Reply
Thread Tools Display Modes
Old 09-03-2008, 03:05 PM   #1
TheFrenZ
Senior Member
TheFrenZ's Avatar
Default Chevy 350 Distributor Question...
At what position,viewed from the front of motor,is cylinder #1 on the distributor cap on a 350 Chevy ? Some sources say it's at 5 o'clock...some say it's at 7 o'clock.I guess it's pretty easy to answer for most Chevy guys on here...your help is much appreciated.Thanks !
offline   Reply With Quote
Old 09-03-2008, 03:09 PM   #2
wetatt4u
Senior Member
wetatt4u's Avatar
Default Re: Chevy 350 Distributor Question...
If the driver side is the right side the number one plug is the first one on the right,at the front of the car
The rotor button should be pointed to that plug which is at about 5 oclock
__________________
God Bless America.
Old 09-03-2008, 03:18 PM   #3
docc
Senior Member
docc's Avatar
Old 09-03-2008, 03:24 PM   #4
primed55
Grenade Inspector
primed55's Avatar
number 1 on the cap is where ever you put it... Find TDC then drop your dist in, where it points is number one. By using a long screw driver to adjust the oil pump rod you can make it where ever you want but i'd say most do it like the pic above.
__________________
The Devil made me do it the first time, the second time I done it on my own.
Old 09-03-2008, 03:29 PM   #5
Drive Em
Senior Member
Quote:
Thanks for posting this because it amazes me that people still think the rotor has to point to the number one cylinder.
Old 09-03-2008, 03:30 PM   #6
36-3window
Old School HAMBer
36-3window's Avatar
in reality , you can make any one of the positions number 1
on a points distributor i always make the one right before (based on the clockwise rotation of the rotor) the points window number 1 because that is the way it was on the very first SBC i ever worked on. later on i saw other SBC's with number 1 the position after the points window. maybe chevy made a change , or maybe i have been wrong all these years
Old 09-03-2008, 03:33 PM   #7
docc
Senior Member
docc's Avatar
.. but i'd say most do it like the pic above.
Old habit...I like to do mine all the same..just never found a reason to do it different.
Old 09-03-2008, 03:42 PM   #8
hotroddon
Old School HAMBer
hotroddon's Avatar
Pretty much accepted that the Drivers Side of a Car is ALWAYS the Left side as viewed from the drivers seat. It's been that way since the dawn of time when people started getting confused about which was which. When someone says right side they mean the same as passenger.
Unless of course you are in England and they say Far Side and Near Side, which pertains to the curb! Not sure what the Kiwi's and Skippy's do. Japanese have a different way to but we don't speak Japanese.
Not trying to rip you, just hoping to make it less confusing for others.
Oh, and to answer the original question, Primed55 is right but there is something to be said for making it uniform, especially if you buy pre made plug wires as moving the position could make the wire lengths wrong
__________________
As I hurtled through space, one thought kept crossing my mind
every part of this rocket was supplied by the lowest bidder. ~ John Glenn
Old 09-03-2008, 08:54 PM   #9
TheFrenZ
Senior Member
TheFrenZ's Avatar
Thanks everybody !
Yes,I know it "basically" can be put "anywhere" you want...we just needed a starting point as the timing on a friend's car can't be adjusted properly.Timing is way off...somewhere around 25 degrees before TDC at idle,vacuum device pulled and plugged...motor currently has a Delco Remy distributor with mechanical and vacuum advance and that device already gets in contact with the firewall...can't be turned anymore further to get the timing closer to the desired settings.
Another friend's car has the dizzy installed like on the pic shown below...#1 in the 7 o'clock position (viewed from the front of motor)...
We already checked everything on the motor...compression is fine on all cylinders,adjusted the valves,points and condenser look good and are adjusted to 30 degrees dwell...but no way to get the timing to 6-8 degrees BFTDC.The vacuum device on the dizzy get in contact with the firewall...channeled Model T Coupe...that's why I asked for the position of cylinder #1 on the dizzy cap (timing adjusted correctly) to find out if there maybe is a major misconstruction etc. made by the pre-owner...
Old 09-03-2008, 09:08 PM   #10
zbuickman
zbuickman's Avatar
Quote:
Originally Posted by TheFrenZ View Post
Thanks everybody !
