Reply
Thread Tools Display Modes
Old 04-10-2008, 07:34 PM   #1
beaulieu
Grenade Inspector
beaulieu's Avatar
Default How do you get stubborn door hinge pins out ?
Hi
The door on my car has one side of the hinge welded to the door post and the other side to the door , so to take off the door you need to pull out the pins that have been in there for decades ,
anyone have a homebuilt tool ?
the one you buy at the Model A Ford shops are not strong enough,
I would rather not use an air chisel ,
but was thinking of using some set-up using a body shop hydraulic pump and ram and pushing the pin out....
any ideas ?
Thanks
Beaulieu
__________________
WTD:356 Porsche project ,anything considered ,rusty ,crashed, incomplete OK+Fiat 500-600+Citroen van
offline   Reply With Quote
Old 04-10-2008, 07:44 PM   #2
Custom.Rust
Alliance Member
Default Re: How do you get stubborn door hinge pins out ?
mine came. Out with a hammer, punch and swearing... Lots and lots of swearing. Enjoi
Old 04-10-2008, 07:50 PM   #3
Sloppyseconds
Senior Member
Sloppyseconds's Avatar
Old pins are easy...just grind off the head on the top and center punch and drill them out. You can drill just underneath the diameter of the pin and then a simple punch. This usually works..if not sell the car and buy one with easier to remove hinge pins
__________________
Ever since I was a lad I was interested in things that go fast.things that roll and go!
The coupe.... http://www.jalopyjournal.com/forum/s...=Sloppyseconds
Old 04-10-2008, 08:06 PM   #4
sawbuck
Senior Member
sawbuck's Avatar
why not a air chisel?grind it down to size ,it works and no damage.almost to easy
__________________
its not how fast you go....its how you get there...
online   Reply With Quote
Old 04-10-2008, 08:09 PM   #5
RustyBolts
Senior Member
RustyBolts's Avatar
Quote:
Yeah, that's what I do too. After you grind the head off, it's easy to find the exact center of the hinge pin so you can center punch it. Then I use one of those long two-step drillbits that are surplus from the aircraft industry to drill the pin out with lots of cutting oil and lots of pressure. If you make a hole that's just a little smaller than the size of the original hinge pin, then you just have sort of a rusty sleeve left to punch out with a drift punch. The heat of drilling and the cutting oil helps loosen it up too.
The top part of the hinge pin has the serrations on it and that part fits tighter in the hinge, so sometimes you don't have to drill all the way through the hinge pin if you can get the top part to start to break free from the hinge.
If you can't hold the drill bit completely vertical inline with the hinge pin (because a drip molding or something is in the way), make your center punch mark slightly outside (away from the car) so that when the drill goes down crooked it will then wind up in the center of the hinge pin (instead of chewing up the lower part of the hinge as it works its way down deeper).
Old 04-10-2008, 08:13 PM   #6
RustyBolts
Senior Member
RustyBolts's Avatar
Quote:
I guess it depends on how stuck and how rusty they are. I never had much luck with the air chisel on the heaps I've been working on. The air chisel just mushrooms the end of the hinge pin sometimes and makes it even harder to get out.
Old 04-10-2008, 08:44 PM   #7
oldrelics
Senior Member
oldrelics's Avatar
Weld a straight punch(just undersize of pin) to a 'donor' air hammer chisel, grind pin flush with hinge (so it doesn't flare), heat hinge HOT with oxy-acet torch, HOLD TONGUE JUST RIGHT, then giver snooose on air hammer. Did all 6 on my A coupe with no drill.
Old 04-10-2008, 09:01 PM   #8
sawbuck
Senior Member
sawbuck's Avatar
Quote:
i grind the pin flush with bottom of the hinge. it cant mushroom.well almost cant.still need penetrating oil and maybe some heat.but i have got some tough ones out this way
__________________
Old 04-10-2008, 09:07 PM   #9
Pist-n-Broke
Old School HAMBer
Pist-n-Broke's Avatar
I've been doing this for Decades. Take your Morgan Knocker and drop a 3" 5/16 bolt in the end nut. Wire weld the end of the bolt to the Head of the hinge pin, this would be before you grind it Off. Heat the hinge with your Torch and pull the pin by sliding the Knocker handle. It never makes the pin a Rivet and they always come out with out damaging the 2 hinge pieces.
