Reply
Thread Tools Display Modes
Old 03-09-2009, 06:46 AM   #21
Ed ke6bnl
Grenade Inspector
Default Re: how to lift a truck cab off the frame by yourself
taking the body off my el camino gantry in front and air cond. condeser lifter in rear
__________________
1950 F1 street rod
1949 F1 stock v8 flatty
1948 F3 parts truck
1953 Chevy 3100 AD project 2B on 85 S10 chevy frame
1972 El Camino chopped 4"
1968 Mustang coupe
1953 Mercury wagon project
Ed ke6bnl@juno.com
Agua Dulce, So. Calif. 70 Miles N.E. of Los Angeles
offline   Reply With Quote
Old 02-15-2010, 09:59 PM   #22
Yellowrr
Yellowrr's Avatar
I attached a 4x4 across an existing rafter, attached 2 more vertically under the horizontal 4x4, and hung 2 chainfalls to the horizontal 4x4 (the chainfalls were FREE, that's why!). I put a 2x10 through the doors and put some 6x6 bocks on top to lift the cab a little higher.
The only problem so far is moving the Dakota under the 49 cab to fit them back together. You have to move the whole truck just to align it with the cab since the cab only moves vertically. If I were just pulling the cab off, it would work like a champ.
I did borrow a friend's engine hoist earlier tonight, so I'll have to try your method
MoparMan4GZUZ!!! But it appears that the angle of the hoist through the window may not work. I may have to remove the doors and try again...
Click image for larger version
Name:	FEB 4 2010 024 SZ.jpg
ID:	900921   Click image for larger version
Name:	FEB 15 2010 012 SZ.jpg
Old 02-15-2010, 11:07 PM   #23
applekrate
Senior Member
applekrate's Avatar
This is a good thread for me. After already fitting a 5.9 Cummins and 6 speed into my '59 F-350, I have decided I wish to to pull the cab for some body work, welding and painting of the cab. Trying the figure out the best way to do it.
Some of these ideas are helpful. I'll post pics when i do mine too.
Steve
Hosting-
8th annual Nostalgic Show & Go! April 11 Phoenix
www.nostalgicshowandgo.org
__________________
2nd Phoenix Drag Reunion
3,29-15
Wild Horse Pass
Old 02-15-2010, 11:58 PM   #24
1950coronet600hp
Senior Member
1950coronet600hp's Avatar
Don't forget.... camper jacks work too
__________________
No trees were killed to send this note but a large number of electrons were terribly inconvenienced
Old 02-16-2010, 12:51 AM   #25
CrusadersNV
Grenade Inspector
CrusadersNV's Avatar
has anybody done a 49-54 chevy car? i was actually going to start a thread asking this but since one has already opened then what the hell!
__________________
North Van Crusaders C.C.
Old 02-16-2010, 09:53 AM   #26
rustyhood
rustyhood's Avatar
I love this!!! just goes to show where theres a will theres a way!!!
I raise mine with Budweiser.....Call the buddies over raise the body off Then tell the drunk bastards to leave before they cause more work for you! No dissasembly no storage space taken.
__________________
Cheap tools, Bloody knuckles, Cold beer.
.........."Old School Requirement"..........
Old 02-16-2010, 09:57 AM   #27
wildearp
wildearp's Avatar
I have used the same method with the engine hoist. I also hang several rims with tires on the back side of the hoist to counterbalance it, especially if I extend the boom a bit..
__________________
Simple solutions to complex problems.
Old 02-16-2010, 11:02 AM   #28
FoMoCoPower
Old School HAMBer
FoMoCoPower's Avatar
Hah,try doing a unibody Ford!
Old 02-16-2010, 12:15 PM   #29
PonchoJohn
Grenade Inspector
This is handy- I'll be removing a cab soon...
Old 02-16-2010, 02:13 PM   #30
MBog
Outside I use a forklift and a long 4X4 between the door windows, inside, the same 4X4 and a block & tackle from the ceiling...
Old 02-16-2010, 09:05 PM   #31
bobj49f2
Senior Member
bobj49f2's Avatar
Old 02-16-2010, 10:33 PM   #32
auto shop
Grenade Inspector
auto shop's Avatar
All you need is two stop sign post and four jack stands and a floor jack. Raise cab with jack , slide sign post under cab put stands under post. Raise each side a notch at a time. Remove rear tires and slide frame out from under cab.
__________________
Put your safety glasses on and pay attention!
Old 01-01-2011, 12:22 AM   #33
ONE CRUSTY ONE
Alliance Member
ONE CRUSTY ONE's Avatar
Quote:
Originally Posted by bobj49f2 View Post
absolutely the greatest. they say a picture is worth a thousand words.
Old 07-02-2011, 06:43 AM   #34
BigBadBuford
FNG
Have any of you built a gantry crane setup out of pressure treated lumber? I was thinking about getting some 6X6's or laminating some 2X10's to make a setup for a chain fall/winch. I want to pull the cab, bed and engine/trans for a frame swap. I have a cherry picker but some of these ideas require a good bit of luck to keep the user out of the ER..
Looking for "safe" ideas.
Old 07-02-2011, 07:18 AM   #35
flatheadfever
Alliance Member
flatheadfever's Avatar
Inside the garage I drilled a hole in the ceiling and dropped a short length of heavy chain down. On the upstairs floor I ran the biggest steel rod I could fit through the link. One for the front and one for back. That gave me something to attach the come-a-long to.
The second one not so much engineering. A 2x10 across the inside of the trunk.
__________________
Injection is fine but I would rather be blown!
Old 07-02-2011, 07:39 AM   #36
Harko
FNG
Harko's Avatar
Quote:
Originally Posted by willie57 View Post
This is how I did mine.
And mine on a tired night about 11 pm , it was real easy to but that there dent in the roof by jacking too far
Old 07-02-2011, 07:56 AM   #37
Hoodlum Rocky
Grenade Inspector
Hoodlum Rocky's Avatar
Cool way of showing that, i also love the change in daylight, all in a day,s hard work!
__________________
Have sawzall will travel!!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
