here we go.... TECH: Lake Headers with simple tools. TECH: cheap and easy door sill plates TECH: Model A coupe rain gutters Simple trig for frame cuts, etc. Straight Axle, Gasser Style TECH: Sandblast Windshield Cutting How To Plus Video TECH -*** model A front crossmember *** Technical Light Tech - a reprise TECH: Salvaging a '32 Grille Insert TECH: Tach Tech, or how to update your vintage sun tach TECH: Another method for filling trim holes TECH: Barking Spiders TECH: Build a floor support TECH -*** model A front crossmember *** Garage tech: Exhaust fan ≈≈≈TECH, Hot Rod, Cowl steering, and steering column≈≈≈ Tech week, Recycle SBC oil pump into a usefull drill pump Po Boy panel edger ***TECH - "Z"ing a Model A frame*** Inexpensive fire alarms Chopping a 50 Chevy 5 window TECH.....235 HEI Dizzy TECH: how to join steering shafts Overhead Lift trolley system under $300. Technical Corvair dash in a fat fender Ford Technical wheel skates Trailer tech TECH: Mechanical Clutch Linkage how to build NICE model a door hinges for cheap Tech: Frame mods without a jig. TECH-----Trunk lid skin removal----TECH TECH: Butter Dish Air Scoops for Drum Brakes Technical TECH circa 1954: Build the Polynesian! Technical TECH - How to PROPERLY load your trailer Technical Hemi Tech: Fitting an SBC Water Neck Technical Custom hood for my Model A TECH Overflow bottle design and construction **Tech: Build your own 32 frame rails** TECH: Saving a Model T Coupe dash (Part 1) Technical TECH Analog gauge repair theory and application. Electric RockStar wipers for cheap skates Mandrel Bend Exhaust Protractor ***TECH: 32 RPU Project - Roadster-izing a $50 Cab in 3 Simple Steps*** ***TECH*** Turn your Model A into a 4 season car TECH: Saving a Model T Coupe dash (Part 2) TECH Build a FOLDING Spray rack Simple tech #1 better floor jack TECH: Installing a Powertrax Lock-Right differential where's the chuck key?? Technical TECH: Brighter Dash Lights Technical TECH: Cheap power windows for any car TECH: How to add an AUX input to your stock Radio TECH: Fix a stuck Radio Pushbutton Clamp on split manifold TECH - Press Forming Tube for Exhaust Flange .
If I miss one just reply in here with it and I'll add it to the list... Please don't PM me with new Tech threads, reply here please.
You weren't kidding. You really were waiting to start this thread as you contribution to Teck week. You're THAT guy. And We cannot be more grateful for it!
Here's one for a replica model A crossmember. Thanks Ryan and Baileigh!! http://www.jalopyjournal.com/forum/showthread.php?p=3156436#post3156436 TP
Always loved tech week... and now even more! What a great prizes! I'll be headin' to my garage with camera, NOW!
My tach tech thread: http://www.jalopyjournal.com/forum/showthread.php?p=3158101&posted=1#post3158101
Here's my first contribution, Salvaging a '32 Grille Insert... http://www.jalopyjournal.com/forum/showthread.php?p=3158360#post3158360 Thanks, Neal
Dunno, is garage tech considered O/T? http://www.jalopyjournal.com/forum/showthread.php?t=297233 Whatever, if it works for someone else, glad to make a contribution.
Here's a quick contribution,hopefully it will help somebody. http://www.jalopyjournal.com/forum/showthread.php?p=3160092#post3160092
I want to make sure I understand tech week.I'm pretty new here to H.A.M.B is there a thread explaining the rules. How do you need post your tech article? The prizes are to outstanding not to give it a shot.
Post it just like a normal thread but put "Tech:" at the beginning of the title and I'll catch it and put it in the list here. Pretty easy. At the end of Tech Week Ryan will have someone choose the best one.
Heris mine low cost overhead lift/trolly set-up http://www.jalopyjournal.com/forum/showthread.php?t=297750
Hmm, I see others on that list that were up previous to this Tech Week. Mine is not as good as others listed so I wouldn't be the top pick anyway...I'm just sayin'. Actually, others are "just sayin'" to me in emails etc. and wondering. I don't really pay that close attention.
No sweat here at all. Whatever the date. I vote for Dreadman's steering box tech. That should definitely be a permanent listing in the Tech Archive.
