Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 |
Too cool man. I could spend days reading all those patents. Seeing how inovative old Henry was just blows my mind.
__________________
Wanted: 30-31 Model A Tudor or Pickup upper door skins (beltline up), ok if they need lots of TLC. |
#22 |
Alliance Member
I don't remember all the details of the story, but at one time you had to submit a working model of whatever it was you wanted to patent. This caused a big storeage problem at the patent office. Some paper pusher desided since "EVERYTHING" had been invented there was no need to make working models. Wonder what year that was?
#23 |
Senior Member
I started a thread like this a while ago sadly noone seemed to care. There are a lot of aftermarket stuff on there too.
http://www.jalopyjournal.com/forum/s...d.php?t=268816 I like this one for hubcaps that don't turn with the wheels. Patent 2935361 http://www.google.com/patents?id=I1t...ad=0_1#PPA1,M1
__________________
#24 | |
Alliance Member
Quote:
Rear was independent as well, circa 1920's
__________________
"They just pissed off the angriest guy in Wayland" (from the lovable Dumb Whore.) |
#25 |
Everything new is old again!
Now I'm going to have to hear how airbags and that weird split I-beam/tube front axle are 'traditional'... and they'll have the patents with dates to back up the arguement!!!!! ![]() Damn you Google!!!! ![]() ![]()
__________________
If you're gonna take the candy, you have to go for a ride in the car. - Henry Rollins |
#26 |
Old School HAMBer
Pandora's box!
__________________
RETRO Spec. (tive) -Getting to where you're going by knowing where you've come from. |
#27 |
Alliance Member
I'd like wallpaper made out of old patent drawings...so much neat detail everywhere.
__________________
Bruce |
#28 |
Grenade Inspector
Just when I thought I'd run out of internet......this is too cool !!!!
#29 |
Senior Member
So when does Bruce from Alliance Member to HAMB God? He and Doc earned it.
Thanks for turning us on to this. |
#30 |
Old School HAMBer
Here's a few things from Robert M. Roof (would love to see the head recast)...
1301007 Roof 16 Valve DOHC Head 1509611 Roof oiling system for OHC 1561666 Roof Chain Drive for DOHC And one that's a little OT... 1373432 Curtiss Valve Operating Mechanism (1921)
__________________
Looking for: Early Chev 4 parts Hupmobile wire wheels |
#31 |
FNG
__________________
"I don't believe in a government that protects us from ourselves" -Ronald Reagan |
#32 |
Alliance Member
A couiple of later lists...there is a lot of overlap due to my utter lack of organization, but each contains a few more discoveries:
Deuce Patents Engine: 1975837 Engine1921266 Early version Model B (Model A at 1875718) 2020405 Distributor 1963657 Distributor 1976178 earliest Mallory distributor 1998636 Porting 1908798 Coil 2086644 Henry didn’t want an oil pump! 2104178 Bohnalite 180…four barrel?? Chassis: 2037126 Chassis general design 1975836 Rear suspension 2020054 Chassis w/ odd features 1937965 Transmission axial 1937950 Late 18 rear end 1908745 Brake stuff 1908744 Brake linkage Grill: 1955470 Deuce grill! Early version 1888719 More. 1803761 Need to ship 500 Bangers? 1876903 Tube axle 1908744 brakes, axle Model A Patents Engine: 1875718 Full engine drawing…lube system 1873369 Ignition 1908786 Piston balancing machine 1908805 Generator 1898696 Commutator segment manufacture 1803761 Engine shipping 1803751 Air filter…non production Chassis: 1908745 Service brakes 1862105 (Experimental/non production) Cable brake actuation 1799292 Brake cross shaft/central linkage 1937988 Brake cross shaft 1955454 Brakes 1793920 Another experimental…Floater? 