Reply
Thread Tools Display Modes
Old 11-05-2008, 01:51 PM   #1
51ChevPU
Senior Member
Default 727 Torqueflite cooler line question
I received my 78 Dodge torqueflite back from the rebuilder and we're now getting ready to run cooler lines. If memory serves me correct, the cooler lines are on the drivers side, contrary to the Ford and GM set-ups, which I understand are on the passenger side. A colleaque of mine swears that it should be on the passenger side. There are two bolts on that side that could act as coolers, so now I'm begining to doubt myself. Can any of the mopar guru's chim in and give me the guidance I'm looking for. Please confirm which side the cooler lines are located on. Thanks in advance for your assistance.
offline   Reply With Quote
Old 11-05-2008, 02:04 PM   #2
blackmopar
blackmopar's Avatar
Default Re: 727 Torqueflite cooler line question
if not answered before this afternoon, ill confirm and get back at ya - at work now
Old 11-05-2008, 02:07 PM   #3
skunx1964
Alliance Member
skunx1964's Avatar
drivers side, one near front and one near back
__________________
- micah
Savages Car Club
Jax, FL
myspace.com/skunx1964
myspace.com/savagescarclub
Old 11-05-2008, 02:16 PM   #4
willysguy
Senior Member
willysguy's Avatar
Quote:
Correct!
Old 11-05-2008, 02:20 PM   #5
Ratmotor
Alliance Member
Ratmotor's Avatar
The fittings on the other side are for testing pressures.
Old 11-05-2008, 02:28 PM   #6
skunx1964
Alliance Member
skunx1964's Avatar
ya, theres a lot of capped ports on there....
__________________
- micah
Savages Car Club
Jax, FL
Old 11-05-2008, 02:31 PM   #7
ajmopar
Senior Member
ajmopar's Avatar
Driver's side
Old 11-05-2008, 02:40 PM   #8
51ChevPU
Senior Member
Gentlemen: Thank you very much for your response. I can continue the project without hesitation. Thank you again.
Old 11-05-2008, 03:23 PM   #9
swifty
Over here in Oz they're on the passenger side. Does that confuse you LOL
Old 11-05-2008, 05:28 PM   #10
30dodgeboy
30dodgeboy's Avatar
The front port is the oil from the converter out going to the cooler, and the rear port is the return from the cooler going in to the lube circuit.
After a complete rebuild, I recommend filling the torque converter with as much oil as possible before start-up. I also recommend overfilling the trans by about an inch, otherwise once the converter is filled the trans oil level will be down off the stick. Overfilling it also makes it a little easier for the pump to pull in (up) the oil.
Another tip - because of the valve body design, the torque converter on these transmissions does not fill well when in Park but does fill when in Neutral. That is why it says what it does on the dipstick.
__________________
WANTED: 1930 Dodge parts
Vintage drag meet!
July 18 19 20, 2014 Bryon, IL
www.meltdowndrags.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
