Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 06-24-2008, 08:36 PM   #1
Henry Floored
Senior Member
Henry Floored's Avatar
Default Karol Miller and Y- Blocks
Here is a cut and pasted article of the great Karol Miller and his Bonneville exploits, enjoy......
FORD SUCCESS STORIES: KAROL MILLER ... BONNEVILLE LEGEND
By Ray Brock*
Our first meeting with Karol Miller took place in the middle of the hot, blinding expanse of the
Bonneville salt flats in August of 1956. None of the old time hot rodders who had been
participating yearly at the annual SCTA (Southern California Timing Association) National Speed
Trials knew anything about this soft-spoken Texan -- he just drove in one day near the start of the
week-long meet and asked for an entry blank.
Unlike most of the other Bonneville entrants, Karol wasn’t towing the car he intended to race, he
was driving it. He and a friend had decided to see what the famous salt flats looked like so they
threw a couple of sleeping bags in Karol’s 1956 Ford Victoria and left Houston for the 2000-mile
drive to western Utah. Karol was used to long drives though for his full-time job was operating oil
exploration teams for his father’s Houston-based drilling company and the test locations might be
all over the country, from Louisiana to North Dakota. When the two Texans and the Ford arrived
on the salt, there was already more than 25,000 miles logged on the odometer. A 3.23 rear axle
ratio was fitted to the car and an overdrive transmission was used. The O-D was strictly for
highway cruising, giving a 2.26 final ratio.
As Karol explained later, the 25,000 miles on the engine didn’t hurt his chances at all; they made
the engine nice and loose. During the few months prior to Bonneville, Karol had performed quite a
few experiments with the car and knew that it was running good. The pan had never been off the
engine but a fresh valve job had been given the cylinder heads. Ports and valve sizes remained
stock. An Iskenderian E-2 camshaft and spring kit were installed and an Edelbrock dual-quad
intake manifold was fitted with a pair of Holley carburetors. A Mallory ignition with centrifugal
advance weights was used in place of the stock distributor which used only vacuum advance.
Total spark advance was about 38º.
Karol used Ford cab-over truck carburetor bonnets on each of the four-barrels with flexible
ducting to the fresh air vents which passed beneath the inner fender panels on their way to the
passenger compartment. These ducts provided cool air directly to the carburetors for maximum
induction efficiency. As the car speed increased, so did the air pressure through the ducts so
jetting was complicated somewhat by the slight pressurization of the carburetors at high speed.
Karol experimented with jetting quite a while before he found the right combination.
Stock ’56 312 exhaust manifolds were used on the engine with a pair of cutout plugs fitted so the
mufflers could be bypassed by uncapping the head pipes 24 inches downstream from the
manifolds. The Ford chassis was stock except for a set of heavy-duty Monroe shock absorbers.
The rear spring shackles were reversed from their normal tension position to a compression
position, giving the rear of the car a noticeable forward rake. Stock street tires with most of the
heavy tread rubber buffed off by a retreading shop were pumped up to 60 pounds at the front, 50
pounds at the rear.
Since Karol Miller was an "unknown" to the predominantly West Coast entrants at Bonneville, no
particular attention was paid to the orange and white hardtop coupe as it pulled away from the
starting line on its first run. Some minutes later when the speed of almost 140 miles per hour was
flashed back from the finish line 2 1/4 miles away, many thought that perhaps a timing mistake
had been made. The speed was unheard of for a Ford sedan.
Hot rodders hadn’t thought anybody would have much success using the Y-block Ford engine
with the odd intake port arrangement but, all of a sudden, here was a Ford with 312 cubic inches
running in a popular sedan class that permitted from 305 to 488 cubic inches and it was beating
almost everybody. The only car that could hold its own was a ’56 Chrysler 300 with a 400-inch
stroker engine. These two cars battled for the whole week before the Chrysler emerged the
winner at 141 mph with Miller’s Ford runner-up at 139-plus. By the end of the week, everyone
knew who Karol Miller was and they were also starting to revise their thinking about Ford’s Y-V8
engine.
Although Karol Miller had been unknown to the regulars at Bonneville in 1956, he had already
earned a reputation as a sharp tuner of Fords on his own home grounds around Houston. His first
Ford was s 1949 coupe which he bought new and, in his own words, "just played around with it a
little to see if I could make it run better." Among the changes made were the installation of Merc
crankshaft and pistons to enlarge the displacement to 255 cubic inches. Carburetion, ignition and
other changes made Miller’s ’49 the scourge of the area and all those who had tried
unsuccessfully to take his measure on some of the long straight Texas roads were mighty happy
to see him join the Army early in 1950.
