Reply
Thread Tools Display Modes
Old 03-03-2008, 10:38 AM   #1
31aBoy
Default Ford 9 Inch Axle Seals/Wheel Bearing Advice Would Be Nice
I know this has been discussed a few times on the Hamb. More guys are running the 9 inch then have replied to those old threads.
So what is the trick to have leak free axles? Running a sealed bearing with seals? No seals?
I have also found and inner tube seal that i think installs from inside the center section.
http://www.allstarperformance.com/product.htm?prod=747
Anyone have any luck with those?
Found these on a stock car website..
http://www.stockcarproducts.com/rear8.htm
__________________
1931 Tudor
offline   Reply With Quote
Old 03-03-2008, 10:56 AM   #2
348tripower
Grenade Inspector
Default Re: Ford 9 Inch Axle Seals/Wheel Bearing Advice Would Be Nice
Sealed bearings and seals. It cured my leaks. I was running sealed bearings only to begin with.
Don
Old 03-03-2008, 10:58 AM   #3
Drive Em
Senior Member
The inner seals are circle track parts aimed at keeping the lube in the diff on hard cornering, they are made to fit 3" DOM tubing that most floater 9" rear ends use. They could work on a regular 9" as long as the fit on the axle, and on the tube I.D. is correct. If you have a tapered roller bearing on the axle, that type of seal is no good because the bearings rely on the diff lube for lubrication. On regular ball bearing 9" housing ends, I install the axle seal with the correct tool that will not destroy it, dab a little RTV all around the edge of the seal so it will seal to the housing, and smear a little RTV around the circumference of the bearing when I install it in the housing. Using those tips will almost always guarantee a leak free housing end.
Old 03-03-2008, 11:31 AM   #4
36-3window
Old School HAMBer
36-3window's Avatar
use the proper bearing (large or small , depending on what you have) and new seals and you will be ok
Old 03-04-2008, 07:17 PM   #5
31aBoy
Quote:
Originally Posted by Drive Em View Post
I install the axle seal with the correct tool that will not destroy it.
Anyone know this tool he is talking about?
__________________
1931 Tudor
Old 03-04-2008, 07:44 PM   #6
36-3window
Old School HAMBer
36-3window's Avatar
he is talking about a seal driver. any good auto parts store should be able to sell you one , or maybe you could borrow one
i have a Lisle like this: http://www.sjdiscounttools.com/lis24800.html
Old 03-04-2008, 07:45 PM   #7
paulie_boy13
Grenade Inspector
I use a soft mallet up against the seal then strike the soft mallet with another soft mallet until the axle seal seats.
Old 03-04-2008, 08:29 PM   #8
31aBoy
Right, a seal driver...but you cant use a seal driver like that to install seals in the 9inch, when the axle hub is in the way...
__________________
1931 Tudor
Old 03-04-2008, 09:19 PM   #9
36-3window
Old School HAMBer
36-3window's Avatar
what? what kind of 9" do you have?
in the real world , with normal 9" rears.....the axle seals are inside the housing ends....you install them BEFORE you put in the axle with the bearing pressed on
i've done this many times
Old 03-05-2008, 12:21 AM   #10
HOT40ROD
HOT40ROD's Avatar
Which bearing is in your rear the sealed bearing or the two piece bearing were the bearing is press on the axle and the race is in the housing. If you have the two piece bearing the seal is between the bearing and the axle mounting plate. You need to remove the bearing to replace this seal. Usually you end up replacing the bearing too. This style bearing is hard to stop from leaking. This seal needs to go in strait and you should use some sealer around the outside edge of the seal.
I hate working on that style bearing.
Old 03-05-2008, 12:32 AM   #11
HOT40ROD
HOT40ROD's Avatar
Picture of the two styles
Click image for larger version
Old 03-05-2008, 01:31 AM   #12
Leon
Grenade Inspector
Leon's Avatar
I have the 2 piece with the seal on the outside and use Hylomar to make sure the seal doesn't leak. It is like RTV but doesn't harden so if it is put in right it stays sealed. They are a pain but with this stuff it is easier to seal.
__________________
my stuff
Old 03-05-2008, 02:01 AM   #13
weemark
weemark's Avatar
Quote:
never seen the style of the axle on the right hand side, all the ones I have seen are the same as the one on the left.
always used sealed bearing and never had any leaks.
Old 03-05-2008, 02:15 AM   #14
chop32
Alliance Member
chop32's Avatar
Check the condition of the portion of the axle housing that the seal drives into.
I once had a 9" that wouldnt seal and later found that someone had previously gouged the housing (probably trying to remove the seal). I cleaned the area up with a die grinder and installed the seal with a little RTV and it stopped the leak.
Old 03-05-2008, 06:20 AM   #15
Old Rod
Alliance Member
Old Rod's Avatar
My housing is gouged like chop32, I tried RTV only and didn't seal. Anyone have the
correct seal number (at least I will know I have the correct seal)? My rear is 57 pass,
small sealed bearing, 28 spline. Thanks Bob
online   Reply With Quote
Old 03-05-2008, 09:35 AM   #16
HOT40ROD
HOT40ROD's Avatar
I have 4 housing laying on the floor with that style bearing. Not sure what they are out of. I got them for a guy that raced late models in N.J.
Old 03-05-2008, 09:50 AM   #17
C9
C9's Avatar
Location: Kingman, Arizona - The place on the way to other places....
Do you have a breather on the axle housing?
If not, increased pressure due to heat could help push oil past the seal.
Here's a couple pics of a home-made one.
It is baffled inside, but oil still gets carried out.
Just enough to dirty up the axle housing, I've never seen a drip from this area and never had to top off the oil in 48,000 miles of running.
The oil still looks clean when it's checked.
The diff etc. doesn't see a whole lot of load cuz the 32 is such a light weight car.
__________________
Sailing the turquoise canyons of the Arizona desert.
C9
Old 03-05-2008, 01:39 PM   #18
Old Rod
Alliance Member
Old Rod's Avatar
[QUOTE=C9;2632985]Do you have a breather on the axle housing?
Mine has the original type breather. Also mine leaks down the backing plate
just sitting still?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
