Reply
Thread Tools Display Modes
Old 04-21-2008, 09:12 PM   #1
tfee
Grenade Inspector
tfee's Avatar
Default Correct brake line size?
I will be doing the brakes on my highly modified model t soon and I don't know what brake line size to use. I have 12" drums on all 4 corners and a 1" bore master cylinder from an old econoline van. Should I run 1/4" line to the t's and 3/16" from there or will 3/16" suffice all around?
Thanks in advance
offline   Reply With Quote
Old 04-21-2008, 09:20 PM   #2
Eyeball
Senior Member
Eyeball's Avatar
Default Re: Correct brake line size?
I run 1/4". It was what was on the early Fords and I seem to have better luck doing the double inverted flares on the larger size for some reason.
__________________
SUEDES CAR CLUB
Suedes Facebook
"Saying "Old School" makes it not."
Wowcars
Old 04-21-2008, 09:20 PM   #3
lostn51
Senior Member
lostn51's Avatar
Id run 3/16" all the way around but thats just me. i cant recall ever seeing any 1/4" in brake lines but then again i have not seen everything thats out there either.
__________________
Old 04-21-2008, 09:22 PM   #4
lostn51
Senior Member
lostn51's Avatar
Quote:
see i just learned me something new.........
__________________
Old 04-21-2008, 09:37 PM   #5
tfee
Grenade Inspector
tfee's Avatar
Thanks, I will run with the 1/4" then
Old 04-21-2008, 09:41 PM   #6
325w
Alliance Member
325w's Avatar
If you run 1/4 don't you have to have an adapter to go into the wheel cly?
Old 04-21-2008, 09:46 PM   #7
Paul2748
Senior Member
Paul2748's Avatar
Run 3/16 - don't putz around with different sizes
__________________
flathead or ovhd- fords only
Old 04-21-2008, 10:06 PM   #8
Rex Schimmer
Rex Schimmer's Avatar
Use the 3/16 size it will give you a firmer pedal.
Rex
Old 04-21-2008, 10:23 PM   #9
Fogger
Senior Member
Fogger's Avatar
Good advice is to run the same size as master and wheel cylinders. Early Ford was 1/4" all arround. But new system wheel cylinders and master are generally 3/16". I've been using 3/16" on all the cars I've build that way I don't need adapters. The FOGGER
Old 04-21-2008, 10:26 PM   #10
enjenjo
Senior Member
As far as brake line size, the brakes don't care what size they are. Old Fords, pre 48 used 1/4" lines. 49 and up Fords used 3/16". GM until recently used 1/4" in the rear, and 3/16" in the front. Line size does not change the pressure on the wheel cylinders.
__________________
You can't be part of the elite unless you have someone to look down on.
Old 04-22-2008, 10:53 AM   #11
HemiRambler
Old School HAMBer
HemiRambler's Avatar
What Enjenjo said
EDIT:
Technically speaking the smaller line will carry more pressure - which might explain why Detroit went to 3/16" - the advent of disc brakes doubled line pressure.
__________________
With the help of some and inspite of others...
Old 04-22-2008, 06:18 PM   #12
35Chevy.com
35Chevy.com's Avatar
Bernoulli's Principle states that as the speed of a moving fluid increases, the pressure within the fluid decreases.
Want to know more check this out, Its kewl
http://home.earthlink.net/~mmc1919/venturi.html
Gary
__________________
I think the monkeys at the zoo should have to wear sunglasses so they can't
hypnotize you.....Jack Handy
Old 04-22-2008, 06:44 PM   #13
RustyBolts
Senior Member
RustyBolts's Avatar
I always do 3/16" all around. A few things good about the 3/16" is that you can make bends with a tighter radius using a tubing bender, and you can make gentle bends or adjustments easily with your bare hands.
Get a good tubing flaring tool. It sucks trying to make the flares with a piece of crap tool. When you get a line all bent and cut perfectly, the last thing you want is to have the flare get ruined by trying to use a junky flaring tool. I bought a used old Blue-Point flaring kit, and it's never let me down.
Old 04-22-2008, 07:22 PM   #14
36-3window
Old School HAMBer
36-3window's Avatar
we are seriously getting close to over thinking this
run 3/16 or 1/4...whichever works out best for you
Old 04-22-2008, 10:23 PM   #15
enjenjo
Senior Member
Gary
In technical terms, there is no "flow" in a brake system. The fluid moves so little that the Bernoulli principle does not really apply.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
