Can anyone tell what the upper and center stainless might of came out of? This is the passenger side door of my 56 effie. I want to find matching pieces for the drivers door. Thanks
lower bent piece looks just like 64 SS impala door trim. only one i know of with that bend like that. they came in pairs per door, one bent up, one bent down, but i think they're identical. top piecemight be 65 impala, hard to tell.
The F-100 trucks did have a stainless molding in the Custom Cab series. That however doesn't look like the stock ones. What it looks simular to to me is 49 Merc door panel trim. The Merc trim has I belive 3 ribbs on about a 1/2" wide trim and an angle similuar to what I see. Some where in my stuff I belive I still have some. The Top piece I don't have a clue. If you like I would dig out what I have and give you the degrees of angle the bend is. The Wizzard
Got the Merc door molding. It is s.s. of course and has 3 ribbs in it. It measures 1/2" wide and sweeps up at 42 degrees. It has a steel strip crimped in it from the back with little fingers 1/2" long that go through the upholstry and bend over to hold it to door panel. The obvious differance is that it doesn't come to a point where the angle change is like the one in your photo. This one is a radius larger than a 2 lb. coffee can. I doubt they are the same. I can't seem to master photo posting on this web site but if you would like a photo P.M. me your e-address and I'll send you a photo of it. The Wizzard