After Army duty, Karol bought a 1953 Ford with the then new overhead valve six. A short time
later Karol was back in the thick of things after he’d milled the head to up the compression,
installed dual carburetion, opened up the exhaust and a few other little Miller touches to aid
performance. It didn’t take the boys in the Houston area long to learn that Karol was back in
circulation because the I-block six proceeded to show its taillights to all the hot flatheads in town.
The next Ford was a 1955 model with the 292-inch engine. Karol installed T-bird heads which
had been milled and ended up with a compression ratio of about 9.5:1. A four-barrel carburetor
was also used. A few more Miller improvements and the ’55 Ford attained its proper spot as top
dog in the neighborhood. After the ’55 came the ’56 Vicky and that’s where we came in.
After shaking up contestants and spectators at Bonneville, Karol went home, made a few minor
changes to the engine and decided to take in the 1957 NASCAR Speedweeks event at Daytona
Beach, Florida, where speed trials were held on the hard packed sand each February. Since the
car was not of current model year and not strictly stock, it was required to run in the Experimental
class. Rough beach conditions held up the meet for several days before Karol got a chance to run
but when the time finally arrived, the Vicky set sail for a two-way average of 140.070 mph over
the measured mile. This speed placed Miller well up in the class standings ahead of many high
powered entries from factory-sponsored race teams.
During the waiting period from Daytona to the 1957 Bonneville Nationals in August, Karol made a
number of changes beneath the hood of his ’56. First of all, he decided to play it smart and quit
trying to compete against as much as 488 cubic inches in D class with his 312 and drop back to C
class for gas coupes and sedans. The class limit was 305 cubic inches for C class. Karol took a
292-inch block and crank, bored .060-inch oversize and came up with 302 inches. 1957 cylinder
heads gave the larger intake valves needed and Karol also fitted 1/8-inch larger than stock
exhaust valves to the heads.
With larger exhaust valves, the combustion chambers in the head crowded the valve closely and
would obviously cause restriction to gas flow. Karol opened the chambers out generously around
both intake and exhaust valves to improve flow and the lengthened chambers were then wider
than the cylinder opening. Carefully, the top of each cylinder bore was chamfered from the
chamber outline to a point just above the top of ring travel. This eliminated the ledge at the top of
the bore which extended into the enlarged chamber. All of the grinding to the cylinder head and
block gave an extremely large volume in the combustion chamber. To get the needed high
compression for maximum performance, Karol used Jahns deflector head pistons and then milled
the heads .100-inch to reach the desired ratio of 11:1.
Karol then selected an Isky cam for the engine but this time it was a "smoothie" grind with high
rpm potential and less torque than the E-2. Karol devised his own stroboscopic test stand to
check valve action at various engine speeds. In the single stall garage behind the family home,
Karol mounted a Y-V8 block on an old kitchen table, installed a cam, tightened down an old
cylinder head with single intake and exhaust valve in one chamber, used a pair of lifters and
pushrods to drive rocker arms actuating these valves, dropped a distributor in place and then
drove the setup by a small 3 hp four-cycle utility engine.
A battery supplied primary voltage to the distributor which operated in the conventional manner
but with only one secondary lead which was connected to a timing light. A V-belt from the small
engine turned the cam fitted with two sprockets to give a wider surface for the belt to ride on.
With this setup, Karol checked out dozens of combinations in cams, springs, valve weights,
rocker ratios, etc. Advancing or retarding the distributor gave stroboscopic viewing through the
timing light. By the time late summer rolled around and Karol was ready for Bonneville, he had
come up with a perfect combination. Both intake and exhaust valves were lightened the limit; an
Isky Ford inner spring and Isky Chevy outer, plus an Isky Chevy retainer and .060-inch shims
under the outer springs made the valve gear stable in excess of 7200 rpm.
The Edelbrock dual intake manifold was retained with four-barrel Holleys, but had been carefully
matched to enlarged ports. Fresh air to the carburetors was doubled in volume with two large
flexible hoses to each carburetor bonnet from openings behind the grille. The exhaust system
also came in for its share of attention as Karol attempted to "tune" for maximum power at about
6000 rpm. Individual 1 1/2-inch pipes 32 inches long from each port extended almost straight out,
through a long narrow opening in each front fender. A little rough on appearance but darned
helpful for performance.
