Reply
Thread Tools Display Modes
Old 07-15-2008, 07:42 PM   #1
Abomination
Old School HAMBer
Abomination's Avatar
Default Stolen Tech: Make your own rotisserie (Pics & Plans)
I found this here:
http://forums.pelicanparts.com/showt...ighlight=Flank
Yeah, I know it's a 911, but this is about the rotisserie. Flank did an awesome job. It's his deal though, and if you have any questions, you'll need to PM him at the link above.
Anyway, here it is in it's entirety for your viewing enjoyment:
Hi all,
Here are some pictures of the chassis rotisserie for the early 911's.
I would like to say that if you are planning to put your car on a rotisserie, that you have most if not all of your sheetmetal work done and also if it's a Targa, make sure you have the body braced. I had made braces for some of the previous repairs and I used them now too.
The whole rotisserie is held together with 5/8" pins, and it can come apart easy for storage. The next picture shows these pins, and some gussets.
To raise and lower the tool I decided to use these 'farm jacks' over using hydraulic cylinders. I like the mechanical action of the jacks and raising or lowering the car can be done by one person.
I made an 'index wheel' that attaches to the yokes. By working in AutoCad, I was able to come up with a simple design that by using two brackets instead of one, I can posistion the car body in one of twenty positions. When the holes are running out on on bracket, they are just begining on the other.
Here is a picture of the rear yoke. Note that the whole thing can be taken apart. By breaking the yoke down into 'components', one person can easly attach it to your car, then you add parts to it, until it's complete.
and the front yoke.
Now, the momment you've all been waiting for, Let's get this car upside down.
The reason I wanted to make this rotisserie was to help with painting the chassis. Also later for installing the wiring harness and the suspension. But the main reason was to make applying the undercoating easier. By having the car body upside down and flat. The brush on coating will have gravity working with it instead of against it. How nice will it be to have the body like this.
Later in this thread, I'll post the dimension plans and more detail shots of the yokes, so you can build your own. I had to redo this thread because the first one had too many pictures!
Here is a link to the last thread detailing the front suspension pan replacement. From there you can keep going back and check out some of the earlier work, including a chassis jig. I'll close with a self portrait. I hope it doesn't make your computer crash.
Later, Flank.
__________________
Flank
Hi all,
Here are the demension plans that will help you get started making you own chassis rotisserie for the early 911's. The base for the roto is pretty basic and you can get ideas from the photos.
Here is a detail of mounting the sliding post to rest of the tool.
Here is a detail of the farm jacks used for raising the car body. I did not want the china made jacks so these are from HiLift and the model is EJ550. Do a search for HiLift and order online for $35.00 ea.
Here are the plans that I made up, so far.
and
and
I just lost my connection to the photos. So I'll post some more detail shots later.
__________________
Flank
offline   Reply With Quote
Old 07-15-2008, 07:42 PM   #2
Abomination
Old School HAMBer
Default Re: Stolen Tech: Make your own rotisserie (Pics & Plans)
Here are some more details. If you have any questions, just ask.
and from the back.
If I had to make this rotisserie over again, one change I would make is to mount the long tubing that connects the two ends under the tubing that the casters mount to. The wheels provide plenty of ground clearance to have the long tube mounted there. This way you would not have raise the car so far up to rotate it around. The length of the long tube would have to be increased by 8 inches overall to make up for the new location.
Here is a detail of the front yoke. Note that the car is upside down. This also shows the lower support bracket for the oil cooler that I made.
Here are two details of the rear yoke.
Look closely at the notches.
and finally a parting shot, showing the overall.
Thanks and I hope you all found this interesting.
Flank
__________________
Flank
Old 07-15-2008, 07:52 PM   #3
Vergil
Vergil's Avatar
Thanks for sharing, looks great.
Vergil
Old 07-15-2008, 07:54 PM   #4
Harris
Harris's Avatar
Cool looking, thanks for the info....
Old 07-15-2008, 07:58 PM   #5
Royalshifter
Moderator
Royalshifter's Avatar
Man that sure saves an aching back.
__________________
"I LIKE KUSTOMS"
Old 07-15-2008, 07:59 PM   #6
Hot Rod Ron
Old School HAMBer
Hot Rod Ron's Avatar
Good post. This should go too the tech section.
