Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Old School HAMBer
I'm not a super tuner but I can get my shit to run pretty good on the street. I took some pictures as I synced the pair of 97's on the Stude motor. Some may find it interesting.
. . The victim. A 34 Ford P/U with a 55 Stude. engine and dual 97 carbs. I bought the truck running. It ran ok but the mechanicals of the truck weren't as nice as the truck looked. . . The first thing I did was disconnect the rod that linked the two carbs together. The set screw was loosened so the rod will slide in the connector. I also disconnected the throttle linkage to the gas pedal so that there isn't any resistance while adjusting. . . Here is the tool I like to use. Some have used the Unisyn tool for years and it works fine too. I just find this one easier to use. . . I put it on the front carb and this is what I got...Zero, Na da, nothing. The guage is reading no air flow. The engine was idling off the rear carb only. The rear carb was showing near 12 on the gauge. . . I screwed in the idle adjusting screw holding the gauge on the carb until it started to get a reading. Now the engine is idling too fast so I backed off on the rear carb screw. . . The red line between the 8's is the vane inside the tool that moves up and down with the air flow volume. It's now a simple matter of adjusting the idle screws up and down to syncronize the carbs. When the engine is idling nicely with both carbs reading the same on the gauge you're done. Lock the set screws that link the 2 carbs together, hook up the throttle linkage and pop on the aircleaners. The truck was running ok so I had no idea they were that far off until I checked it out. It won't make a big deal in the performance of the truck but I have the peace of mind in knowing that it's right. You only need to do this on 2-2 set ups or six twos with progresive linkage. (sync the 2 center carbs together) The end carbs on 3-2's and 6-2's with progresive linkage need to be slam shut so no syncing is necessary. If you are running a Man-a-fre or some other 4 carb direct feed set up' be prepared to spend some time adjusting the screws. All 4 carbs affect the engine idle. It just takes time. Pretty basic stuff but if you've never tried it, don't be scared ![]() |
#2 |
Senior Member
ok great, now back the hubble telescope up and give us a look at that vehicle,it looks great from what i can see
#3 |
Old School HAMBer
. Your basic 34 Ford P/U, 259 Stude engine, T-85 3 speed and an 8" rear. It's a nice piece that I wish I could take credit for building. |
#4 |
Grenade Inspector
Tommy,where can a fellow get one of those Holley tools.I find the Unisyn a pain to use,the Holley tool looks more user friendly.
Chuck Fish |
#5 |
Alliance Member
i think that even as simple as that is to do it needs to go to tech-matic!
thanks for the demo. jerry |
#6 |
Old School HAMBer
I'm not sure. I've had this one for 30 years. I'd try Holley. I was told they are still available. Mine has a flat rubber gasket that fits the 2 bbl carbs. Drive her up here. We can do it in 20 min.s
#7 |
Alliance Member
Looks easy enough, now to find the synchronizer. Do you make house calls to the midwest?
#8 |
Grenade Inspector
Sounds like a plan... I gotta get a new starter switch. Went to start it up sat. nite and the Starter stuck! A little testing ,Ifound out it was the "sillynoid". I'll get a new one (American made this time)and get her runnin this week. maybe by the weekend I'll give you a call or stop by.
By the way, I dig the truck! It's "THE BOMB" Chuck Fish |
#9 |
Old School HAMBer
[ QUOTE ]
Looks easy enough, now to find the synchronizer. Do you make house calls to the midwest? [/ QUOTE ] No but if you feel like a road trip, I'll help you out. no problem. |
#10 |
Senior Member
Uni-Syn's are like 8-12 bucks... VW/sandrail places that sell cheap stuff will have them. Definately not as fancy as that holley one.
#11 |
Alliance Member
BTTT for Tech Week...
#12 |
Senior Member
that is a clean look ,nice
#13 |
Can that Holley tool be used on side draftcarbs or is it gravity sensitive? Oh, your truck looks pretty darn good.
#14 |
Old School HAMBer
I'm not sure I'd have to look at it to see. I'm not sure if there is a spring inside or not. When I recommended this tool before, someone found the same basic tool with different style adapters on the web someplace. They may make one for the side drafts. You might try Googling it.
#15 |
Alliance Member
All the tech to the top...
| Thread Tools | |
| Display Modes | |
