Reply
Thread Tools Display Modes
Old 09-09-2008, 04:24 AM   #1
beaulieu
Grenade Inspector
beaulieu's Avatar
Default is hydraulic floor jack oil same as brake fluid ?
does anyone know if you can use brake fluid in a hydraulic floor jack ?
it seems like it should be the same stuff but I am not sure,
is there a hydraulic only fluid ?
thanks for the info, I am sure I am not the only one wondering
Beaulieu
__________________
WTD:356 Porsche project ,anything considered ,rusty ,crashed, incomplete OK+Fiat 500-600+Citroen van
offline   Reply With Quote
Old 09-09-2008, 04:31 AM   #2
HEMI32
Old School HAMBer
HEMI32's Avatar
Default Re: is hydraulic floor jack oil same as brake fluid ?
no ... most floor jacks use an ISO 32 hydraulic oil ... using brake fluid, tranny fluid, or motor oil will screw up the seals.
Old 09-09-2008, 04:31 AM   #3
weemark
weemark's Avatar
no brake fluid normally ruins the seals for some reason. use hydraulic fluid - should be easy to find and is cheap.
Old 09-09-2008, 04:44 AM   #4
beater32
Grenade Inspector
beater32's Avatar
I use air-tool oil.No probs
Old 09-09-2008, 05:26 AM   #5
skidmarks
Old School HAMBer
skidmarks's Avatar
brake fluid will swell up the seals, old used car lot "fix" for a slipping automatic transmision, put a little brake fluid in it , swell up the seals and get it to stop slipping...................for enough time to see the brake lights disappear.
jack oil is high pressure hydraulic oil, then there is UTF and a lot of others. some hyd. systems use 10w non detergent.
online   Reply With Quote
Old 09-09-2008, 05:40 AM   #6
BigNick1959
BigNick1959's Avatar
I just asked a friend last weekend what he used in his jacks and he said he's used ATF for years. I guess if your going to the store anyway, how much more $$ can hydraulic cost then ATF.
__________________
www.garageno7.com
Pinstriping,lettering plus
www.nick-solovey.artistwebsites.com
photography.
Old 09-09-2008, 08:39 AM   #7
C9
C9's Avatar
Location: Kingman, Arizona - The place on the way to other places....
I used ATF in a Walker.
Took 20 years before the leaks started.
None of the 4 jacks leak now, but if one did I'd probaby replace the factory oil with USA made jack oil.
__________________
Sailing the turquoise canyons of the Arizona desert.
C9
Old 09-09-2008, 08:43 AM   #8
King Tut
Newbie
King Tut's Avatar
Ive always used hydraulic jack oil and never had a problem..My Craftsman jack is over 25 years old and still going strong..with proper maintenance it should last a 100 years!!!!!!!!!!
...Bruno...
Old 09-09-2008, 08:46 AM   #9
fab32
Alliance Member
fab32's Avatar
I had a hydraulic and air tool repair business for a number of years and the most common reason for having jacks go bad was the use of brake fluid. The reason has already been stated.................JUST REMEMBER IT
Frank
__________________
"What we got here is failure to communicate"
Old 09-09-2008, 10:22 AM   #10
Barrelnose pickup
Alliance Member
Barrelnose pickup's Avatar
32 weight hyd oil is what you want,any hyd repair shop would probly give you enough for your jack,have a nice day
Old 09-09-2008, 11:34 AM   #11
beaulieu
Grenade Inspector
beaulieu's Avatar
thanks guys ,,,,,
I get it....NO BRAKE FLUID...
Beaulieu
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
