Reply
Thread Tools Display Modes
Old 11-12-2008, 09:09 PM   #1
striper
Old School HAMBer
striper's Avatar
Default 235 Blue Flame - 3/4 race cam
I met an old guy at the parts shop this morning who just finished a '40 Chev. He was talking about building another engine and some speed equipment he has for it. But he said he didn't know what cam to use. He said no-one has a 3/4 race cam for 235s anymore. I know nothing about them but said I found it unusual given their popularity in their day.
Can anyone give me info on what's available so I can pass it on to him?
Pete
__________________
VULTURES
Australia
http://www.readersdigest.com.au/most-trusted-professions-2013
offline   Reply With Quote
Old 11-12-2008, 09:12 PM   #2
HEATHEN
Old School HAMBer
Default Re: 235 Blue Flame - 3/4 race cam
Iskenderian still sells cams for 235s. So does Patrick's in Casa Grande, AZ (I believ he sells Howard's cams). Nielson Cams will regrind his original cam. You mentioned a '40 Chevy; if it's still got the original engine, I doubt that Isky or anyone else has a core for it, since Chevrolet enlarged the cam journals in 1954. If anyone wants a hot cam for a '37-'53 engine, they'll probably have to have their stock cam reground.
Old 11-12-2008, 09:39 PM   #3
Human Fly
If he knows what he wants, Wade cam's will do anything you want. They are local http://www.wadecams.com/
Old 11-12-2008, 09:58 PM   #4
Stovebolt
Old School HAMBer
Stovebolt's Avatar
Quote:
i've spoken to them about my 6's too.
did you know they developed the XU1 cams with holden, so they know a thing or two about 6's and cams.
They do Flathead cams for one of the flathead boys in victoria, so "Do yourself a favour .......!"
__________________
Doing all I can to keep 'em inline
Old 11-12-2008, 11:08 PM   #5
Snarl
Senior Member
Snarl's Avatar
For starters, you need to know what year the engine is.
Clifford does/did offer camshafts for the small journal engines.
Howard F298 should still be available for the later large journal engines. Try Patrick's for that. I have it in my 261, and with the right gearing it is a nice cam. It's about as big as you would want to go for the street without having to notch the pistons. Careful about how much you deck the block and mill the head also.
__________________
Aluminum without fins is like a Playboy without pictures...
Old 11-13-2008, 08:44 AM   #6
Road Runner
Senior Member
Road Runner's Avatar
Patrick's offers cams from Delta Cams in Tacoma/Wa.
If the original cam is still in good shape, Delta will regrind the original cam to whatever grind pattern they offer for about $50.
Give them a call - they really know cams for these engines and have excellent service.
Delta grinds have a lot less overlap than the original Chevy and old Mcgurk race grinds and are more symmetrical.
I have their 254 advertised duration in/ex grind on my 261 (.060 bored, 9.0 cr) which holds torque up to 3000 rpm and gives peak HP around 4000 rpm.
To get good HP above 4000 rpm on a well breathing and built 235 get at least 264 adv. duration at the exhaust. If you keep the intake at 254 you still get good idle and low end torque for the street.
The 254/264 in/ex 'Bulldog' grind is very popular for the later full pressure 235s and is also offered by Tom Langdon.
__________________
On the road every day...
1948 Chevy Coupe - 261
1952 Chevy Truck - 235
Old 11-13-2008, 09:01 AM   #7
gas pumper
Old School HAMBer
gas pumper's Avatar
Patrick knows his stuff, he recommended a cam for my 235 back in the early 90's, a Howard. Maybe M4F? Anyway, it needs to idle a little high, like 800, but will pull great off idle and run strong to over 6000, but seems to not help ET to run over 5000. You can chug around town at 1000 in high if ya want to be quiet. A great cam.
Old 11-13-2008, 09:11 AM   #8
Road Runner
Senior Member
Patrick's used to carry the M4F howard cam which is very similar to the stock 261 grind.
It's recommended for the earlier pre-54 235s but doesn't do anything for the later 235s.
Sounds like you got a hotter cam than that in yours.
Patrick's doesn't offer Howard cams any longer, as they don't offer cams for these engines any longer.
Not sure about that.
__________________
Old 11-13-2008, 09:22 AM   #9
TagMan
Alliance Member
TagMan's Avatar
The term "3/4 cam" really has little to no significance. Back then, there was very little math / science involved in the aftermarket cam business. It was trial & error development - a cam shape found satisfactory for street performance, but not as "hot" as a "full race" cam racing, was called a "3/4 race" cam.
Old 11-13-2008, 09:38 AM   #10
repoguy
Senior Member
repoguy's Avatar
Whenever someone, when referring to their ride, has ever tried to tell me that it had a "3/4 race cam", that's pretty much been a solid indicator that they are completely full of shit.