The Wizzard
Old 04-10-2008, 09:13 PM   #10
thunderbirdesq
Old School HAMBer
thunderbirdesq's Avatar
Quote:
The Wizzard
+1 on this. Heat, heat, heat! It's also easier on the door jambs and bolts too.
Old 04-10-2008, 09:20 PM   #11
thirty7slammed
The Wizzard
I heated and beat, cussed, busted my hand with a BMF hammer, I wish I would have tried this, it sounds like it would work great.
Old 04-10-2008, 10:05 PM   #12
Pist-n-Broke
Old School HAMBer
I don't think I've ever damaged any of the pieces doing it this way. Any time you beat on the actual Pin you enlarge the Rivet effect it has. The Ford pins must come out the Top side since they are Knurled just below the Head to keep them from rotating. Good Luck
The Wizzard
Old 04-10-2008, 10:59 PM   #13
BigChief
Senior Member
BigChief's Avatar
Mac's Antique Auto parts (and others, I'm sure) sell a hinge pin removal tool. It supposed to pull the pin without damaging the hinge or paint. Hmmmm.
That tool plus heat should get it out with little problem if it works as advertized.
Anybody use one? I bet Bruce Lancaster probably has an original Ford dealer tool for the job sitting someplace, eh?
-Bigchief.
__________________
The early bird gets the worm but its the second mouse that gets the cheese!
Old 04-11-2008, 10:36 AM   #14
Pist-n-Broke
Old School HAMBer
That tool is marginal at best. I have one. It works IF your hinges are in grate shape and NO ridges on the pins. If they are stubborn at all the push pin just bends.
The Wizzard
Old 04-11-2008, 11:12 AM   #15
beaulieu
Grenade Inspector
beaulieu's Avatar
we trieed the tool sold at vintage Ford shops , it either did nothing or bent the tool !
But I do appreciate some of your ideas and will pick up a slide hammer at the swap meet this weekend
Please keep posting , I am sure there are others with this problem
Thanks
Beaulieu
__________________
Old 04-11-2008, 11:15 AM   #16
Zombie Hot Rod
Senior Member
Zombie Hot Rod's Avatar
Try taking a C-clamp and drilling a hole the size of the pin on the end (the pin itself, not the head) then weld a hinge pin to the other end. Grind the head off the pin and use the clamp to push it out like a press...
Hope that made sense.
__________________
- brian
www.AtomicHotRods.com <----- "Psssst, Hot Rod Documentaries and T-Shirts over here."
Old 04-11-2008, 12:46 PM   #17
dirthawker1313
dirthawker1313's Avatar
where was this post a week ago? i tried to remove the pin in my 51 ford. after much frustration i decided it would be better to remove the whole hinge and get the pin out. needless to say i ended up having to drill out all 8 screws just to get the hinge off. then i had to drill and tap all eight holes for new screws plus buy a new hinge!! OWELL it was good for experiance i guess.
Old 04-11-2008, 01:08 PM   #18
Iceberg460
Iceberg460's Avatar
Not trying to hijack this thread but anybody know where new pins can be bought? Will need to dill them out of my '29 Star and nobody makes parts for that car so i would like to find a place with different sizes so i can find some that i can make work. Thanks
__________________
Wanted: 30-31 Model A Tudor or Pickup upper door skins (beltline up), ok if they need lots of TLC.
Old 04-11-2008, 01:24 PM   #19
thirty7slammed
Quote:
Can you get one of the pins out so you can measure dia, that will help finding new pins.
Old 04-11-2008, 01:30 PM   #20
Iceberg460
Iceberg460's Avatar
Quote:
Will try again tonight, but i doubt it, there rusted in there pretty good
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
