Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 05-08-2008, 08:58 PM   #1
Joshua Shaw
Senior Member
Joshua Shaw's Avatar
Default CHEAP HOMEMADE 18"x6", 5 on 5.5 BOLT, EARLY FORD STEELIES, How-to with PHOTOS
I wanted 18" early ford style steelies for the back of my 32' I called Genie wheel company and a few others and the cheapest I found was special order, 30 day wait, and $300 EACH!!
I searched junkyards for the right hoops, and didn't fine what I wanted. (I found many 18" steelies, that were $75 to $100 EACH!) But that was just the hoop, then I needed a center and I didn't want wires.
As most of you know, with late model rear ends, to run wires, you must run BIG spacers. I didn't want to do this. So, I sat down in the middle of my wheel stash with a tape measure, and figured this out.
Slick Williams and I, hand made the wheels, when we built the Dynaliner coupe.. So I said what the hell..
Enjoy.
You will need a stock 32' ford 18" wire and a stock 40's Ford 16" steelie. Both availible at most swap meets from $20 to $50 bucks.
Then you need to build a wheel holder.. I have an old bent axle that I use. BE SURE TO USE A DRUM, not just a hub as wires need the drum to stay true sometimes. Also, be sure to lock the spindle from turning.
***IMPORTANT!! BE SURE TO CHECK YOUR WHEELS FOR STRAIGHTNESS FIRST!! No steel wheel is truly 100% perfect, actually a lot are far from it(new and old). My own limit is an 1/8 inch of movement. If the wheel is moving around at 3/16 or 1/4, toss it aside.. Below is the best way to check them. Clamp a piece of steel to your table and draw a line on it.. Then give the wheel a spin!
Lets cut the 18" wire first.
THE VITAL KEY is to make a "clampable" arm to hold the plasma gun.(a torch will work, just not as clean) If you have niether, use the clamp arm to hold your sharpie, and mark the wheel as you spin it.
The First cut is just inside the inner roll, ON EITHER side of the outer most spoke. When done right the center will still be intact. SAVE THESE CENTERS! You can make other wheels out of them(shown later).
SAVE THESE!!
Now its time to cut the 16" steelie. The cut is made 5/8 in from the outer most edge. Hook your tape on the tire side of the edge and wrap it in.
Making the cuts, is pretty easy, just push the button and turn the wheel with your other hand... The speed is determined by your cutter.
Next, unbolt the 16" wheel and put the 18" hoop with the Valve stem hole on the jig. (you have to weld the hole up, and on the inside you wont see it) Then, bolt your 16" back on and check it to be bolted on straight.
Now the tricky part. (not really.. turns out easy) Align the 18" lip to the 16" wheel. If you have a buddy to hold it it makes it easier. I did not. So, I aligned it, pushed in with my hip and tacked (welded) the top... Then carefully rotate it 180 degees, tweak it if need be and tack it again.. At this point, SPIN TEST it.. Don't feel bad if you dont get it on the first try. Cut one or both of the tacks and make adjustments. REMEMBER!! CLOSE AS YOU CAN GET IT, IS FINE! (You will be amazed how good they balance, even the ones you think are way out)
Then repeat the process for the outter ring. An old rear wishbone works good cause its hooked..
Once you have it where you want it, WELD IT SOLID!! ALL THE WAY AROUND!!
Once welded I paint them, and finger smear Silicone on the welds, as well as the factory rivets.
Now you have an 18x6 rim that ford never made.
I didn't weld the outside for two reasons.. My weld was penatrated and strong enough on one side and I didnt want to see a weld. This is what the seam looks like before paint.
Here's the finished product with some rare ORIGINAL 18" Firestone dirt trackers on them. While I usually run all my old wheels TUBELESS these old tires were very hard and just wouldnt seat, so.. 16" tubes were used due to where the valve stem hole is in the wheel... YES 16".. Not 18's.
They Balanced out good, One took 1.25 and the other .75
Now.. for the "other" wheels you can make with the left overs!
Head down to you local Tractor Supply and get some Ford 9N tractor front wheels.. 19"x3", about $40. then cut the centers out of them. The 18" wire centers will drop right into them. Depending on the brand 9N wheels, you may have to roll a spacer ring between the two. (this is what the Dynamat coupe has on the front)
19" x 3" (like a model A wheel, but STRONGER!)
Hope this will help a few of you..
Joshua Shaw
Shaw Shop Cin Oh
__________________
In Racing, You can be CHEAP, FAST, or SAFE...
...pick TWO.
offline   Reply With Quote
Old 05-08-2008, 09:11 PM   #2
mad-cad
Alliance Member
mad-cad's Avatar
Thumbs up Re: CHEAP HOMEMADE 18"x6", 5 on 5.5 BOLT, EARLY FORD STEELIES, How-to with PHOTOS
Brilliant!