__________________
Is there a problem officer?
Old 11-13-2008, 11:17 AM   #11
panic
For an owner this is generally true - the same person will tell you "it's bored and stroked" - he has no idea what that means, and doesn't know that you do.
OTOH, if it's just an enthusiast, they're repeating what they heard from someone who hasn't been under a hood for 40 years.
I've been doing this for a long time, and that was a dead giveaway that you weren't in the loop in 1964.
BTW: you should tell the cam grinder about anything you're doing to the engine (compression increase, replacement pistons, high-lift rockers, big valves, split exhaust) or chassis (4 speed, automatic, stall speed, axle ratio) to get the full benefit of his experience.
Old 11-13-2008, 02:34 PM   #12
Mr. Creosote
Grenade Inspector
Mr. Creosote's Avatar
Is there a rule of thumb for the fraction of the cam? I know its meaningless but couldnt you say cams in the 260 duration range would be 1/4 race.. 270 range duration 1/2 race.. 280 range duration 3/4.. 300+ would be full race??
__________________
Who'd 'ave thought, thirty year ago, we'd all be sitting here drinking Chateau de Shlasseler, eh?
Old 11-13-2008, 02:45 PM   #13
repoguy
Senior Member
repoguy's Avatar
Quote:
Originally Posted by panic View Post
Is anyone out there interested in a product I'm working on?
Direct replacement high performance intake valve for the 216/235/261, better flow, lighter weight, larger head diameter than the original, no special machine work required to install, fits the original valve guide, uses the original spring, collar and locks, length adjusted for high lift cam.
You should start a separate thread.
A lot of guys around here with inline Chebbies.
__________________
Old 11-13-2008, 03:10 PM   #14
6inarow
Senior Member
6inarow's Avatar
Direct replacement high performance intake valve for the 216/235/261, better flow, lighter weight, larger head diameter than the original, no special machine work required to install, fits the original valve guide, uses the original spring, collar and locks, length adjusted for high lift cam.[/quote]
How is that going to help the head flow better?
Old 11-13-2008, 03:52 PM   #15
gear jammer
Grenade Inspector
gear jammer's Avatar
Quote:
235 chevy? runs strong to over 6000 rpm?, we must be talking about another motor!
__________________
kept her tuned up too !!
Old 11-13-2008, 03:55 PM   #16
FATT STRIPES
Grenade Inspector
FATT STRIPES's Avatar
Quote:
as i was reading this thread this was the first thing that came to mind.
i remeber several times in the parts store when , what the board refers to as "gold chainers" would ask for a 3/4 cam. i had no clue what they meant
__________________
Matt "FATT" Jones
www.pinheadlounge.com/FATT
FATTStripes@gmail.com
Old 11-13-2008, 04:38 PM   #17
gas pumper
Old School HAMBer
gas pumper's Avatar
Quote:
No I ain't bullshitting ya, .050 off the head, .050 off the block. 848 head a little cleanup in the ports. Neway cut valve seats, .060 over bore. flat tops, Total Seal rings, M4F cam, big cap HEI, full flow oil filter, Fenton headers. Offy intake w/ 2 "B" Rochesters.
There was a video on the Hamb last year of me running at Island against the Gold Duece, All you could hear in the sound was my 6, all the way to the end of the track. And the 32 is a little hemi with open headers.
Old 11-13-2008, 05:44 PM   #18
HEATHEN
Old School HAMBer
It's just an archaic term that actually was used by some cam grinders in the '40s/'50s. I've got a N.O.S. Wolverine regrind for '55-'56 Chevy 265s that proudly declares that it's a "3/4 race" on the box. Its modern equivalent is an RV/torque grind, more or less.
Old 11-13-2008, 06:01 PM   #19
striper
Old School HAMBer
striper's Avatar
Yeah guys I know the 3/4 cam thing is a generic and very non-specific term. I did say this guy was an old guy and I think he is basically a restorer. I didn't go into the specifics of his motor or car for that matter but figured it would probably be easier to get some info for him on here than for him without this great resource.
Oh, for those who asked the motor is a 56 or 7.
I guess if the guy knew about cams and motors in general he would already have known that he could go to a local grinder like Wade and specify what he wants. The fact that he doesn't does not mean that he shouldn't be allowed to put a cam in his car that will give him some performance and that I shouldn't ask the question on his behalf.
To you guys who offered some solid information. Thanks. I'll follow up some of the leads and pass them on.
Pete
__________________
VULTURES
Australia
Old 11-13-2008, 06:47 PM   #20
panic
Of course, you're right.
How could that possibly help.
What was I thinking.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
