Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 07-30-2008, 06:03 PM   #1
Sprout
Sprout's Avatar
Question How to remove overspray off of chrome.
The guy I bought my Falcon from thought he was a painter and painted parts of the car. Now I have overspray on almost all the window trim and on the bumpers. My question is how do I get it gone?
__________________
WTB a 60 Olds
or a 39-40 Mercury coupe or sedan
offline   Reply With Quote
Old 07-30-2008, 06:05 PM   #2
Iamagearheadru
Grenade Inspector
Iamagearheadru's Avatar
Default Re: How to remove overspray off of chrome.
A Claybar works good .........Meguiar's (Sp)makes a good one
Old 07-30-2008, 06:05 PM   #3
Fraz
Senior Member
Fraz's Avatar
scotch brite and some mineral spirits or lacquer thinner
__________________
"God knows i dont want to be a barfed-up poopnoodle!!! - Dynaflash 8
Old 07-30-2008, 06:07 PM   #4
vintagehotrods
Senior Member
vintagehotrods's Avatar
Some lacquer thinner on a shop rag and be very careful of sparks or flame
__________________
Editor of the Mid-West Deuces "Deuce Gazette"
Old 07-30-2008, 06:08 PM   #5
roundvalley
Senior Member
roundvalley's Avatar
Lacquer thinner and your sandwich clamp.
Old 07-30-2008, 06:12 PM   #6
SaltCityCustoms
Senior Member
SaltCityCustoms's Avatar
Very fine steel wool like 000.
__________________
Salt City Customs
Jeremy Owens
Syracuse, NY
saltcitycustoms@yahoo.com
Old 07-30-2008, 06:16 PM   #7
oilslinger53
Senior Member
oilslinger53's Avatar
rubbing compound or a medium polish followed by chrome polish and wax has always workd for me... or #0000 steel wool then polish&wax if its real bad
__________________
I think I breathed too much rust...
Old 07-30-2008, 06:19 PM   #8
confederate jack
FNG
i kid you not, a rectangular razorblade. a brand new one!!! use one side only. it will not scratch. i promise. if you use both sides, it will leave scratches, they are cheap little sharp blades, the other side gets burrs. it will work. 000 steel wool is good also. brush cleaner removes everything and is not caustic or acidic like that kleen strip stuff is.
Old 07-30-2008, 06:20 PM   #9
jahearne
Newbie
jahearne's Avatar
Whichever method you use, be careful with bits of stuff getting into new paint while it's still soft and curing. scotchbrite will scratch, fine steel wool doesn't scratch, but it leaves lots of tiny slivers of metal behind. A razor blade works great on glass, but again be careful of scaped off paint falling onto your new paint job; it'll melt right in if the paint is still curing.
__________________
John
CAUTION:
may cause uncontrollable productive flatulence!
Old 07-30-2008, 06:30 PM   #10
desertratrodder
Old School HAMBer
desertratrodder's Avatar
I always used brake cleaner on a rag..works great for getting grease spots out of carpet, too.
Old 07-30-2008, 06:32 PM   #11
jimmyv
jimmyv's Avatar
lacquer thinner works great followed by chrome polish. Razor blade will clean up the glass.
Old 07-30-2008, 06:41 PM   #12
Chad s
Senior Member
Chad s's Avatar
Laquer thinner will not do much at all to remove a 2k urethane primer. I have even tried urethane reducer and it wont "melt" the stuff.
I'd take the parts off of the car, and use some aircraft stripper.
Old 07-30-2008, 07:10 PM   #13
Tony
Alliance Member
Tony's Avatar
I use #0000 steel wool when cleaning chrome..Works great..
At least it always has for me.
Sometimes i'll use the #000 stuff, BUT only if needed and only in small spots that are being stubborn.
Aside from that, a quality paint stripper if have a serious overspray problem.
Chrome is easier to scratch than most people think. SOS pads will scratch the hell out of the plating, as will course steel wool..and using the wrong scotch brite pad will do the same especially if any real pressure is used.
Razor on the glass. easy, quick and works great.
__________________
WHO CARES!
"You are cordially invited to shit in your hat"
-Chili Phil-
Old 07-30-2008, 07:12 PM   #14
toddc
toddc's Avatar
Bingo! And a scotchbrite WILL scratch chrome. They're what you use to brush finish with.
__________________
Quote:
Originally Posted by Hnstray View Post
There is a not so polite suggestion that can and should be made to such people.
Old 07-30-2008, 07:13 PM   #15
Tman
Old School HAMBer
Tman's Avatar
Laquer thinner
or a claybar and windex.
Anything else will scratch
__________________
Open for business, website in developement
www.compulsionrodandcustom.com
Old 07-30-2008, 07:15 PM   #16
punkabilly1306
Old School HAMBer
punkabilly1306's Avatar
i have used one of those sanding sponges but a very old an dull one and then soaked in soapy water...and i mean soaked...worked really well for my, even worked on the overspray on the glass
Old 07-30-2008, 07:16 PM   #17
Iamagearheadru
Grenade Inspector
A Claybar is the easiest way to remove without worrying about being easy on it...unless you use it dry it will not scratch
Old 07-30-2008, 07:21 PM   #18
HHRM-John
Alliance Member
I have used oven cleaner and a plastic razor blade to effectively remove bad pinstriping jobs from cars and toolboxes, as well as overspray from windows and other areas. The fumes are terrible, though.
__________________
It is nice to be important, but it is more important to be nice.
Old 07-30-2008, 07:22 PM   #19
punkabilly1306
Old School HAMBer
Quote:
doesn't oven cleaner peel the actual paint as well, we have used that stuff at work to clean 40 year oil off of our machines and it takes it straight to the metal
Old 07-30-2008, 07:23 PM   #20
zbuickman
zbuickman's Avatar
shop rag and CRC green brake cleaner. if that wont touch it get some circuit board cleaner. that stuff is wickedit will eat spray painted graffiti off raw wood with out wiping it.....it just goes away
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
