote
Old 10-06-2004, 11:42 PM   #3
flt-blk
Old School HAMBer
flt-blk's Avatar
Honest just made a set for his truck. He copied an
origonal borrowed from Bass.
If he doesn't see this send him a PM, I bet he can measure
or take some pictures.
TZ
Old 10-07-2004, 12:13 AM   #4
Paul
Editor
Paul's Avatar
post them here would ya?
Paul
Old 10-07-2004, 10:21 AM   #5
Dan
Senior Member
Dan's Avatar
A-bomb that would be great I would like to see what you've, same with Honest-
Old 10-07-2004, 05:30 PM   #6
Rand Man
Old School HAMBer
Rand Man's Avatar
What do they look like? How do they work? More info please.
Old 10-07-2004, 06:14 PM   #7
Paul
Editor
Paul's Avatar
very basic three sided box with holes for the master to mount on the flat bolted to the firewall and a bolt going through the sides with two swing pedals hanging off it.
bracket
bolt
two cleavis'
two pedals
some older car mags, Hot Rod, Car Craft etc, will show them in Moon ads. etc.
Paul
Old 10-07-2004, 08:57 PM   #8
tommy
Old School HAMBer
tommy's Avatar
If you use the Chevy truck m/cyl, don't forget to swap the cylinders innerds. The brake cylinder has the residual valve and your clutch will be slow to return if you don't swap the insides.
Old 10-07-2004, 11:25 PM   #9
Paul
Editor
Paul's Avatar
here's a Moon version from '63
Click image for larger version
Old 10-07-2004, 11:30 PM   #10
Paul
Editor
Paul's Avatar
here's a pair of Ansen singles
Name:	580606-ansen pedals.jpg
Old 10-07-2004, 11:40 PM   #11
fab32
Alliance Member
fab32's Avatar
Paul, Thanks for posting that. I'm thinking anyone handy at fabrication could come up with something with that drawing. You could "scale" it to fit your application. Just remember to keep the pedal ratio correct, or you'll end up with a stiff pedal and little braking or lots of pedal travel (or the need to pump the pedal) to get the needed action.
BTW, slave cylinders of different configurations can be had at any of the circle track supply houses. Maybe someone here can post a source, or just call Speedway Motors.
Frank
Old 10-07-2004, 11:44 PM   #12
fab32
Alliance Member
fab32's Avatar
Also your local NAPA store has a listing for the master cylinder and slave cyl. that was used in the GMC/chevy truck application.
Frank
Old 10-08-2004, 12:33 AM   #13
dabond
Grenade Inspector
No pics of the pedals, but here is the underhood view of my old Minor. I used the old Ford cylinders.
Old 10-08-2004, 10:36 AM   #14
Dan
Senior Member
Dan's Avatar
cool picture 60's style! that will help, I think all I probably need to do is get the m/c (or gasket if there is one, dont remember now if I saw one in the moon ad) for hole spacing and the rest should be pretty easy. I think I understand pedal ratio pretty well, the pushrods though - dont they need to be any specific length?
Old 10-08-2004, 11:45 AM   #15
Dan
Senior Member
Dan's Avatar
can anyone provide these dimensions?
back of mount to centerline of pivot bolt hole? (the upper dimension lines on my drawing)
center of brake pedal pad to clutch pedal pad (the lower dimension lines in my drawing)
how thick of plate should I use?
what to use for pushrods?
how thick material for the pedal arms?
anyone tell me how big and how far apart the big holes for the m/c are? how big and where to locate the bolt holes on the m/c?
On 60's drawing there are two holes at location B and location C, why?
Old 10-08-2004, 12:26 PM   #16
41ChevyTrucker
41ChevyTrucker's Avatar
cool topic. building your own pedal assembly from scratch would be nice because then you can get them to fit perfectly. A little bit more work than I can handle right now so I ended up buying a set.
You can probably get some good dimensions off of the wilwood website.
http://www.wilwood.com/Products/Peda...mtmc/index.asp
Old 10-08-2004, 12:48 PM   #17
Rand Man
Old School HAMBer
Rand Man's Avatar
Anybody know how much one of those rebuilt Chevy master cylinders costs without a core? New Willwood clutch and brake master cylinders cost around fifty bucks each. The new slave cylinder is about fifty-five from www.daymotorsports.com
Old 10-08-2004, 01:05 PM   #18
alchemy
Alliance Member
alchemy's Avatar
napaonline.com has them for $31 plus $3 core, remanufactured.
Old 10-08-2004, 01:19 PM   #19
Rand Man
Old School HAMBer
Rand Man's Avatar
Wow! I'm more interested now. Somebody get me some dimensions. I could manufacture a few sets of these if there's an interest.
Old 10-09-2004, 10:38 PM   #20
A-Bomb
Grenade Inspector
A-Bomb's Avatar
here are the dimentions of our pedals. Sorry, I could not get the dia. of the two large holes. You can use your master cylinder as a guide for these and also the holes that bolt it to the firewall. The master cylinder mounting bolts go through the firewall and the pedal bracket holding it all together.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
