Reply
Thread Tools Display Modes
Old 03-22-2008, 08:19 AM   #1
rpol7966
Grenade Inspector
Default How to "Age" Aluminum???
I have a machined aluminum air cleaner(yes, it's billet) that I want to remove the shine on. What are some techniques that can be used? I'm thinking sandblasting, glassbeading or a chemical process to etch/oxidize.
I'm wanting an appearance similar to old aluminum valve covers that have a darker oxidized look.
Like most here, I don't like the billet look but some billet items might be used if they can be "disquised".
offline   Reply With Quote
Old 03-22-2008, 08:32 AM   #2
charleyw
Alliance Member
charleyw's Avatar
Default Re: How to "Age" Aluminum???
I seem to remember a mention of using oven cleaner to remove the anodizing (if it is). That would get it to bare alum.
Old 03-22-2008, 08:37 AM   #3
Bob the Ferret
Bob the Ferret's Avatar
Location: Santa Rosa NM Yes, it's part of the United States
Quite right . Oven cleaner has a lye type substance that will remove anodizing quite easily . Experiment first by leaving the stuff on for a short period , extending the time until you get the results you want .
Old 03-22-2008, 08:38 AM   #4
brandon
Old School HAMBer
brandon's Avatar
might try glassbeading then a trip thru the dishwasher.... some drain cleaners will discolor polished stuff as well.....easyoff oven cleaner will discolor aluminum and remove the shine.....(that ones from experience....cover those big rig tanks when removing lettering ....and wear gloves...) brandon
Old 03-22-2008, 09:54 AM   #5
Bokchoy
FNG
Bokchoy's Avatar
battery acid from an old battery will do wonders. just be careful.
Old 03-22-2008, 09:56 AM   #6
Royalshifter
Moderator
Royalshifter's Avatar
Oven cleaner works good but wash it right after.
__________________
"I LIKE KUSTOMS"
Old 03-22-2008, 10:00 AM   #7
Bert
Grenade Inspector
Ive always used sraight amonia on brand new silver jewelry to make it age and go dark in the recesses and then polish it with a polish cloth to get back an aged shine....works great...should work well on alumium too...try a small spot and see........cheers, Bert
Old 03-22-2008, 10:03 AM   #8
Gauder the goof
Grenade Inspector
Gauder the goof's Avatar
Oven cleaner has worked for me. Like has already been said, keep an eye on it as the longer you leave it on, the more it works.
Old 03-22-2008, 10:04 AM   #9
GTSDave
Grenade Inspector
GTSDave's Avatar
I always use vinegar and water to etch aluminum before I paint it. It is cheap, and mild enough that you can take your time and get just the amount of etching you want.
I use a tub of warm water just deep enough to cover the part, and about a cup of vinegar. If the wife isn't around the bath tub is perfect hehehe. The neat part is if you check on it every 15 or so minuets, you will be able to see just how much the finish has changed. It will look like nothing is happening for a while, but once it starts you will be able to see it.
This vinegar method has always given me a very even finish like a part that has been sitting in the sun for years. The longer you leave it in the vinegar, the duller/older it will make the surface.
I have used easy off, too, but it always seems to be splotchy. Some parts real dull, others still shine like they haven't been touched.
Best part is vinegar is CHEAP! You probably already have it in the kitchen.
-Dave
__________________
Please pray for our brothers and sisters in harms way
Old 03-22-2008, 10:16 AM   #10
jj mack
jj mack's Avatar
Use a scaler to make it look cast.
http://www.use-enco.com/CGI/INSRIT?P...&PARTPG=INLMK3
Old 03-22-2008, 10:18 AM   #11
GTSDave
Grenade Inspector
GTSDave's Avatar
jj mack,
I have seen those things for years, but never used one. Are they worth the money? What else do you use yours for?
-Dave
__________________
Old 03-22-2008, 10:36 AM   #12
jj mack
jj mack's Avatar
Quote:
Originally Posted by GTSDave View Post
jj mack,
-Dave
Not much......
If you have a bead blaster the bead blaster works much better for removing paint, which is what I think these were made for.
But is you have to repair cast aluminum you can make the weld "disappear" by using one of these.
Old 03-22-2008, 10:36 AM   #13
Halfdozen
Alliance Member
Halfdozen's Avatar
jj mack,
...What else do you use yours for?
-Dave
Removing flux from stick welds.
Old 03-22-2008, 10:40 AM   #14
Flatman
Senior Member
Flatman's Avatar
There is a treatment called "Liver of Sulfer" that'll darken it down to black in seconds. It's used in jewelry work. Try it after a light sandblast and then lightly buff the high spots, should give you a nice cast look.
Flatman
__________________
Some men are Baptists, others Catholics, my father was an Oldsmobile man.
Old 03-22-2008, 10:49 AM   #15
DocWatson
Old School HAMBer
DocWatson's Avatar
A scaler is for removing rust scale. Originaly and still mainly used in the marine world, any squid will know these!
__________________
There’s a meaning there, but the meaning there doesn’t really mean a thing.
Old 03-22-2008, 10:50 AM   #16
GTSDave
Grenade Inspector
GTSDave's Avatar
Thanks Doc!
-Dave
__________________
Old 03-22-2008, 10:56 AM   #17
swade41
Old School HAMBer
swade41's Avatar
So will oven cleaner work on polished aluminum like Weld wheels ?
__________________
Gasser Gang of WNY
Old 03-22-2008, 11:35 AM   #18
David Totten
Grenade Inspector
s;ome of the spray on wheel cleaners that say not for polished aluminum will dull them .
Old 03-22-2008, 11:41 AM   #19
Barn-core
Barn-core's Avatar
Also before blasting the part you might want to try using a file, grider, or an agressive sand paper to knock off any sharp or crisp edges, that will help age it, and give it more of a cast look as well.
__________________
Barn-core, contra mundum with a vengeance!
Old 03-22-2008, 11:57 AM   #20
Bigbearchaseme
Bigbearchaseme's Avatar
Sandblasting is how we made the billet brakes look cast when i worked at Flyrite.
__________________
Instagram.com/fadedlovegarage
Instagram.com/bigbearchaseme
online   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
