Reply
Thread Tools Display Modes
Old 04-29-2008, 12:34 AM   #1
Baumi
Alliance Member
Baumi's Avatar
Default 283 Chevy Question: Recessed Oilfilter Boss? Which Oilfilter
Hi folks!
Iīm having some headaches with my 283 casting #3862194. Itīs supposed to come from an 65 Chevy II and has the recessed oilfilter.
Unfortunately it came without an oil filter, and unlike any other SBC Iīve seen to this day, the oilfiter mounting provision is totally different. The screw on and canister type filters I know on early and later sbc usually have an aluminum mounting surface attached to the block by 2 bolts.
This block I have here only has a 3/4"-16 threaded hole in the block.
Maybe someone on here has an identical block, or knows what to use?
Any help would be great!
Thanks, Chris
__________________
Kronz`nīDungle Hi Performance Exhausts
offline   Reply With Quote
Old 04-29-2008, 01:21 AM   #2
racer32
Alliance Member
racer32's Avatar
Default Re: 283 Chevy Question: Recessed Oilfilter Boss? Which Oilfilter
Should use AC/Delco PF25.
Old 04-29-2008, 01:35 AM   #3
Alliance Member
Mr48chev's Avatar
It shows to take a NAPA 1069 oil filter.
http://www.napaonline.com/MasterPage...l+Filter+(Gold)
That link also shows the specs on the filter including the thread size.
From looking at a photo of another block I am pretty sure that is all there is.
Here is another link to a list of filter numbers that you might be able to cross from. The AC being the factory filter.
http://www.partsamerica.com/ProductL...for=Oil+Filter
I'm in agreement with Racer32 as to the PF 25 filter and that should cross from the napa #1069
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 04-29-2008, 02:03 AM   #4
racer32
Alliance Member
racer32's Avatar
Took some searching, but I found what I was looking for. This should help:
http://www.knfilters.com/search/kn_c...spx?kn=HP-2002
Old 04-29-2008, 06:47 AM   #5
booboo
booboo's Avatar
sounds like your oil fltr adapter is missing .look to mr gskt for a spin oil fltr adapter. then you can use an ac delco pf25,pf35 or pf1218 with a anti bleed back diaphram..the adapter part number from GM is part number 3952301.maybe a gm dealer over there can get this for you
Old 04-29-2008, 07:38 AM   #6
novadude
Second the PF1218 recommendation.
Old 04-29-2008, 08:39 AM   #7
Deuce Roadster
Deuce Roadster's Avatar
Does your block look like this?
This is a Chevy II block
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Old 04-29-2008, 02:32 PM   #8
Baumi
Alliance Member
Baumi's Avatar
Yes, thatīs exactly what my block looks like.Does this type of block usually use a canister type oilfiter?
Thanks! Chris
__________________
Old 04-29-2008, 02:45 PM   #9
Baumi
Alliance Member
Baumi's Avatar
I just checked my block again, and it looks like the block Deuce Roadster posted has two threaded holes for the aluminum oilfilter adapter mine hasn´t at all...
Here´s a pic of what I have...
__________________
Old 04-29-2008, 08:07 PM   #10
racer32
Alliance Member
racer32's Avatar
Baumi, I'll post a pic tomorrow of my early Chevy II block. I can't remember if it's still got a filter mounted on it or not.
Old 04-29-2008, 09:39 PM   #11
Engine Pro 5X
Old School HAMBer
Engine Pro 5X's Avatar
Are you sure the threads in the block are 3/4-16. The two small holes in the block are the bypass and the other is the oil feed to the filter. Also what are the stamping #s on the block pad in front of the right cylinder head???
__________________
GET IN THE TRUCK JETHRO!!! WE'RE GOING TO CALIFORNIA!!! SWIMMING POOLS!!! MOVIE STARS!!!***CAN I SHOW YOU MY BEST KIELBASA ???
Old 04-29-2008, 09:56 PM   #12
Redneck Smooth
Senior Member
I don't know shit about chevy small-blocks, but aren't those 327s and worth a couple grand?
__________________
Looking for Cadillac 390 speed parts and intakes. PM me.
Old 04-29-2008, 10:41 PM   #13
1oldtimer
Old School HAMBer
1oldtimer's Avatar
to me that looks like it doesnt have one, just put in a threaded pipe. it looks like a fill hole to the filter, a return hole from the filter, a pressure port and a flat mating surface for the filter o ring. because the regular blocks drop down in the middle, the spin on filter piece will sit in the hole so the filter will seal against the block (notice the main hole isn't threaded).
Click image for larger version
__________________
#1 Post killer
Old 04-30-2008, 12:40 AM   #14
Baumi
Alliance Member
Baumi's Avatar
Quote:
#īs are: 805552917 and 283V06360
The big hole in my block is 3/4 and threaded
__________________
Old 04-30-2008, 12:51 AM   #15
1oldtimer
Old School HAMBer
1oldtimer's Avatar
so is that 1/2 pipe thread?
__________________
#1 Post killer
Old 04-30-2008, 07:25 AM   #16
29moonshine
it takes a canister with a oil filter in side that has a bolt that screws in to the block if the casting # on the back of the block is3790721 it is a 283 64-65 if it is 3791362 it is a 327 65-67 if it is 3862194 it is a 66-67 283 all are chevy ll blocks. booboo gave you the adapter information
Old 04-30-2008, 12:13 PM   #17
Baumi
Alliance Member
Baumi's Avatar
Quote:
Yeah, but the adapter # 3952301 looks like this...
...and would caue the filter to sit higher than the sealing surface.
I can see no way to bolt it to my block without threaded mounting holes...
so I figure the adapter or oilfilter should go into the threaded big hole in the middle of the oilfilter boss...
Nontheless, thank you guys so much for dealing with this.
Chris
__________________
Old 04-30-2008, 12:20 PM   #18
Baumi
Alliance Member
Baumi's Avatar
Quote:
No, the large center hole is a 3/4" thread
__________________
Old 04-30-2008, 12:27 PM   #19
Baumi
Alliance Member
Baumi's Avatar
Yes, thatīs what I thought. But the common sbc filter are 13/16" female threads, so Iīd need a filter with a 3/4 " male thread or an adapter pipe from 3/4" to 13/16" or a pipe with 3/4 thread and use a 3/4" threaded filter.
I just donīt know which filter have 3/4" male/female threads, so I figured that someone could know the OEM application...
The canister type filter I know ( like early 283 and such) have a very slim bolt compared to 3/4"..
Thanks ! Chris
__________________
Old 04-30-2008, 12:31 PM   #20
63_nova_ss
Grenade Inspector
63_nova_ss's Avatar
i cant think off the top of my head where mine mounts either. will check when i get home to look at it, but looks like you have got several viable answers.
__________________
i like mine with no shine...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