Old 07-15-2008, 08:08 PM   #7
rat bastad
Old School HAMBer
rat bastad's Avatar
Thanx for the info.
I am looking at fabbing one of these down the track. Apart from the fact that my back is trashed, Im looking forward to being able to wrench on my rides more comfortably AND get a better result than otherwise would have been the case.
Thanx for postin...
Rat
__________________
"IF IT WAS'NT FOR BAD LUCK I WOULD'NT HAVE ANY LUCK AT ALL"
Old 07-15-2008, 08:20 PM   #8
Abomination
Old School HAMBer
Is that even ethical? I mean, I did steal it from that other board. LOL!
I guess I DID quote/cite it properly.
~Jason
Old 07-15-2008, 08:35 PM   #9
breeder
Old School HAMBer
breeder's Avatar
kool! ohh and thanks for the pics jason...ohh thats right, you never sent them!!!!
__________________
Www.rustrevival.com
May 16th-17th 2014!!!!!! Hope ta see ya there!!!!!
Old 07-15-2008, 08:46 PM   #10
toddc
toddc's Avatar
Stolen Tech is the best kind of tech. Very cool.
__________________
Quote:
Originally Posted by Hnstray View Post
There is a not so polite suggestion that can and should be made to such people.
Old 07-15-2008, 10:05 PM   #11
Abomination
Old School HAMBer
Hey, I took 'em!
Been fixing my AC on the house. It's a hellofa a time for that to go, man...
Sent.
~Jason
Old 07-16-2008, 09:07 AM   #12
Abomination
Old School HAMBer
BTTT for the mornin' crowd.
~Jason
Old 07-16-2008, 09:13 AM   #13
Von Rigg Fink
Old School HAMBer
Von Rigg Fink's Avatar
that would sure make life easy
__________________
Goldchainers CC S.E. Michigan Chapter
Charter Member
Some guys could fuck up free lunch.
Old 07-16-2008, 09:31 AM   #14
Nitrofan
Newbie
Thanks for posting, that would be real useful in the shop.
Old 07-16-2008, 03:57 PM   #15
Stevie Nash
Alliance Member
Stevie Nash's Avatar
The million dollar question... what's the cost of materials?
__________________
Outsiders C.C.
Wanted: 1937 Nash Coupe
Old 07-16-2008, 04:00 PM   #16
Abomination
Old School HAMBer
That would depend highly on what you bought vs. what you found laying around and used, I guess.
~Jason
Old 07-16-2008, 04:03 PM   #17
RAMBLINMAN
Newbie
RAMBLINMAN's Avatar
Some good ideas there.
__________________
welders penetrate deeper....
Old 07-16-2008, 05:10 PM   #18
34toddster
Alliance Member
34toddster's Avatar
I actually had one similar to this one and I damn near killed myself and helper, when we rotated the car upside down it took off on it's own because it was really top heavy. It was a 64 full size Pontiac, I finally modified it so the arms that mount to the body dropped down to get the centerline of the car in line with the rotating head of the rotisserie. That way the weight is balanced whether the car is right side up or upside down. I don't think it would make much difference on a really lite car like an A or B model. I would suggest anyone building one of these to look at other designs that have dropped arms and incorporate them into this design. Thanks Abomination for the plans!
Old 07-16-2008, 05:12 PM   #19
FiddyFour
Old School HAMBer
i dig the railroad jacks for raising and lowering the height... lot nicer than holes and pins for sure. i had been kickin the idea around of building a rotisserie outta a pair of engine stands, got a couple ideas from this one that'll really help. thanks dude
Old 07-16-2008, 05:32 PM   #20
49ratfink
Old School HAMBer
49ratfink's Avatar
yeah... what 34 toddster said. there needs to be an adjustment so you get the cars center (weight wise, not inch wise) at the pivot point. the way he has it once you get a full size car body to a certain point gravity takes over and you are screwed.
there is a guy who sells them at swap meets around here. he made the mistake of having a nice drawing on his flier he hands out. so I took the flier and looked in my scrap pile and adjusted the design to fit the steel I had. I had to buy a couple of pieces of tubing that fit inside each other, everything else was scrounged. cost me about 30 bucks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
