Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 09-27-2008, 06:50 PM   #1
Chris Casny
Old School HAMBer
Chris Casny's Avatar
Default ≈≈≈TECH, Hot Rod, Cowl steering, and steering column≈≈≈
This is the cowl steering set-up I've done on my model a coupe, here is a link to the whole thread http://www.jalopyjournal.com/forum/s...dreadman+coupe .
I did cowl steering because I'm using a Buick nailhead engine, that didnt leave enough room for a F-1 or F-100 box.
I built a "hoop" out of heavy walled 2" round tubing, that attaches to the frame with 6 bolts to ensure maximum strength for the steering box.
Once I established, placement for the box (in this case a 1966 Mopar model), I fabricated mounts, so the box could be firmly fastened to the "hoop".
Next step was to cut the stock pitman arm. All that's needed is the splined end.
The "end" was then welded to a heavy walled round tubing, making sure the, the ID was big enough to receive the 1 3/16" socket, required to tighten the 7/8" nut.
I can't stress enough, that if you have any doubts about your welding abilities you should consult a professional.
The other end of the sector shaft was drilled for 6 holes and threaded, and the drilled to allow the socket to pass thru, again, this end was welded to the shaft. Again, this piece is only about 3.5" long, but is, just about the most important piece, safety wise, when it comes to cowl steering.
A pitman arm was fabricated, out of 1/2" thick cold rolled steel. It received 6 corresponding holes.
Then it was bent so the tie rod end would clear the body.
__________________
I know nothing
offline   Reply With Quote
Old 09-27-2008, 06:50 PM   #2
Chris Casny
Old School HAMBer
Default Re: ≈≈≈TECH, Hot Rod, Cowl steering, and steering column≈≈≈
Next, the custom steering column.
It occurred to me, that there were 6 holes, on the steering box, that seemed, ideal, to be tapped and then hold the flange for the steering column.
Using a 3" washer, I drilled 6 corresponding holes, in order to bolt the flange to the box.
For the steering column, I decided to use 1 1/2" stainless "stripper pole", you know the smooth stuff, not the brushed kind, easier on the hands.
Mine ended up being 12". It was welded, to the flange.
The other end of the column needed a bearing, to hold the 3/4" shaft.
I found one that didnt quite fit the 1 1/2" column, but pressed it in anyways, and therefore created this kind of flared, end look.
For the box end, I purchased a 3/4", 36 spline coupler, to which the shaft would be welded to (spot welded shown here).
The steering wheel end of the shaft, was machined down with my crappy lathe, to 5/8" and then tapered and keyed to accept an early Ford steering wheel (not pictured here).
Here is the full set-up shown outside the car.
In the car
Safety, is number one here, I TIG welded everything making sure, the pitman arm cooled down properly after bending, etc. your life is on the line here, but if you did everything right this will be a good solution.
__________________
I know nothing
Old 09-27-2008, 06:51 PM   #3
povertyflats
Old School HAMBer
povertyflats's Avatar
You sure do nice metal work for a woodworker.
__________________
I like old engines and stuff--
Facebook-- Paul Kruse
www.gopovertyflats.blogspot.com
Old 09-27-2008, 07:12 PM   #4
Glen
Senior Member
Glen's Avatar
nice job on the cowl steering there are about 4 good threads on that process now and each one is a little different. Thanks for posting.
Old 09-27-2008, 07:19 PM   #5
Mullda
Grenade Inspector
Mullda's Avatar
Great post! Beautiful work. Thanks for sharing.
Old 09-27-2008, 07:45 PM   #6
cheezburgers
FNG
cheezburgers's Avatar
Great Job .....Thank ya much
Old 09-27-2008, 08:10 PM   #7
Noland
Senior Member
Noland's Avatar
Hey maybe if you win techweek they can give you a colored camera for a prize
Came out really nice though
__________________
RUSTY hemi Model A Coupe build
http://www.jalopyjournal.com/forum/s...d.php?t=647364
Old 09-27-2008, 08:28 PM   #8
bct
Senior Member
bct's Avatar
ooohhhhhh....thats how its done!!!!!!!!good job
__________________
a time to weld , a time to grind.
Old 09-27-2008, 08:34 PM   #9
Fenders
Old School HAMBer
Fenders's Avatar
Nice job.
Uhhh... bump steer?
__________________
Faux-tina can be bought.
Patina must be earned.
Old 09-27-2008, 08:37 PM   #10
Chris Casny
Old School HAMBer
Quote:
Originally Posted by That guy with the coupe View Post
Nice job.
Uhhh... bump steer?
I've done this three times, no bump steer.
7" pitman arm (center to center), 8" steering arm.
__________________
I know nothing
Old 09-27-2008, 10:41 PM   #11
zibo
Senior Member
zibo's Avatar
Nice job.
Uhhh... bump steer?
I think there is a special technique to drive a cowl-steer car because of the bumpsteer inherent in the design.
Once you learn to not white knuckle the steering wheel, the car will drive fine,
and what is called bumpsteer isn't an issue.
TP
Oh yeah nice work!
__________________
holey chit
http://perichbrothers.blogspot.com/
Old 09-27-2008, 10:54 PM   #12
Dreddybear
Old School HAMBer
Dreddybear's Avatar
Nice job.
Uhhh... bump steer?
Bump steer sucks on a race car, at the limits of traction you don't want sudden jerks on the stering wheel. On a street car a little bump steer will be okay. If this car has measurable bump steer it will be minor enough that he won't notice or care.
Car is looking AWESOME Chris!
__________________
HOLLEY 94 INFO
MY COUPE BUILD
Old 09-27-2008, 10:57 PM   #13
Royalshifter
Alliance Member
Royalshifter's Avatar
Beautiful job Chris as always.
__________________
"I LIKE KUSTOMS"
Old 09-27-2008, 11:13 PM   #14
Malcolm
Old School HAMBer
Malcolm's Avatar
Very, very nice work, Chris! Some great ideas there - thank you.
I really like that steering wheel, too - is that a Lincoln or Mercury wheel?
Malcolm
__________________
www.instagram.com/hoesing
Old 09-27-2008, 11:34 PM   #15
1935Ron
Senior Member
1935Ron's Avatar
Nice!!! you don't mind if I copy it..............
Old 09-28-2008, 12:02 AM   #16
KIRK!
Old School HAMBer
KIRK!'s Avatar
You win! Pick out your new tool from the sponsor.
__________________
Pics of your mom naked at killKIRK
Old 09-28-2008, 04:38 PM   #17
captainjunk#2
Old School HAMBer
what a great tech article , good build
Old 09-28-2008, 06:47 PM   #18
2deuces64
2deuces64's Avatar
Nice job, this answers some questions I had. I'm starting on my cowl steering this week using a bmw box.
Old 09-28-2008, 08:32 PM   #19
marodder62
Grenade Inspector
Great tech. I was wondering how to do the steering column on mine and now I know. What tap size did you use for the 6 holes on the steering box?
Jerry
Old 09-28-2008, 10:39 PM   #20
sko_ford
Old School HAMBer
sko_ford's Avatar
i know which one i'm voteing for and copying almost completly
__________________
Little Pages Tech Group
thee suedes
Occupy a Hurst shifter
Quote:
Originally Posted by thunderbirdesq View Post
Grind until bitchin
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
