Reply
Thread Tools Display Modes
Old 03-22-2008, 09:00 PM   #1
SMier
FNG
Question How to free up an old flathead?
Just towed my latest project home today, a 1951 Ford F2 pickup with a flathead V8, its an old farm truck that had been in their family since it was new. They parked it 20+ years ago and hadn't touched it since. We put a breaker bar on the crank pulley and tried to spin it with no luck, I didn't try to force it, because I figured it would be stuck. I bought a can of marvel mystery oil to pull the plugs and soak it down with and let it sit for a week. I'm just wondering what other people have tried, what works and what doesn't... I'd like to do as little damage to the motor as possible ( I know it'll need rebuilt more than likely). Couple of my buddies are really confident that we'll get this motor freed up and running again if it ran when they parked it... I wish I shared their confidence... on the positive side I've always wanted a truck like this with the flathead V8, she's rough but very straight, only dent is in the roof, and almost everything is complete except for the wooden bed floor that's rotten. It was kinda neat the grandfather( original owner) was there when we brought the roll back in and took our pictures next to his old truck before we towed her off.
__________________
'51 Ford F2 with a Flathead V8
offline   Reply With Quote
Old 03-22-2008, 09:11 PM   #2
Goztrider
Old School HAMBer
Goztrider's Avatar
Default Re: How to free up an old flathead?
My uncle did this trick with an old tractor he bought - and it had a stuck flathead engine in it as well.
He drug it up onto the trailer and left enough slack in the chains so that the thing could move front and back a few inches. Now, he had safety chains on it as well to prevent it from coming off the trailer, but it had still enough slack to move around a bit.
He pulled the plugs and added the marvel's, just like you did. He also left the tractor in 2nd gear (I think). Then he just spend a good day running around doing his errands with the tractor on the trailer. Seems that he constant movement forward and backward freed the stuck rings and he added a fresh battery, fuel, and kicked it off and drove it that way until he sold it.
Might be worth a try.
__________________
Subtlety is saying what you mean, and getting out of the way before it is understood.
My '29 Dubble A build progress thread.
Old 03-22-2008, 09:24 PM   #3
GEEZZER
Grenade Inspector
Back around 70-72 bought a 50 Ford woody off the back of a tow truck, on its way to the junk yard for $50.00. Body and wood was allright[ cherry by todays standards] Had a rt outer door panel missing and the motor was stuck. Pulled the plugs poured in some automatic trans fluid, worked the crank with a socket and breaker bar ,loosened it up, a set of jumper cables and she was running. I think I sold that thing for a hundred bucks. A mighty fine profit. Years later I used that same process on an old jet boat my son bought with a 455 Olds.
Old 03-22-2008, 09:28 PM   #4
wideglide74
Senior Member
wideglide74's Avatar
Great thread. I just bought a 47 ford PU that sounds to be in the same shape as yours, I'd also like to have a go at freeing up the old flathead. I'm sure it was a runner when it was parked...
__________________
WTB Very clean, rear mount, curved lense SW Fuel gauge...
Old 03-22-2008, 09:47 PM   #5
Straightpipes
Senior Member
Straightpipes's Avatar
A stuck flathead is usually due to valves. Once them suckers are stuck they are STUCK. I'd pull the manifold and heads and see whats going on in there. Wouldn't hurt to clean the mice nests out anyway. Man, I spent all day today doing a flathead valve job
__________________
"You damn hotrodders ain't never goin" to amount to nothin" .... Local Cop 1960
Old 03-22-2008, 09:54 PM   #6
lostn51
Senior Member
lostn51's Avatar
we did the same thing to my best friends 1955 Ford in high school.. it had the original Y motor in it and it was locked up (sitting for 25+ years) but was very cherry. we poured marvel mystery oil in her and every afternoon after school we would try to spin the motor with a breaker bar. about a week later it loosened up and we fired it up ran like a top after we gave it a tuneup. then he got a few bad grades and his dad took the car away till the next report card. guess what ...........it was locked up again!! so we did the same thing over again and after that he made sure he had good grades!!
__________________
Old 03-22-2008, 10:20 PM   #7
Old wolf
Senior Member
Old wolf's Avatar
Thumbs up Re: How to free up an old flathead?
Ive had very good success using brake fluid in the cyls. As was mentioned before the valves on flathead engines tend to stick. I would at least pull the intake to check. sometimes you can use a large screwdriver to pry on the flywheel teeth do it a little at a time back and forth. OldWolf
Old 03-22-2008, 10:28 PM   #8
Shoprag
Shoprag's Avatar
My buddy kelley filled his flathead all the way full with paint thinner, filled it til it was overflowing (oilpan and lifter gally and cylinders) with the plugs out. while he was messin with other stuff, he would rock it back and forth here and there for about 2 hours and it freed up. he also did this to his 52 buick straight 8. the old oil tarred up on the lifters rods and mains and the paint thinner washes it.
online   Reply With Quote
Old 03-22-2008, 10:34 PM   #9
phat rat
Old School HAMBer
phat rat's Avatar
Not saying it can't be done, I've done it, but not on all and I wouldn't hold my breath. I bought a 52 truck awhile back that the guy claimed had run 3-4 years before. LOL After soaking it with everything I could think of, with the heads off, I finally resorted to a piece of 3" channel iron and a BFH. Took the rod caps off and beat the hell out of two of the pistons and never did get them to budge, the other 6 came out ok. I had another one the same way a year ago.