Since Karol still didn’t have the finances needed for a second car to tow or trailer the Vicky, he
again drove it to Bonneville for the ’57 meet. Since the outer valve springs were almost coil bound
with the high rpm setup, horseshoe shaped shims .060 thick which had been fitted under the
outer springs were removed to lessen possible cam wear on the 2000-mile jaunt. Stock exhaust
manifolds were also fitted for the trip.
When Karol arrived at the salt, the first day was spent installing the spring shims, headers,
carburetor air ducting and setting the chassis up for minimum rolling resistance. Engine oil was
used in the transmission, overdrive and front wheel bearings. Wynn oil was used to thin out the
rear end lubricant. Rear shackles were reversed to raise the rear of the car for improved air flow
beneath the car. Trimmed down tires with little tread rubber were used with high inflation
pressures.
When everything was set to go, Karol drove the car up to the starting line and took off on his first
run. This time, spectators and contestants knew who he was and all activity stopped while they
watched. Through low and second gears, Karol twisted the engine up to a spine-tingling 7200
rpm and then shifted into high gear. 2 1/4 miles away at the finish line, the impressive sounding
Ford approached rapidly and then roared through the timing traps at a speed of 149-plus mph.
With the 3.23 gearing, engine rpm was about 6100.
The reason for the high rpm through the gears was to keep engine speed up within the best
power range after shifting. If shifted at less than 7000 rpm from second to high, rpm would fall
below 5000 rpm and the engine would not pick up speed.
Throughout the week of the ’57 meet, the Ford ran consistently near the 150 mph mark. The only
trouble encountered was a blown head gasket and once it was replaced, speed went right back to
its normal. By the end of the week, Karol Miller had set a new C Gas Coupe/Sedan record twoway
average of 150.097 mph for the flying mile. The speed was almost 13 miles per hour faster
than the previous record held by a Chevy. The 302-inch Ford with the impressive 7000-plus
exhaust tone was one of the sensations of the ’57 Bonneville meet.
Again the following February, Karol took in the Daytona Beach Trials but this time he went to an
even smaller engine displacement and then topped it off with a Latham axial-flow supercharger.
The engine was a 272 fitted with Karol’s special valve gear, reworked heads, an Isky blower cam,
the tuned headers, Mallory ignition and the Latham competition blower with four side-draft Zenith
carburetors. Running ten pounds boost, Karol shocked other contestants in the Experimental
class by averaging 153 mph over a rough beach and walked away with the class win. The ’56
Victoria was the fastest car on the beach in 1958. After the success shown with the blower, it was
only natural for Karol to retain the combination for the ’58 Bonneville Nationals. Since the use of a
blower automatically jumps cars one class under SCTA rules, the engine size was cut back even
further so that it would fall under the B class maximum of 259 cubic inches. Then, the addition of
the Latham blower would again raise the car into C class.
To drop the engine displacement to 259 inches, Karol used a ’54 Merc crank with 3.100-inch
stroke and then bored the block .010-inch over standard ’54 Merc bore (3.625) to achieve the
proper size. Again the engine was topped by the head, valve and cam setup worked out by Karol
on the table in his garage. Compression was held to 8.5:1 for use with the blower. With a smaller
engine displacement than he’d run at Daytona, Karol contacted Norm Latham for blower
information and switched to a unit that had fewer vanes at a slighter pitch for use at Bonneville.
When Karol rolled onto the salt for the ’58 meet, driving the car from Texas as always, the Ford
was again the center of attention. After a day of engine and chassis setup, Karol proved that he
still had the magic touch as the little 259 inch Y-V8 plus blower exceeded the 150 mph mark on
the first run. By the end of the week, Karol had raised his C class record slightly to 151.997 mph
and had a one-way qualification speed of 153.32 mph. At the 4300 foot elevation of Bonneville,
the lower boost Latham did not put out the pressure Karol had hoped for so he actually went
home unsatisfied although everybody else thought he’d done great.
The ’56 Victoria was retired from competition after the ’58 Bonneville meet and returned to strictly
highway use with a 312-inch engine until late 1959 when with 120,000 miles on the odometer, it
was sold to make way for a new 1960 Ford Starliner coupe. Karol really intended to quit racing
when he bought the ’60 Ford and it had the standard 352-inch engine with hydraulic lifters, power
steering and even air conditioning. By the time summer rolled around though, Karol got the urge
again and, in a matter of two weeks, put together an engine for another fling at the salt flats.
