Reply
Thread Tools Display Modes
Old 09-20-2008, 06:41 PM   #1
axeman39
axeman39's Avatar
Default Building a pressure sand blaster
I want to build my own pressure pot sand blaster but I'm not sure whats needed. I have a 25 gallon tankon wheels that stands uprite with a 2" threaded steel cap w/oring seal. I know I will have to drill a hole in the bottom and weld a bung there, the top already has a fitting for an air line to be connected. do I need a special gun or will a regular gravity feed gun work? How much pressure should be in the tank? will I need to run 2 air lines one to the tank and one to the gun? Anyone build there own? comments and suggestions needed!
__________________
HOTRODDERS THE FIRST RECYCLERS.
offline   Reply With Quote
Old 09-20-2008, 06:52 PM   #2
Tman
Old School HAMBer
Tman's Avatar
Default Re: Building a pressure sand blaster
www.pablaster.com
We had a thread going here last week or so, this looked the best to me. Fiddy has used one and said it rocks. My info should get to me in a couple days!
__________________
www.compulsionrodandcustom.com New website up! Product listings updating weekly!
Old 09-20-2008, 06:55 PM   #3
stealthcruiser
Old School HAMBer
stealthcruiser's Avatar
Someone on here built one.
"Frankenblaster" I think it was.
__________________
Chuck
Old 09-20-2008, 07:10 PM   #4
3Mike6
I took a cheap siphion feed gun, used a 10 gallon SS tank I had, ran a "dip tube" to the bottom, the on top of the dip-tube I attached the siphon feed.
Then, I teed off the air line and ran another tube into the tank and regulate it to 20PSI...I guess it's sort of a "siphon-assist-presure-blaster"
Works pretty good.
Reason I like the siphon feed more than pressure, is there is rarely a chance of warping and sheet metal, it's slower than a pressure pot, but much faster than just a regular siphon feed.
Old 09-20-2008, 07:11 PM   #5
Tman
Old School HAMBer
Tman's Avatar
Thats the thread, search frankenblaster!
__________________
Old 09-20-2008, 07:18 PM   #6
3Mike6
Quote:
LOL...I just searched and found the thread...looks to m\be made just like the one i made.
Shoot...should have put the plans on the 'net for 9.99 too
Old 09-20-2008, 07:49 PM   #7
Crusty Nut
Alliance Member
Crusty Nut's Avatar
I built my own frankenblaster. Also known as a PABlaster. It works pretty good.
__________________
Singley Speed Shop
707-599-2315
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