That pic is wrong in more than one way...... Pontiacs dists spin CCW
Old 09-03-2008, 09:26 PM   #11
Old School HAMBer
squirrel's Avatar
It's pretty easy to get the distributor gear off one tooth when you drop it in, that's probably what happened.
Also Chevy did move around the #1 position on the cap over the years. I like to try to put it where Chevy intended, if only to make life easier for the next guy who works on the car.
Click image for larger version
__________________
Jim Forbes
my shtuff
online   Reply With Quote
Old 09-03-2008, 09:47 PM   #12
Thumper
Senior Member
Thumper's Avatar
Quote:
Yeah....that pic ain't right. The cylinder numbers are off on a few of those listed too.
__________________
"This job is just a skidmark in the drawers of life"
Rusty Ole Pile of Shit Car Club
Old 09-03-2008, 10:15 PM   #13
TheFrenZ
Senior Member
TheFrenZ's Avatar
Quote:
That's what I think too,thanks squirrel.We will check that tomorrow and post an update.Motor will get a new dizzy in near future anyway.
Btw,what's the "correct" timing for a 350 SBC ? Some people say this...other people that.I know it also depends on engine mods,but I mean generally.
What does the HAMB say ?
Old 09-03-2008, 10:18 PM   #14
Old School HAMBer
squirrel's Avatar
Generally around 6 to 12 degrees BTDC. But since every distributor is different, a reasonable way to set it is to set the total timing, then see what initial timing is, and make a note of it.
To set total timing you need dial or readout timing light, disconnect vacuum advance, rev the engine up high enough that timing doesn't advance any more (usually 2000-3000 rpm) and set the timing to around 34 degrees.
__________________
Jim Forbes
my shtuff
Old 09-04-2008, 12:28 AM   #15
dave lewis
Alliance Member
dave lewis's Avatar
Sounds like you cannot retard the timing enough....So move all the wires 1 position CLOCKWISE on the cap, then yank the vac can away from the firewall.
Rotating toward the firewall on sm.blk.chevy= timing retard.. Rotating toward the intake = timing advance..
BTW, Not only does pontiac dizzy rotate CCW BUT also the # 1 cyl is the RIGHT (psgr) front..And yes, it is not the furthest forward cyl like most other motors #1 !!
Dave
Old 09-07-2008, 08:36 PM   #16
TheFrenZ
Senior Member
TheFrenZ's Avatar
Time for an update...we had the distributor out and installed it so cylinder #1 on cap is at 3 o'clock which gives us plenty of clearance to retard the timing.Problem is the motor runs like shit when timing is set at 6 to 8 degress BTDC.Tried everything form 0 to 12 degrees.
It runs much better if we advance the timing again.It runs best with the timing mark at around 12 almost 11 o'clock on the balancer.Yes,it's that far off !! Balancer is correctly installed...both valves fully closed,compression stroke and timing mark is on TDC.
However,the engine runs "good" with the timing advanced WAY too much...anyone has an idea what´'s going on here ?
Old 09-07-2008, 09:07 PM   #17
Old School HAMBer
squirrel's Avatar
did you check to see that the TDC mark on the damper is actually top dead center of the #1 piston? there were at least 3 variations on timing mark locations on small blocks over the years...could have a mismatched timing tab and damper.
__________________
Jim Forbes
my shtuff
Old 09-07-2008, 09:27 PM   #18
1oldtimer
Old School HAMBer
1oldtimer's Avatar
Quote:
Originally Posted by docc View Post
if you have hei it's like the pic if not then it's at the 7 o clock position. but you really can put it anywhere as long as the firing order is right.
__________________
#1 Post killer
Old 09-07-2008, 09:50 PM   #19
Larry T
Old School HAMBer
Larry T's Avatar
If you're using the old points style distributor, you can drop the distributor in with the rotor contact parallel to the vacuum advance unit. Use the cap terminal that is right next to the "window" for number one. That is the stock position for the number 1 terminal. The timing will be close enough for the engine to start. Then you can set the timing with a light. 10 degrees BTDC will put you in the ballpark.
I like to wire distributors like they came from the factory. Makes things easier to troubleshoot and work on.
Larry T
Name:	distributor cap (2).jpg
__________________
Goldchainers CC
Old 09-07-2008, 10:12 PM   #20
old dirt tracker
Senior Member
seconds on doing it the factory way. like doccs picture. any thing else is asking for trouble if you forget or some one else has to figure it out.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