The 352 engine was bored .090-inch over to take stock Edsel replacement pistons. Edsels used a
.050 larger standard bore for 361 inches and with .040-inch oversize, a total of 368 cubic inches
was realized, placing the Ford in a newly established BX Gas Coupe/Sedan class with a
displacement limit of 370 cubic inches. Karol then borrowed a few engine pieces from a friend
who had purchased one of Ford’s 360 hp high performance 1960 cars. The 360 hp heads were
milled .030-inch to give a compression ratio of 11:1 and otherwise left stock. The four-barrel
aluminum intake manifold was used and equipped with a ’59 Lincoln four-barrel carburetor which
had larger capacity than the standard Holley. An Isky RR8000 cam and spring kit was installed
and these pieces were the only non-Ford parts used. Exhaust headers were the factory cast iron
items; distributor and wiring were 360 Ford.
As always, the car was driven to Bonneville, this time with the added luxury of power steering and
air conditioning. After arriving at the salt and passing through the inspection line, Karol drove it to
the pit area, changed tires, removed the power steering and air conditioning belts and made a
warm-up run. The car left the starting line with just a slight whisper from the stock dual exhaust
system and a few minutes later word flashed back from the finish line that the Ford had registered
a cool 150 mph -- with mufflers.
After bypassing the exhaust system and performing a little tune-up, Karol qualified for a record
run at 158.17 mph and then set a new record average of 157.902 mph. When the meet was over,
Karol slipped the belts back on for power steering and air conditioning and headed back to Texas.
Early in 1962, Karol sold the ’60 Starliner with 95,000 miles on the odometer and it was still going
strong.
We talked to Karol in May of 1962 and he was driving a Fairlane 500 with the 260-inch V8. He
hadn’t made up his mind just what he was going to do for the ’62 Bonneville meet, if anything, but
he did confess that he had looked the Fairlane engine over pretty good.
If Karol does show up at Bonneville this summer, you can bet that he’ll be driving a Ford product
of one type or another and you can also bet that whatever class he chooses to enter will have a
new record hung up before the week is over. With his slow, Texas drawl, Karol doesn’t make
much noise -- he lets his Fords speak for him and their voices are loud.
*From the FORD PERFORMANCE HANDBOOK, 1962, by Ray Brock and the Editors of HOT
ROD magazine.
offline   Reply With Quote
Old 06-24-2008, 09:22 PM   #2
Clark
Old School HAMBer
Clark's Avatar
Default Re: Karol Miller and Y- Blocks
Great Story!! Can you imagine someone has a record holding Vicky and probably doesn't know it.
Clark
Old 10-28-2008, 03:44 AM   #3
murdercycles
Grenade Inspector
murdercycles's Avatar
From an old Champion spark plug ad.
Ray
__________________
Gasoline, Oil, Whiskey & Ink
http://www.murdercycles.com/
Hot Rod Riot 4, Sat. July 11, 2009
Old 10-28-2008, 05:08 AM   #4
teddyp
Old School HAMBer
teddyp's Avatar
Good story
__________________
y-blocks ford,s the real ford small block
goldchainer cc
Old 10-28-2008, 05:17 AM   #5
unclechop
Grenade Inspector
unclechop's Avatar
Ive got an old 70s copy of a ford performance book,
heaps of stuff bout Y blocks racing in t birds etc ill if any one wants i can scan a few pages?
Old 10-28-2008, 10:15 AM   #6
modifieddriver
Old School HAMBer
modifieddriver's Avatar
Great reading. I like the driving to and from Bonneville WITH the record holding car!!!!!!
__________________
If ya' really want it.....all ya' have to do is "STEP-UP".
Old 10-28-2008, 01:21 PM   #7
GEEZZER
Grenade Inspector
I remember the Fords from seeing them in hot rod magazine and in Isky ads. was he the same fellow who was partner wih a guy named Singer? They had a 430 Lincoln powered dragster with a front mounted blower. I think they won the nationals one year at Tulsa or Detroit. Is he still alive?
Old 01-10-2009, 09:38 PM   #8
mctim64
Alliance Member
mctim64's Avatar
Wonderful story! I've read it before but never get tired of it.