1873568 Brake drum forming and rolling 1772481 Totally non-production version of brakes 1850006 Early brake design 1803059 Speedometer drive 1862099 AA intermediate shaft 1810195 Spare lock 1781503 Radical non production chassis design 1716637 Gear manufacture –production or experimental? 1840881 1931 radiator shell 1763847 Bumpers and bracketry Body: 1783501 Windshield ventilator 1873607 Upholstery button retainer 1876923 Body polishing head 1998614 Hood pad 1963658 fuel pump stand 1758597 planetary trans…Ford invents the Powerglide! 2037126 ’32 frame 1975836 ’32 rear frame 1908744 ’32 frame, brakes front izzat axle tubular?? 2020054 ’32 chassis variants 1749807 BB type weights 1824810 carb rod joints 1975837 engine 1975837 flathead lifter variants 1875718 A oiling system 1921266 early version B oiling 1781503 Frame…odd 1749099 Early A trans 1937950 Model 18 rear 1802913 A carb GAV 1781502 A carb 1873569 One piece valve 2020405 ’32 distrib 1963657 Distributor, timing 2326113 crab distributor 2092269 distributor brake 1975885 bullet wire connector 1908745 brakes, guide plate 1908785 flathead spring compressor 1757493 instrument illumination 1888719 the beginning of the deuce grill 1955470 more on grill 1873369 A distributor 1803751 air cleaner…!!?! 1840881 1931 radiator shell 1908798 V8 coil 1975847 radio tuner 2279671 sleeves 2334917 opposed engine 1998611 water pump 2065065 rear engine…Ford invents the Volkswagen! 1993992 SOHC 2402543 polarity r distrib 1998612 bucket lifter 2057774 power brake/clutch 2020406 cast crank 1992677 casting process 2440812 sludge traps 2092291 torque tube center bearing 2317619 GP lamp 2231742 column shifter 2317654 ditto 2290927 ditto ditto 2086644 pumpless oiling 2372381 ashtray…’48 type 2088841 anti-sway 2088787 zephyr shifter 2037126 B chassis…close to production 2057774 Vac clutch 2669227 hemi 2286695 Asa Taylor valve assembly tool 1963658 fuel pump stand 1758597 planetary trans…Ford invents the Powerglide! 2037126 ’32 frame 1975836 ’32 rear frame 1908744 ’32 frame front 2020054 ’32 chassis variants 1749807 BB type weights 1824810 carb rod joints 1975837 engine 1975837 flathead lifter variants 1875718 A oiling system 1921266 early version B oiling 1781503 Frame…odd 1749099 Early A trans 1937950 Model 18 rear 1802913 A carb GAV 1781502 A carb 1873569 One piece valve 2020405 ’32 distrib 1963657 Distributor, timing 2326113 crab distributor 2092269 distributor brake 1975885 bullet wire connector 1908745 brakes, guide plate 1908785 flathead spring compressor 1757493 instrument illumination 1888719 the beginning of the deuce grill 1955470 more on grill 1873369 A distributor 1803751 air cleaner…!!?! 1840881 1931 radiator shell 1908798 V8 coil 1975847 radio tuner 2279671 sleeves 2334917 opposed engine 1998611 water pump 2065065 rear engine…Ford invents the Volkswagen! 1993992 SOHC 2402543 polarity r distrib 1998612 bucket lifter 2057774 power brake/clutch 2020406 cast crank 1992677 casting process 2440812 sludge traps 2092291 torque tube center bearing 2317619 GP lamp 2231742 column shifter 2317654 ditto 2290927 ditto ditto 2086644 pumpless oiling 2372381 ashtray…’48 type 2088841 anti-sway 2088787 zephyr shifter 2037126 B chassis…close to production 2057774 Vac clutch 2669227 hemi 2286695 Asa Taylor valve assembly tool
__________________
Bruce |
#33 |
Old School HAMBer
Great to see this thread after so many years!
__________________
"ANNUIT COEPTIS NOVOS ORDO SECLORUM... AD MAJORUM DIA GLORIUM" |
| Thread Tools | |
| Display Modes | |
