Reply
Thread Tools Display Modes
Old 03-07-2008, 04:26 PM   #1
DeucePhaeton
DeucePhaeton's Avatar
Default Tech: 348 - 409
I did this back in the early 80s when I rebuilt the ole 348 for the Impala. As the "W" motor fans know the deck angle to the cylinder bore for these engines isn't perpendicular to one another. So how does one install the pistons into the cylinders after a rebuild? >A< You can run down to your favorite AZ and purchase a 348/409 piston ring compressor. Ya, sure.. >B< Get a few of your favorite buddies over for a install party with a half dozen flat blade screw drivers. I don't recomend this! >C< Try it by yourself with the kids outta shouting range. Or >D< Takes a little preplannning but I used a piece of black pipe and bored it on a lathe to a couple of thousands under my finished bore diameter. Squared up one side to the bore and milled the other to the proper 17 degree angle of the deck. Use a standard piston ring compressor on the square side. Worked like a champ.
I'm sure there are other ways but it's how I skinned the cat.
Click image for larger version
Name:	ring compessor.JPG
__________________
Luck:
is at the intersection of planning and opportunity.
offline   Reply With Quote
Old 03-07-2008, 04:27 PM   #2
CURIOUS RASH
Classified's Moderator
CURIOUS RASH's Avatar
Default Re: Tech: 348 - 409
How much for it?
Old 03-07-2008, 04:41 PM   #3
Candy-Man
Senior Member
Candy-Man's Avatar
Saves breaking rings ?
__________________
Its Not How Fast You Went, Its How You Went Fast....
http://candyshotrodsupply.blogspot.com/
Old 03-07-2008, 08:12 PM   #4
Tony
Alliance Member
Tony's Avatar
Quote:
Originally Posted by CURIOUS RASH View Post
How much for it?
I was thinking the same thing, that or, how much to rent it for a little while??
Nice...
__________________
WHO CARES!
"You are cordially invited to shit in your hat"
-Chili Phil-
Do you need a open 32 Ford registration for your display case?? I have a NY one perfect for framing! contact me.
Old 03-07-2008, 08:47 PM   #5
Ricola
Newbie
Ricola's Avatar
Me too!
__________________
[SIGPIC][/SIGPIC]Who say's Aliens only abduct people?
Old 03-07-2008, 08:54 PM   #6
DeucePhaeton
This is for a +.060" 348. So it's 4.183" or so.
__________________
Luck:
Old 03-08-2008, 07:31 AM   #7
modifieddriver
Old School HAMBer
modifieddriver's Avatar
Hell, I need it too. I'm doing a 348 +.060.
I promise I'll return it. I've been dodging this job for awhile just because of the ring compressor issue.
Rental fee? Deposit ....... I'll give ya' the title to my '40 Ford Pickup!!!!
__________________
If ya' really want it.....all ya' have to do is "STEP-UP".
Old 03-08-2008, 11:34 AM   #8
Larry T
Old School HAMBer
Larry T's Avatar
I didn't know it was that hard to install pistons in a 348/409 without a ring squeezer. I've had good luck just squeezing the rings as they go into the cylinder. The further they go into the cylinder the further around you squeeze them until they're all the way in, if that makes any sense.
Old 11-22-2011, 02:12 PM   #9
DeucePhaeton
Dragging up old threads....
How'd this work out for people? Did anybody have one made? What did it cost?
__________________
Luck:
Old 11-22-2011, 02:14 PM   #10
GOATROPER02
Alliance Member
GOATROPER02's Avatar
What bore size is that one....Ive got a use for it..Lol
__________________
Ross Racing Engines
1763 North Main St
Niles,Ohio 44446
330-544-4466 w
330-720-1282 c
www.RossRacingEngines.com
Ross Racing T-Shirts
http://www.jalopyjournal.com/forum/s...d.php?t=597973
Old 11-22-2011, 02:31 PM   #11
Max Gearhead
Alliance Member
Max Gearhead's Avatar
Nice item.
__________________
Posted telepathically from my mancave
Join the 348-409 Chevy group.
http://www.jalopyjournal.com/forum/g...hp?groupid=125
Primates CC
online   Reply With Quote
Old 11-22-2011, 02:35 PM   #12
DeucePhaeton
I figured you had the resources to make your own.
I can loan it to you when I send your T-shirts ----
Answer to the question is, I built it for installing my 348 +.060 Pistons way back in 82. I installed used Jahns that measured out to be +.058" with wear and IF I remember right it was bored -002" from that dimension. I just used it to install my new Egge pistons which are an honest +.060" is it still works.
Brian
__________________
Luck:
Old 11-22-2011, 02:53 PM   #13
Truckedup
Old School HAMBer
Truckedup's Avatar
Old 11-22-2011, 02:57 PM   #14
48 Chubby
48 Chubby's Avatar
When a 348/409 is bored it should also be counterbored. If the bore goes .060 over then the combustion chamber (it's in the block) also goes .060 over. Then you can use a standard band type ring compresser seated at the bottom of the counterbore. Beyond where the ring squeezer sits, its just like any other engine. I've built a few of these, no problem.
__________________
We has met the enemy, and he is us.
Old 11-22-2011, 03:25 PM   #15
56don
Old School HAMBer
56don's Avatar
I was expecting to have trouble putting my pistons in because of all the stories I heard about the W motor being hard to install pistons/rings. But I had no trouble at all. Mine was bored .030 and I used a standard ring compressor. I had no problem.
__________________
I'm just an analog guy trying to make it in a digital world.
Old 11-22-2011, 05:43 PM   #16
DeucePhaeton
Quote:
Since the combustion chamber is determined by the pistons and it cylinder, how much does this lower the compression? Probably not much but have you done the math? How deep (dia) is the counter bore?
__________________
Luck:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