__________________
Y-Block Powered Model A Tudor project http://www.jalopyjournal.com/forum/s...d.php?t=667198
"it looks just like a Tellafunkin U-47"
http://yblockguy.com/
Old 01-11-2009, 09:51 AM   #9
scrapiron
Alliance Member
My HERO when I was in HS,,,,remember that story well,,,,in '63 he ran a SPRINT with a 289 at Bonny'. That was the inspiration for my Bonnevile run in '65,,,,139+ in a 260 Falcon.
Old 01-11-2009, 10:25 AM   #10
39cent
Senior Member
39cent's Avatar
yeah I remmber him, when I saw his name 'FORD' popped into my brain. The first thing in our mind was WOW, a lotta racers were missing something. when a guy can just drive up in his ford and breaks a Bonneville record! It got everyone's attention. That something was, starting from scratch, 'attention to details' and doin his homework, it was real hot rodding!
__________________
"If you think you can do
a thing or think you can't do a thing, you're right".- Henry Ford,
Old 01-11-2009, 11:12 AM   #11
Goober
Senior Member
Goober's Avatar
Karol is the man.
Old 01-11-2009, 03:33 PM   #12
Customline Vicky
Alliance Member
Customline Vicky's Avatar
Absolutely fabulous post. Being a Yblock guy this hits home. Can one just imagine the thinking by these kinds of guys? There were tons of guys like him back in those days and those days seem to have gone by the way side. This is the definition of "Back In The Day" ... !!!! The next time somebody bad mouths the term just think of this story.
__________________
Old 01-11-2009, 04:18 PM   #13
Retro Jim
Old School HAMBer
Retro Jim's Avatar
What a great story on Karol Miller !
I knew I loved them Y Blocks for a reason !
I think I have seen that engine picture on the site from John Mummert before .
They have some really mean Y Block on that site .
Old 01-11-2009, 04:25 PM   #14
Spooky
Alliance Member
Spooky's Avatar
A neighbor of mine casually mentioned his friend from California, Karol Miller and I about wet myself.
Karol keeps to himself and when he does show up to Ford events he is always astonished at the attention he gets.
I have a promotional video tape that was put ut by Wynn's featuring the exploits of the Kenz and Leslie team in '57 and Karol's '56 is shwon running at the Salt. I mentioned it and they sent it to KArol to watch. He sent me a thank you note mentioning how good it was to see his old girl running again.
My friend Jack Richards remembers clearly when Karol made his record run.
Vic Edelbrock, Bill Kenz and others rushed over to see what he had done to make a Ford Y-Block run sooo good.
Neat stuff.
__________________
President
Pan Draggers Customs
Car Club
Old 01-11-2009, 07:13 PM   #15
warbird
warbird's Avatar
153 mph out of a Y-block back in the day! Just shows you the potential that resides in these old lumps of iron.
__________________
Willit Run?
Old 05-12-2009, 12:34 AM   #16
racepast
FNG
Hello, I am new to this forum. I was refered to this thread from the randy ayres modeling forum on "Darkside" cars.
I believe I may have found the 1960 Starliner mentioned in this thread. I live in AZ and the car I found is from CA with reported Bonneville history.
Does anyone have any more info or photos of this car?
I have the VIN and data tag info and can get a photo.
Thanks,
David Tom
Old 05-12-2009, 04:17 AM   #17
Homespun91
Old School HAMBer
Homespun91's Avatar
Karol is still alive & well, last I heard. I think I have his address somewhere...I'll look around.
__________________
Against stupidity, the gods themselves contend in vain. - Schiller
Life's a bitch. If it was easy, it would be a slut.
Old 05-12-2009, 06:42 AM   #18
coletrickle
FNG
nice old artical.Made me think of Red Adair the oil well fire fighter from houston in the mid 50's he had a lincon if i remember correct,he had it hotted up by some guy in houston who raced at bonneville.It said the car would out run light aircraft!I'm guessing that karol is the unnamed hottrodder.
Old 05-12-2009, 06:46 AM   #19
RAY With
Old School HAMBer
RAY With's Avatar
Here are some old shots of Karol and Rodney Singer back in the days And yes they won nationals. The group shots were at the old freeway drag strip in Houston and I think in 1958
Click image for larger version
ID:	659148   Click image for larger version
__________________
http://www.hotrodchat.com/gallery/ 29,660 +pictures and 160 albums and growing-Many HAMB FRIENDLY and some not. Many subjects and many old drag pictures from the 50-60's
Old 05-12-2009, 06:58 AM   #20
skywolf
Senior Member
skywolf's Avatar
Another shot of Rodney Singer's dragster.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