Old 03-22-2008, 10:35 PM   #10
R Pope
Old School HAMBer
If it's a rolling chassis, put it in high gear and chain it bumper-to-bumper with another vehicle, preferably with an automatic. Then rock the old truck back and forth, not getting too rammy, and you'll be surprised how soon it turns over. I have got a few buddies together and pushed 'em back and forth by hand, but that was when I and my buddies were newer. The rocking will free 'em up much sooner than tons of force in one direction.
Old 03-22-2008, 10:43 PM   #11
Straightpipes
Senior Member
Trouble is that you get it to turn over by forcing that stuck valve up. So now it turns over nicely but the valve is stuck open.
__________________
Old 03-23-2008, 10:57 AM   #12
phat rat
Old School HAMBer
phat rat's Avatar
Quote:
What you say is true as long as the rust isn't so back that the piston and wall have become virtually one. When you see the piston kinda crumbly the thing isn't goning to move by rocking it.
Old 03-23-2008, 11:15 AM   #13
ago
Senior Member
ago's Avatar
I heard gasoline and brake fluid works well.
Ago
Old 03-23-2008, 11:21 AM   #14
rotorwrench
I've seen a camshaft broken in a truck motor 8rt due to turning the engine without freeing the valves. One of the valve stems was also pushed through the hollow lifter. If you thing stuck valve assemblies are hard to get out just try to get one out with a hole in the lifter. You cant tap on the lifter from the bottom cause it's just hitting springs. Take your time and pull that manifold to make sure.
Old 03-23-2008, 11:25 AM   #15
Flatman
Senior Member
Flatman's Avatar
Pull the intake and heads, the gaskets aren't that expensive. You need to see inside that engine to know what you're dealing with. Valves and lifters are notorious for sticking. If it's been sitting for a long time, you'll want to change the valve seals as well. Pull all the valve assemblies and clean everything. You'll also be able to check the cylinders for ridge depth, cracks, sleeving, and scoring.
Flatman
__________________
Some men are Baptists, others Catholics, my father was an Oldsmobile man.
Old 03-23-2008, 11:37 AM   #16
flatford39
Senior Member
I've got one on the engine stand and have been soaking it for a month now in Kroil and using a breaker bar with a piece of pipe on it for more leverage and it won't budge. Intake and heads are off and I've soaked it thouroughly. The cylinder walls look ok although one of them did get water in it at one time and that one I am soaking in brake fluid. The valley was real clean without a lot of gunk build up.
I guess I just gotta be patient with it.
Old 03-23-2008, 11:49 AM   #17
pistinbroke
pistinbroke's Avatar
Last one I did, I used deisel fuel. I filled it up through the intake and the fuel pump stand untill the fuel stated coming out. Left it for a few days, used a breaker bar and rocked it back and forth. Took a while but it loosened up, going to try and fire it next week. I've been spinning it every day since I got it lose, and haven't drained it yet. I'll let you know how it works out.
Old 03-23-2008, 12:09 PM   #18
Mudslinger
Senior Member
Mudslinger's Avatar
I havent tried this but I read on a forum some where after filling the cylinders with whatever your choice is, trans fuild, brake fluid etc. This guy put a braker bar on the front pulley bolt and put tension on it with a floor jack and left it that way. He rocked it and messed with it for a while, weeks I think and he busted it free.
No idea what condition it was after that but I read it. It may have been here?
__________________
Looking for 49-50 Oldsmobile Grille and Bumper.
41-48 Ford passenger sheet metal.
Old 03-23-2008, 12:41 PM   #19
hoarder1212
Grenade Inspector
hoarder1212's Avatar
I have had great success with equal parts trans fluid,brake fluid, and kerosene. And keep trying it with the breaker bar,sometimes it can take up to a week but it always works. Good luck.
Old 03-23-2008, 01:12 PM   #20
BobbyD
BobbyD's Avatar
I've been working on the one in the '50 coupe I bought a couple weeks ago, had it soaking in tranny fluid and keresone, stuck as hell. Finally pulled the heads and intake and low and behold, one cylinder has gotten some water in it enough to form some heavy rust. A block of wood the size of the piston and a 5lb hammer I knocked the bad piston to the bottom of the bore, then took some Gibbs and 80 grit, then more gibbs and 180 grit and cleaned it out good again and soaked it with gibbs overnite, as well as the rest of the bores, next morning it spun over like a new one. Put her back together and she fired up on the first try, sounding good. Moral of the story, had I tried to "force" it to turn over it would have busted the rings and probably the piston in that bore. Take it apart, get a good block of wood and start banging on the pistons. Also if you have a old flathead valve tool use it to get under the spring to help free the valves up also. Hope this helps.
__________________
A "hand out" is what you get from the goverment,
A "hand up" is what you get from a friend.....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
