Reply
Thread Tools Display Modes
Old 10-30-2008, 07:21 AM   #1
galaxieguy
FNG
Question Autolite 3X2 Setup?
Has anyone ever tried to use Autolite 2100 Carbs in place of Holley's for a Ford FE 3X2 (tri-power) setup? I'm having dificulty setting up the linkage correctly... Any suggestions?
offline   Reply With Quote
Old 10-30-2008, 08:22 AM   #2
exwestracer
Old School HAMBer
exwestracer's Avatar
Default Re: Autolite 3X2 Setup?
Keep in mind the 3X2 setups only idled on the center carb, and the outers only opened under hard acceleration. You're going to need to plug the idle ports on the outer Autolites. I believe the outers did not have power valves either (?).
You will need a slider on the center carb where the linkage goes to the outers, and the outers will need the throttle arm length shortened so they can "catch up" as the center carb comes full open.
__________________
Words of Wisdom from an old master...
Old 10-30-2008, 08:52 AM   #3
R Pope
Old School HAMBer
There was a good how-to on just that subject in Hot Rod mag a few years ago. Maybe someone has a copy.
Old 10-30-2008, 09:58 AM   #4
galaxieguy
FNG
Thanks.
Old 10-30-2008, 10:11 AM   #5
tommy
Old School HAMBer
tommy's Avatar
Quote:
If you have the correct carbs, I'm pretty sure the linkage is reproduced. It goes down the drivers side across in front of the front carb and then back up the pass side to the carb. Original linkage parts show up on Ebay pretty often. You can even get new carbs for that set up but pack a wallet.
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
Old 11-02-2008, 04:51 PM   #6
Jalopy Jim
Senior Member
Jalopy Jim's Avatar
Dearborn classics sells the Blue Thunder linkage for the Autolites in a 3-2 setup along with the air filter , carbs and intake. $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
__________________
NORSEWOODS woodworking
http://www.amazon.com/gp/browse.html...A2ARWVW5926VUX
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
