Reply
Thread Tools Display Modes
Old 05-08-2008, 08:32 PM   #1
Mattilac
Alliance Member
Mattilac's Avatar
Default Bolt Won't Come Out!
Okay, I'm having a hell of a time trying to get this bolt out. As you can see, it holds the front eye of the rear leaf spring. The problem isn't that it's frozen to the bracket or anything, since I can turn the bolt using a wrench just fine, it's that no matter what or how hard I try, it just refuses to slide out. It'll turn and turn and turn all day, but pounding on the back of it and trying to pry it out doesn't do anything! The other side came out without too much of a hitch, so I'm wondering what the deal is with this side...
The way I tried to bang it out was via a steel rod that I inserted through the back to hit the end of the bolt. The hammer won't reach in there, but no matter how hard I pounded on the shaft, it doesn't budge the bolt.
__________________
www.TrainScience.com
offline   Reply With Quote
Old 05-08-2008, 08:45 PM   #2
pitman
Old School HAMBer
pitman's Avatar
Default Re: Bolt Won't Come Out!
Any chance that there is a steel bushing in there? (check opposite side that came out?) If it isn't there, and holding the bolt, may have to cut the head off w/torch and push thru the opposite direction.
Old 05-08-2008, 08:45 PM   #3
Paul2748
Senior Member
Paul2748's Avatar
The problem is rust on the inside. Even though it turns, it won't release the bolt. You have to soak it with Kroil, Gibbs , etc. and bang the hell out of it. That's they way I solved my problem.
If you can rig up a bottle jack to apply some hydraulic pressure that may work. Never tried it myself.
__________________
flathead or ovhd- fords only
Old 05-08-2008, 08:46 PM   #4
35Chevy.com
35Chevy.com's Avatar
I would take a sawsall cut the head of the bolt off and pound it thru the other way.
Gary
__________________
I think the monkeys at the zoo should have to wear sunglasses so they can't
hypnotize you.....Jack Handy
Old 05-08-2008, 08:49 PM   #5
PRoz
Grenade Inspector
PRoz's Avatar
use a sawzall and cut the bolt on each side of the spring bushing. The bolt is rusted to the steel sleeve in the bushing.
The spring will just fall out and then you can get the remains out of the bushing on the workbench.
__________________
Paul
Area 51 Performance
Pimpin Freightliner parts for a Livin
Old 05-08-2008, 08:49 PM   #6
61 chevy
61 chevy's Avatar
cut bolt on both side of spring, it will drop down, you said it first
Old 05-08-2008, 08:50 PM   #7
toddc
toddc's Avatar
^^^ what these two said. Good luck.
Old 05-08-2008, 09:02 PM   #8
tomcat46
Alliance Member
tomcat46's Avatar
Exactly...and assuming you have the chassis jacked up and on stands, put another jack under the rear axle and lift it enough to unload the bolt. So the weight isn't hanging from the bolt or pushing up, just neutral. That will make the bolt as loose in the hole as possible.
I need to pull another leaf from the rear on my son's '65. So let us know which ones you end up pulling from the rear and how it works out.
Tomcat
__________________
'46 Chevy Stylemaster
'65 Ford F-100
'64 Ford Galaxie 500
'58 BMW R-26
Old 05-08-2008, 11:53 PM   #9
dabirdguy
Senior Member
dabirdguy's Avatar
You need a bigger hammer.
It's like a Blond...till she has 2 black eyes you just havn't EXPLAINED things to her.
Old 05-09-2008, 02:33 AM   #10
Willy301
Senior Member
Willy301's Avatar
I am with the guys suggesting cutting the bolt on both sides between the spring and bracket method, but I invested in a Mac air chisel and got the punch attachment for it. I have driven all kinds of stuck stuff out with that thing, but after awhile the hands go numb. Good luck with it.
__________________
Fire Fighters find them Hot and leave 'em Wet
NSMC Life member
www.smallscalecreations.org
Old 05-09-2008, 02:45 AM   #11
Zodoff
The bracket may flex on the bolt head side when you punch it,so it jams.
Try to put a vice of some sort on the bracket\frame, and hit it again.
Z.
Old 05-09-2008, 03:24 AM   #12
MetalMike
Newbie
Do you have an air compressor, with an impct driver, and an air hammer? set up two lines. FAQ I am geting sick of this board!
Old 05-09-2008, 03:50 AM   #13
rustynewyorker
Old School HAMBer
rustynewyorker's Avatar
Location: Upstate New York, watching my New Yorker Rust
FWIW if you end up cutting it make your life easier, use a cutoff wheel on a grinder. Will be a little faster and easier particularly if you have to lay on your back to do it. Goggles highly recommended. Don't ask me how I know this.
__________________
"That was a time when America was great.. when the chrome was thick and the women were straight" - Michael Savage
I have old cars for sale. PM me or check the classified.
Old 05-09-2008, 05:53 AM   #14
Jonny69
Grenade Inspector
Jonny69's Avatar
I used a 1mm cutting disc in a grinder and cut the bolt either side of the spring. It was rusted solid in the steel bush and the rubber was the bit that was turning.
Old 05-09-2008, 06:43 AM   #15
Mattilac
Alliance Member
Mattilac's Avatar
Yeah I kinda suspected that I would have to cut it off. That's what I had to do with the front leaf spring's rear bushing too. It's a pain in the ass the way it's in there, but whatever.
__________________
Old 05-09-2008, 06:55 AM   #16
PumpGasRatVette
Grenade Inspector
I'd try unloading the tension first, in case there is a wear shoulder holding it. If/when that doesn't work...CUT, CUT, CUT! Then beat the hell out of it. Good luck.
Old 05-09-2008, 06:56 AM   #17
Mattilac
Alliance Member
Mattilac's Avatar
Oh yeah the axle is already unbolted from the springs, so there isn't any force on it.
__________________
Old 05-09-2008, 07:57 AM   #18
Shifty Shifterton
Old School HAMBer
Shifty Shifterton's Avatar
Welcome to rusty ole junk! I mean classic cars and trucks!
If you ever get something like this that a sawzall can't reach, an electric 1/4" die grinder with a 3" x 1/8" disc on a short arbor is an incredible weapon of precision destruction. Great for removing bolt heads in tight spots, and doesn't care if it's cutting hardened steel. Wear appropiate safety gear.
Good luck!
__________________
The same........but different
Old 05-09-2008, 08:16 AM   #19
novadude
If you can fit it in there, I've used those Ball-joint presses that look like big C-clamps to drive bolts out of these type of bushings before. Those damn sleeves practically weld themselves to the bolt after years of rust.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
