Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Old School HAMBer
MerCruiser 224 cid/3.7L I4
Bore: 4.36 Stroke: 3.75 Aluminum block Big block Ford head SB Chevy transmission compatible bellhousing pattern 170-190hp stock I have searched high and low and found some information (most of it here on the HAMB), but finding pictures, that don't suck, of these engines is almost as hard as finding the doo-doo bird. If you have pictures (especially if in a car), or know where to find them, please post them here. Last edited by tjm73; 04-11-2008 at 07:28 AM. |
#2 |
I have a Pontiac super duty produced by KRP in Kansas. It has a Brodix 10X aluminum Ford head , shaft mount rockers, dry sump, chevy bolt pattern. It has a single 4 brl intake now and the plan was to install a set of weber side draft or a injection unit and run it in a 27 t. i'll have too get a picture and post it. thw KRP block could be orderd to fit a Ford, Dodge, Pontiac , or chevy v8 head. they ran them in midgets and ARCA truck series.
__________________
Rules..... Guide lines for Gray areas |
#3 |
Senior Member
in Model Y frame with Chevy 6 engine mount and V8 frame mount and hose number to get to rear mounted intake inlet
#4 | |
Old School HAMBer
Quote:
I have to go see him today, I'll try to remember to take a few pics for ya. These are BIG inch 4 cylinders.
__________________
If ya' really want it.....all ya' have to do is "STEP-UP". |
#5 |
Old School HAMBer
There is a 27 roadster with 29 fenders here in town with a hot lil Mercruiser in it. Very cool car.
#6 |
Old School HAMBer
Do you have any boat yards/dealers around you? If so, you'll likely find one or two collecting dust/rust in the back lot.
__________________
I was bored before I even began. |
#7 | |
Old School HAMBer
Quote:
I live in Hampton,and I know we have 'prolly crossed paths,as I know a bunch of folks in Jointsboro. Lemme' know where you are,if you don't mind me knowing.
__________________
Chuck |
#8 | |
Old School HAMBer
Quote:
Here's a pic of the two engines I mentioned yesterday. Don't pay the blue cylinder head any attention.
__________________
#9 |
Old School HAMBer
Thanks for the followup.
#10 |
Old School HAMBer
#11 |
Old School HAMBer
I found this.....
#12 |
Old School HAMBer
It appears that the coolant flows from the water pump to the intake to the head, or vice versa from the head to the intake to the water pump. I also see what appears to be a mechanical fuel pump on the intake side of the block.
#13 |
Grenade Inspector
There are lots of marine salvage yards that sell these engines. i believe they are called 170 mercruisers when you are searching. You still have to drill one hole on the bellhousing. If you push them hard you will need to short fill the block. There's a guy down in florida with one of these in a dragster that's has them pretty scienced out. google red's headers. he does lots of turbo 4 cyl ford stuff.
#14 |
Grenade Inspector
sorry, it's a 470 mercruiser. not a 170. it has 170hp stock.
#15 |
Grenade Inspector
It is a half of a 460 ford engine.
#16 |
Senior Member
4 bbl version is 488, 188 HP. Also 485, 2bbl with hotter cam and 170 MR and 190 MR (redesigned gear housing). Cam lift is .481/.503 for 470, .497/.517 for 488 and .497/.536 for 485 with 1.73 rockers. I put BBC roller rockers on mine as cheaper. As to coolant flow, it is from the radiator to the rear of the intake (488 has oil cooler in intake bottom also), then to the water pump and out the front of the head to the radiator in a street application. You can use a 488 thermostat housing with a Cosworth Vega thermostat housing to make an 1-1/4" inline holder since you eliminate the water cooled exhaust. You will also see the alternator is in the dampener stock.
#17 |
Old School HAMBer
#18 |
Old School HAMBer
Phil1034, what is the rpm range with the OEM camshaft?
#19 |
Senior Member
I had Reed regrind mine, but I have some notes the 470 was 269/274 (216/220 @.050") on 114* centers so seems like a mild hot rod cam.
#20 |
Grenade Inspector
Now I know why I moved away from the Northeast. People spend all winter indoors smelling their own farts. I makes them irritable.
| Thread Tools | |
| Display Modes | |
