Reply
Thread Tools Display Modes
Old 06-04-2008, 09:23 PM   #1
PBRmeASAP
Old School HAMBer
PBRmeASAP's Avatar
Default Replacing Pinion Seal on 57 chevy rear
I know this isn't rocket science, but is there anything i need to look out for? Tips, tricks?
Figure 13 shows it all i guess.......can this be done without removing the center section of the rear?
http://chevy.oldcarmanualproject.com...56spcra08.html
__________________
Sock Fuckers CC because we can do it ourselves
http://www.youtube.com/watch?v=U7dc4vEgngQ&NR=1
offline   Reply With Quote
Old 06-04-2008, 09:30 PM   #2
scotty t
scotty t's Avatar
Default Re: Replacing Pinion Seal on 57 chevy rear
check out this info. i think page 2 has what you need
http://www.trifive.com/forums/showthread.php?t=3200
__________________
imagine that this is a clever signature line!
Old 06-04-2008, 09:33 PM   #3
middleskewl
Grenade Inspector
middleskewl's Avatar
http://www.jalopyjournal.com/forum/s...d.php?t=269423
__________________
if it was easy, everybody'd have one.
Old 06-04-2008, 09:35 PM   #4
Torkwrench
Senior Member
Torkwrench's Avatar
It's been awhile since I changed one, but I;m sure that it can be changed while in the car. The only other thing that I remember is that you do not want to install the seal flush with the center housing. Seems like there should be a small gap between the housing and the metal lip around the outside edge of the seal. I think the shop manual has a specific amount, but I don't have my shop manual with me right now.
Old 06-04-2008, 09:36 PM   #5
sdluck
Senior Member
Mark the pinion flange, pinion,and the nut, count number of threads the nut is on the pinion, remove nut and flange .Replace seal ,install everything back to its same position, tighten nut back to same spot. If you did every ok it should be fine
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