__________________
Salty Box Racing, #622 AA/CBFALT and B/DT
Old 05-08-2008, 09:14 PM   #3
hemi coupe
Senior Member
hemi coupe's Avatar
Default Re: CHEAP HOMEMADE 18"x6", 5 on 5.5 BOLT, EARLY FORD STEELIES, How-to with PHOTOS
Dude that is brilliant!! I would never even think of doing something like that!! NIce work man. You made what I thought was some lost art seem so easy!!
Jimmy White
__________________
www.circlecityhotrods.com
Old 05-08-2008, 09:54 PM   #4
Crusty Nut
Senior Member
Crusty Nut's Avatar
Awsome!
__________________
Singley Speed Shop
707-599-2315
Old 05-08-2008, 09:58 PM   #5
Joshua Shaw
Senior Member
Here's the finished product. Thanks guys.
Joshua Shaw
__________________
...pick TWO.
Old 05-08-2008, 10:00 PM   #6
The37Kid
Alliance Member
The37Kid's Avatar
Years ago there was a shop in New Jersey that would do wheel work like that, lots of stock car work. I had a pair of 16" Ford wheels widened for dirt track rear tires.
online   Reply With Quote
Old 05-08-2008, 10:00 PM   #7
Kiwi Kev
Old School HAMBer
Kiwi Kev's Avatar
You tricky bastard!
__________________
That's MISTER low buck to you pal!
Old 05-08-2008, 10:05 PM   #8
wheelkid
Alliance Vendor
wheelkid's Avatar
neat way to do it.
Jimmy
__________________
www.rallyamerica.com
Old 05-08-2008, 10:13 PM   #9
Cshabang
Senior Member
Cshabang's Avatar
BITCHIN JOSH....I may have to find me some wheels...then build the car for them..haha
__________________
BANG ZOOM, ITS NOT ROCKET SURGERY..
Would I be bitching if i said i was sick of people BITCHING?
Old 05-08-2008, 10:13 PM   #10
lakester47
Alliance Member
lakester47's Avatar
Josh,
Thanks for the wheel lesson. I have read your explanation of the Dynaliner wheels in Street Rodder several times. Seeing the excellent pictures was awesome. You're very talented. Thanks for sharing with us.
Old 05-08-2008, 10:20 PM   #11
Richard D
Old School HAMBer
Richard D's Avatar
Location: Texas City, Texas Between Houston & Galveston
Holy shit, when's TECH Week?!?!? A+++
Old 05-08-2008, 10:26 PM   #12
hotrod1940
Old School HAMBer
hotrod1940's Avatar
If anybody asks what traditional hotrodding is all about, give them this thread.
Great job.
Old 05-09-2008, 12:05 AM   #13
HHRdave
Senior Member
HHRdave's Avatar
Excellent post !!!! This is a great tech post. Nice work!
Old 05-09-2008, 12:16 AM   #14
Crazy Backyard Builder
Senior Member
Crazy Backyard Builder's Avatar
Wow, great tech ! I want a set of those.
CBB
Old 05-09-2008, 12:33 AM   #15
Chris
Alliance Member
Chris's Avatar
Awesome!
__________________
Swenson's Early Ford Parts
Instagram pictures: http://instagram.com/swensons_early_ford_parts
THEE INLAND EMPERORS
Old 05-09-2008, 01:34 AM   #16
alteredpilot
Old School HAMBer
alteredpilot's Avatar
Location: City of Hawthorne, Los Angeles County, CA, USA
faw king amazing.
__________________
AstroMotive Auto Service & Transmission
www.astromotive.com
MAS Line Design
Kustom Paint and Pinstriping
MAS Means MORE!
Embers So Cal CC
Old 05-09-2008, 02:26 AM   #17
Minewithnoshine
Alliance Member
Minewithnoshine's Avatar
Killer.
Old 05-09-2008, 03:31 AM   #18
Shoprag
Shoprag's Avatar
I wouldn't trust my welds on something so tender!!!
Great job, looks nice!
Old 05-09-2008, 05:10 AM   #19
Dat Dirty Rat
Old School HAMBer
Dat Dirty Rat's Avatar
Thats one of the best techs in my opinion in a long time!
Nice job..
__________________
trust can take years to build....but only a second to break.
Old 05-09-2008, 05:19 AM   #20
Jeff Norwell
Art Editor
Jeff Norwell's Avatar
Nice tech Josh..very nice.
__________________
"I like HOT RODS."
"Now, go drive your Volvo...safely..."
http://www.jeffnorwell.com
http://drawnandquarrtered.blogspot.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
